Charcoal canister skid? - Page 4 - Toyota FJ Cruiser Forum
 80Likes
post #31 of 57 (permalink) Old 01-25-2019, 07:15 AM Thread Starter
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2083 Post(s)
Re: Charcoal canister skid?
iwashmycar previously said: View Post
I do not think you would want anything that attaches to the body as it would just transfer the hit and probably F-up the floor.
This other thread about the overseas 'vibration damper' got me thinking....just run something across frame to frame...done.
https://www.fjcruiserforums.com/foru...gthen-bar.html
All in all, sucks some guy hit theirs, but I think you are worried over nothing....pretty freak occurrence.
Good thought! Makes sense to mount it on the two adjacent support members. Thanks for the suggestion And while itís a relatively infrequent occurance, with the advent of my high departure angle bumper Iíve been tackling more extreme drop offs and rock gardens that place rocks more in the canister vicinity No need for senseless destruction when a simple plate will prevent it!
Member of the Month November 2016
TLCA# 25170
debFJVT is offline
post #32 of 57 (permalink) Old 01-25-2019, 09:35 AM
Quoted: 90 Post(s)
I like the idea of bolting or welding in an additional cross member between the frame rails. Some 1 3/4" DOM and a little bit of 1/4" plate would be easy money.
Cruiser47 likes this.
smracing is offline
post #33 of 57 (permalink) Old 01-25-2019, 09:54 AM Thread Starter
MOAB SUPERSTAR
debFJVT's Avatar
smracing previously said: View Post
You mean running perpendicular to the two rails? Hmmmmm
Keep the ideas coming folks - this is great!
TLCA# 25170
debFJVT is offline
post #34 of 57 (permalink) Old 01-25-2019, 05:49 PM
Iconic_'s Avatar
Quoted: 2513 Post(s)
I was working on a box to cover it. IDK. I'll look at it some more tomorrow and see if my idea will work. Is protection there necessary? No. But it is piece of mind and cheap insurance. Plus I live for modifying the FJ in different ways.
You guys could just get body lifts. Mine is 1.5" taller than all of yours.
Iconic_ is offline
post #35 of 57 (permalink) Old 01-25-2019, 07:48 PM
Admin
Winterpeg's Avatar
Quoted: 2401 Post(s)
I don't believe the rear factory skid mounts to the bumper.... it has mounting point before it reaches the bumper and just sat below the bumper. I've removed mine to save on weight in the back... at some point I'll likely put it back on but I will have to tweak it a bit due to the Exp1 rear bumper.
(this is going off memory as it's been a few years now... the skid has been sitting in the corner or my garage for a bit)
Suck it up... it's only -40
2008 FJ Trail Teams
ARB Front; Exp1 rear STC; Apex rocksliders; Lightforce on front bumper; ARB Full Rack w/Grid; ; Icon Susp w/cdc; magnaflow muffler (mashed the original); Engo 12000S winch; 285/75/16 Duratracs; Ricochet skids, Uniden PC78 Elite CB (ch 16 typically, ch 19 on the hwy)
"Don't drive angry".... BFM
Winterpeg is offline
post #36 of 57 (permalink) Old 02-01-2019, 11:48 AM
4-Corners Moderator
FJX2000's Avatar
Quoted: 444 Post(s)
My 2008 Trail Teams was the one year that all TTSEs came with that factory rear skid and after reading this thread I'm glad I still have mine! It works in conjunction with my ARB rear bumper and like Winterpeg said, I don't believe it mounts to the actual bumper. So you may be able to get it to work Deb!
debFJVT likes this.
FJX2000 is offline
post #37 of 57 (permalink) Old 02-01-2019, 01:18 PM
Desert Moderator
amaclach's Avatar
Quoted: 2815 Post(s)
My charcoal canister is smaller than yours, and is mounted in the engine bay aft of the fuse box.
i see no reason why you couldn't just bolt a piece of Al plate between the chassis rails to protect the delicate bits there. I of course have an OEM 80L aux tank wrapped in a steel skid in that location...
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #38 of 57 (permalink) Old 02-04-2019, 08:08 PM
Cruiser47's Avatar
Quoted: 43 Post(s)
rotorhed1 previously said: View Post
I was backing up in the hills and didn't see a large rock. It tweaked the tailpipe and the exhaust leak was blowing directly on to the canister. It also melted the coax going to my rear camera and the wires for the sonar things. One reflector fell out of the stock bumper. I found an aftermarket one for like $2 and had to use a heat gun to reform the bumper wings.
I got a replacement canister from a Toyota wrecking yard in Cali for ~$200. But I still get an error code at times minor leak. I want to give it a smoke test to see where the leak is.
How did it run after the canister was compromised? Throw codes?
Sent from my SM-J700P using Tapatalk
Cruiser47 is offline
post #39 of 57 (permalink) Old 02-05-2019, 07:53 AM
rotorhed1's Avatar
Quoted: 900 Post(s)
Cruiser47 previously said: View Post
This happened around Ouray. It was a couple of days later, when driving a friend to the airport in Albuquerque. High speed, pulling a couple of hills. I got a bunch of lights, including the skid and traction control, and a smell. I have an Ultragauge so accessed the codes. P0441 and P0445 if I recall. Gross evap leak and minor evap leak. A rubber plug in the cargo area melted and the carpet in the cargo area got crispy in one spot.
I replaced the cannister and the larger tube that connects to it. Now I still get the P0441 minor leak sometimes. I am debating on how to find the leak. I could connect to an air source and pressurize to a max of 1/2 PSI. I would have to rig a manometer for that. Or use one of those smoke machines that shops use.
But no change in how it drove or performance when the lights are on.
Cruiser47, ZerosFJ and amaclach like this.
rotorhed1 is online now
post #40 of 57 (permalink) Old 02-05-2019, 03:12 PM Thread Starter
MOAB SUPERSTAR
debFJVT's Avatar
Yes itíll light up the Christmas tree and as a result, you wonít have ATRAC. For me thatís a problem when wheeling, but not a big deal on pavement.
rotorhed1 and Cruiser47 like this.
TLCA# 25170
debFJVT is offline
