I Wish This Part Existed - Page 11 - Toyota FJ Cruiser Forum
 184Likes
post #101 of 111 (permalink) Old 07-28-2019, 06:01 PM
TenMileHunter's Avatar
Quoted: 15 Post(s)
Re: I Wish This Part Existed
Thanks!!!
Iíve searched and searched to no avail.
Toytec couldnít offer any suggestions either.
Stock springs are 14Ē so a 16Ē spring should give me a couple inches lift?
TMH
Ten Mile Hunter
aka TMH
TenMileHunter is offline
post #102 of 111 (permalink) Old 07-28-2019, 06:15 PM Thread Starter
Iconic_'s Avatar
Quoted: 2611 Post(s)
TenMileHunter previously said: View Post
Thanks!!!
TMH
Technically yes, 2" taller might give you around 3" of lift. But I think that is accomplishing the same thing as just adjusting the preload on the 6112's?
Iconic_ is offline
post #103 of 111 (permalink) Old 07-29-2019, 10:15 AM
Quoted: 15 Post(s)
Can 2014 TTUE TRD 6112ís be preloaded to increase lift? I think the later ones could but I didnít think mine could. I was under the impression that new coil overs, lifting springs or spacers were the only choices I had other than a body lift.
Ten Mile Hunter
aka TMH
post #104 of 111 (permalink) Old 07-29-2019, 12:08 PM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3377 Post(s)
Thanks!!!
TMH
Technically, if they have the same spring rate.
See above^^.
Any spring can give you more lift if you preload them enough. What will suffer will be ride quality, braking distances, early failure of suspension, steering, Axles, and other components, but that's not what you really asked. What exactly are you trying to accomplish besides lifting 3"?
There are many reasons to lift, just curious yours. Also, there's nothing wrong with adding a 1/4" spacer on top of the coilover assembly, which will give you approximately 1/2" at the wheel to compensate. Keep in mind that the higher you go, the more down travel you give up and adding a limiting strap can help the suspension from topping out.
FJFool likes this.
R.I.P.- Echo
Solitude Allows One to Reflect While Others are Reacting...
It Is Easier To Walk On Hot Coals Then It Is To Walk On Egg Shells...-CC
Member of the month-October 2017
CabinCruiser is offline
post #105 of 111 (permalink) Old 07-29-2019, 12:36 PM
Kansas Law Dog's Avatar
Quoted: 49 Post(s)
Tired of following a vehicle for miles with its turn signal activated?
All cars should be equipped with a turn signal that doubles its clicking volume after 2 minutes (provides enough time to turn at a light or stop sign). That way the person driving is adequately notified that his/her turn signal needs to be turned off. If after another two minutes the driver still hasn't reacted to the blinker, the car should shutdown the radio and all bluetooth devices, and maybe spray water from the center of the steering wheel.
Rant off.
ďKansas Law DogĒ for admiration of ďTombstoneĒ, the movie, and the legend of Wyatt Earp.
2007 Titanium 4x4 Automatic (stock except non-factory rock rails)
Kansas Law Dog is offline
post #106 of 111 (permalink) Old 07-29-2019, 02:34 PM
FJFool's Avatar
Quoted: 269 Post(s)
Kansas Law Dog previously said: View Post
Rant off.
For some seniors, it's called "an eventual turn." Pretty sure it's a legal maneuver in Florida.
amaclach likes this.
óMIKE
Two roads diverged in a wood, and I,
I took the one less traveled by,
And that has caused all the damage to my FJ.
~ Robert Frost
42" Light Bar | Warrior Products Roof Rack | N-Fab RSP Bumper | ARB Skids | 4.0L V6 AT | ToyTec BOSS 2.0 Coilovers | Sway Bar Relocate | Toytec Superflex Heavy Duty Rear Coils | Toytec BOSS Rear Shocks | SPC Adjustable UCAs | Toytec Rear Aluminum 2" Bump Stop Kit | 265/70R/17 Toyo ATs x5 | 2" Wheel Spacers | Rad Rubber Designs Engine Splash Guards | Hi-Lift Extreme Jack
FJFool is offline
post #107 of 111 (permalink) Old 07-29-2019, 03:18 PM
Quoted: 15 Post(s)
What Iím trying to do is lift my 2014 TTUE to get some 305ís under it without rubbing. Plus looks. Iím an old phart so I need to keep the kids thinking Iím cool.
CabinCruiser likes this.
Ten Mile Hunter
aka TMH
post #108 of 111 (permalink) Old 07-29-2019, 04:02 PM
FJFool's Avatar
Quoted: 269 Post(s)
There are definitely parts for that.
óMIKE
~ Robert Frost
FJFool is offline
post #109 of 111 (permalink) Old 07-29-2019, 05:25 PM
トヨダ Master
FJFool previously said: View Post
You mean an Eventual Left?
FJFool likes this.
R.I.P.- Echo
post #110 of 111 (permalink) Old 07-29-2019, 05:26 PM
トヨダ Master
This is doable without 3". BMC and wheel back spacing comes to mind, but there are lots of folks running 305s with minimal lift.
R.I.P.- Echo
  Similar Threads
LCA Adjust Cam Sizes - Toyota Part Diagram Incorrect - 07-09 is different from 10+ Kamokazi Suspension / Steering Tech 2 09-13-2015 07:37 PM
OEM Air Dam part number for complete installation kevinco Newbie Discussions 1 08-16-2013 01:40 AM
FJ Part Out Feeler: Lots of Goodies Shadowrwr Want to Sell (FJ Related Items) 54 07-30-2009 06:49 AM
Tacoma owner looking for an FJ part number... griffin407c General Discussion 8 12-08-2008 11:09 AM
