So I'm probably the first to ask.... - Page 2 - Toyota FJ Cruiser Forum
 2Likes
post #11 of 14 (permalink) Old 10-04-2015, 12:12 PM
gaylonw's Avatar
Quoted: 187 Post(s)
Re: So I'm probably the first to ask....
Usedbutnotabused previously said: View Post
When they changed the engine in 2010 it was a horse power for torque trade off. So yes earlier engines had more torque (low end zip) and newer ones had more hp (higher top end speed). For the type of vehicle the FJ is, l'd pick the torque.
The initial engine was single Variable Valve Timing on the intake side only.
The new engine is Dual Variable Valve Timing.
The set-up employs heads that are much wider than the previous engine making the oil filter location of the older engine impossible.
The new engine is greener and gets about a mile better fuel economy.
A mile per gallon is money saved for other things that you may want to do to or with your FJ.
Toyota constantly upgrades things as they go along.
Some times it is a new and improved engine; other times it is a different design for the rubber seals for windows and doors.
Park my '12 RRTT next to my '14 TTUE and you will notice that it is different than my '14 in subtle ways, better but the same!
It the Toyota way, Kaisan!.gm
amaclach likes this.
TLCA # 20795
2018 Lexus LX570
2018 Jeep JK Rubicon Recon
2014 FJ TTUE- 1 of 2500
1994 Mustang Cobra Indy Pace Car Convertible 5.0 (Stock)
1986 Ford F150 XLT Super Cab Longbed 5.0 (Stock)
1982 Jeep CJ7 Limited Edition (Stock)
1966 Corvair Corsa Turbo Convertible (Stock)
gaylonw is offline
post #12 of 14 (permalink) Old 10-04-2015, 12:43 PM
Desert Moderator
amaclach's Avatar
Quoted: 2853 Post(s)
I agree with @gaylonw - Our Fortuner has the single VVTI engine and it sounds better, but the Dual VVTI in my FJ has more overall power and uses a lot less fuel even with the FJ's worse aerodynamics.
It is true that the early engine has slightly more peak torque, but the newer engine changes character significantly at the 3500 RPM mark, and I feel the torque delivery is more linear.
gaylonw likes this.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is online now
post #13 of 14 (permalink) Old 10-05-2015, 06:54 AM
boilermaker's Avatar
Quoted: 128 Post(s)
As someone else mentioned, if you're looking for an FJ, craigslist can be your friend. I always use the site searchtempest.com it lets you browse multiple cities to find the best deal on a FJ.
boilermaker is offline
post #14 of 14 (permalink) Old 10-05-2015, 08:29 AM
Kevin108's Avatar
Quoted: 109 Post(s)
Don't get hung up on finding a 2010+. Lots of people suggest that but the 07-09s are usually fine. Know what to look for in regards to fender bulge and transmission shudder. Do a search and you'll find plenty of info. Of course, spend some time underneath looking for rust or leaks.
Some will tell you that the 07-09 have to be run on premium fuel. They don't.
Some are worried about the improper heat treating on some of the 07-09s. It's cheaper to buy an 07-09 and replace the rear diff than it is to buy a 2010+.
Do read up on what to look at for the motor mounts. That would be a big downer to address on a new-to-you rig.
Good luck with your search!
Kevin, Shannon, and a 2007 FJ Cruiser | ОѴƦԼχƝƊ.com | Facebook | Instagram | YouTube
"You're born into the world thinking that you are...entering a world that's been seen before.
And seldom do you sort of wake up to the realization that you're the explorer." -- Sean Parker
Kevin108 is offline
