why 4x4 vehicles have nose down "no exception" ?? - Page 4 - Toyota FJ Cruiser Forum
 38Likes
post #31 of 40 (permalink) Old 09-18-2014, 09:10 PM
3L5 Lego's Avatar
Quoted: 47 Post(s)
Re: why 4x4 vehicles have nose down "no exception" ??
I found this thread funny in so many way.
3L5 Lego is offline
post #32 of 40 (permalink) Old 09-19-2014, 08:51 AM
jasonfjc's Avatar
Quoted: 75 Post(s)
flipping over is more complicated than looking at your car as a simplified point object.
flipping over has something to do with torque because flipping over is a rotating motion.
going down hill and you have short wheelbase and very light in the back, you are going to start rotating forward if you brake hard enough if torque is strong enough to lift the back end.
same with uphill, if your front is light and you have too much throttle you flipping backwards.
long wheelbase is better than short wheelbase, lower car is better than higher car.
Other cars will get you somewhere, but a Land Cruiser will always get you home.
2013 Toyota FJ Cruiser
2017 Ford Mustang GT/CS
2015 Ducati Monster 1200
jasonfjc is offline
post #33 of 40 (permalink) Old 09-19-2014, 08:55 AM
mikey's Avatar
Quoted: 1556 Post(s)
If an airplane is on a treadmil...
FJess, WaJohnZ and Lightpath like this.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #34 of 40 (permalink) Old 09-19-2014, 09:03 AM
bazross's Avatar
Quoted: 1849 Post(s)
TRDParts4u previously said: View Post
The reason all trucks and most suv's are taller in the rear is so the vehicle will sit level once loaded. They also do this so the head lights wont blind people if the vehicle is loaded down. It has nothing to do with aerodynamics or off road improvments.
Thats why Yota fit actuators to our headlights so we can adjust them depending on load from the dash....
Cheers
Baz
FJ Moose likes this.
bazross is offline
post #35 of 40 (permalink) Old 09-19-2014, 09:13 AM
Quoted: 671 Post(s)
WaJohnZ is offline
post #36 of 40 (permalink) Old 09-19-2014, 09:26 AM
FJess's Avatar
Quoted: 423 Post(s)
FJ Moose previously said: View Post
The coefficient of the center of gravitational rollover is inversely rooted the 5th derivative of sin(of the driver's intoxication level)
More simply put, the angle of the dangle is inversely proportional to the heat of the beat.
Jessica
2011 Cavalry Blue with some added stuff.
Iconic_ previously said:
Donít be afraid to use your rig! Dents can be popped out, scratches can be buffed out, but in the end the memories you have make it so worth it!
FJess is offline
post #37 of 40 (permalink) Old 09-19-2014, 10:43 AM
Lightpath's Avatar
Quoted: 58 Post(s)
Gotta love Myth Busters!
Lightpath is offline
post #38 of 40 (permalink) Old 09-19-2014, 10:58 AM
I Have a V-8!! Moderator
BIGGUY's Avatar
Quoted: 7041 Post(s)
Cheers
Baz
Aren't those nice. I adjust mine down a bit to get better light in front of me since I'm usually not running fast and it works pretty good.
bazross and FJ Moose like this.
BIGGUY is offline
post #39 of 40 (permalink) Old 09-19-2014, 11:21 AM
mikey's Avatar
Lightpath previously said: View Post
Used to, not so much anymore.
Like some one else mentioned that when loaded you sit level....it's not about where your lights are shining it's about maintaining weight over the front wheels.
If you are squatting in the rear you are light up front this = less steering control and poorer braking. With the load too the rear now your rear brakes are taking working harder than the fronts...not what they are meant for.
Kermit the Frog
mikey is offline
post #40 of 40 (permalink) Old 09-19-2014, 01:38 PM
Quoted: 26 Post(s)
This.
They're designed that way so they don't squat when running with a typical load.
I guarantee Jeep engineers didn't lower the front an inch and a half on every wrangler they sold because they were concerned about the .01% idiot factor rolling his junk over backwards.
_Bacchus_ is offline
