Pulled Some Shrubs, Now I'm Concerned - Toyota FJ Cruiser Forum
 31Likes
post #1 of 21 (permalink) Old 08-21-2017, 11:58 AM Thread Starter
fka P.S.
AgentP's Avatar
Quoted: 0 Post(s)
So this last weekend, I had some heavy duty yardwork to accomplish. I had some old hedges that I wanted to remove.
So, I embraced my inner hillbilly..and took my tow straps....and went to town.
I hooked up the tow strap to the shrub, and connected it to the front tow hoops.
All went well for the first couple of shrubs..yanked em clean out.
But then, on one of the bigger bushes, I actually broke/snapped the tow strap!
Now, stupid me...instead of thinking to myself...hey, I broke a tow strap with a breaking force rated at 12,000-15,000 lbs... I probably should not be doing this... what did I do?
I of course went out and bought another tow strap (the same one).
And...proceeded to snap that one immediately.
After that, I gave up...and decided it probably was not a smart move to begin with.. but now I find myself wondering.. did I, or could I have possibly done any damage to the FJ? It doesn't seem any worse for wear after the fact..but I guess the point of this post is to see if anyone out there could give me possible things to check , to make sure I didnt F anything up?
Thanks for the help!
jamesepoop likes this.
AgentP is offline
post #2 of 21 (permalink) Old 08-21-2017, 12:25 PM
Quoted: 1326 Post(s)
Re: Pulled Some Shrubs, Now I'm Concerned
Jeez ... broke TWO 12-15,000 lb breaking strength tow straps?
Post a photo of those "shrubs" ... not sure what they look like in OH, but on the west coast I think they're called "redwoods".
Or were those Harbor Freight straps, rated in "Chinese lbs"?
As long as your tow points are not deformed or cracked, you are OK.
However, not sure why you'd pull from the front ... a shrub that suddenly broke free while your strap was under tension (or even the strap itself) could have ended up launched through your windshield. Better to pull from the rear tow hitch, and place a small piece of plywood above the spare tire to protect the much smaller rear door glass.
FJtest is offline
post #3 of 21 (permalink) Old 08-21-2017, 12:27 PM
Mean Time Moderator
ZerosFJ's Avatar
Quoted: 1383 Post(s)
Well hopefully the straps were sacrificed to save your FJ, if you'd done some damage you'd probably have heard it.
2014- FJC Cement "Eddystone" US spec personal import - mods in progress https://www.fjcruiserforums.com/foru...eddystone.html
ZerosFJ is offline
post #4 of 21 (permalink) Old 08-21-2017, 12:51 PM Thread Starter
fka P.S.
AgentP's Avatar
Quoted: 0 Post(s)
As requested, here is a picture of the shrubs I pulled... they are about 5 feet high and about 4 feet wide.
https://goo.gl/photos/6QduiKzDDQXVVy4a9
And here is the tow straps that I broke..not once, but twice!
20' Tow Strap, Loop End; 17,000 lbs - SmartStraps
AgentP is offline
post #5 of 21 (permalink) Old 08-21-2017, 01:22 PM Thread Starter
fka P.S.
AgentP's Avatar
Quoted: 0 Post(s)
FJtest previously said: View Post
Luckily, the tow points don't look any worse for wear. I pulled from the front so that I could better see what I was doing....I wasn't too concerned with the bushes flying towards me..those things are super heavy and rooted deep....in retrospect, I should have likely never done this in the first place. Lessons learned.
AgentP is offline
post #6 of 21 (permalink) Old 08-21-2017, 01:34 PM
A few final questions:
1. How/where did the tow straps fail? The strap material itself failed, in the body of the strap; the stitching failed at the end loops; she strap material failed in the end loop; or something else?
2. Did both straps fail in the identical way? (Photos would be informative)
3. What was the Country of Origin?
FJtest is offline
post #7 of 21 (permalink) Old 08-21-2017, 01:39 PM
Quoted: 20 Post(s)
You should back up to the bush, give it some gas, throw it into neutral and let the weight of the FJ pull up the shrub. (kind of a sling shot effect) It may take a few tries, but they will come up. If it's really tough, dig on the back side and cut a few roots then tug at them. I've done this many, many times. Hope this helps. (still hard to believe the straps broke... strange)
buzzvtx is offline
post #8 of 21 (permalink) Old 08-21-2017, 01:47 PM Thread Starter
fka P.S.
AgentP's Avatar
Quoted: 0 Post(s)
The strap broke actually in the body of the strap..I'd say right at the front of the "noose" that was wrapped around the base of the bush. After the straps broke, the noose still remained firmly stuck around the trunk of the bush.
Unfortunately, I returned one of the straps (that I still had packaging for), and pitched the other one. But yes, they both did fail in the exact same way..and left me with almost identically the same amount of leftover strap post-breakage.
Not sure, I don't have any of the packaging material anymore, and I cant find much info on SmartStraps website.
AgentP is offline
post #9 of 21 (permalink) Old 08-21-2017, 02:38 PM
Quoted: 35 Post(s)
Did you put a shock load on the straps, or did you gradually apply pressure to them as they were put under load. Tow straps are durable, but can snap at a lower pull weight than advertised if the conditions are right.
Chains up next?
All the mods and vehicles I have ever owned.
Anything less than absolute overkill is a half assed waste of time.
UTEFJ is offline
post #10 of 21 (permalink) Old 08-21-2017, 02:46 PM Thread Starter
fka P.S.
AgentP's Avatar
Quoted: 0 Post(s)
UTEFJ previously said: View Post
Chains up next?
Ha...no chains...I learned my lesson and just chainsawed them down to stumps...now I just await the stump grinding guy.
As far as my technique was concerned..it was pretty awful I'm sure. I started being all casual..and going slow and just trying to pull them out. But then I got tired of turfing my lawn and not accomplishing much... So I would just take the slack outta the strap by pulling forward, and then hammering it into reverse to give a solid yank. This would stop the FJ dead in its tracks...well..until the straps broke.
AgentP is offline
