Pre-Purchase Inspection, should I be scared away? - Toyota FJ Cruiser Forum
 1Likes
  • 1 Post By FJtest
post #1 of 8 (permalink) Old 09-06-2019, 11:42 AM Thread Starter
Quoted: 1 Post(s)
Question Pre-Purchase Inspection, should I be scared away?
Hi all!
I am in the process of purchasing a 2007 FJ with 115k miles on it. I took it to an independent Toyota shop and got the report back yesterday. Any purchasing advice is greatly appreciated. The FJ will be used as a daily driver and weekend warrior for backpacking/hiking some offroading to get to hard to reach places to camp.
Here is a link to the inspection: Inspection
I feel comfortable trying to tackle the suspension (control arms and such). Really worried about the timing cover leak.
Thanks in advance!
-Powda
PowdaSuga is offline
post #2 of 8 (permalink) Old 09-06-2019, 12:40 PM
Quoted: 1399 Post(s)
Re: Pre-Purchase Inspection, should I be scared away?
A minor timing cover leak is pretty common, and a bit of seepage (light oil film around the edge of the cover) isn't really a major concern. If oil is literally running down the front of the block and dripping onto the ground, then it's a major leak and requires repair.
Pressure wash the front of the engine to remove all grime and oil residue, and drive the vehicle for 1/2 hour. There should be zero to very, very little visible oil seepage after 1/2 hour of running after the engine is fully warmed up.
debFJVT likes this.
FJtest is offline
post #3 of 8 (permalink) Old 09-06-2019, 01:45 PM
longtooth's Avatar
Quoted: 82 Post(s)
As FJtest said, clean it off and drive it and check. If it IS leaking a little more than you like, you might want to just retorque the bolts. Break them and then retorque. Then clean and drive again. Heat cycles loosen bolts - just a mechanical fact.
You can also over-torque by about 10% on most bolts and nuts - there is a 15% safety factor in the specs that most folks don't even know exists...
longtooth is online now
post #4 of 8 (permalink) Old 09-06-2019, 02:13 PM
Quoted: 149 Post(s)
Look at the back window for a film of oil also. If oil is collecting there thatís a sign. Forward side of rear axle is more evidence of leak size
Sparky of SoCal is offline
post #5 of 8 (permalink) Old 09-06-2019, 03:06 PM
Serenity Now's Avatar
Quoted: 432 Post(s)
I scanned through pretty quick, but I didn't see any notes regarding frame rust (or lack thereof). I would want to know about that. Some of that suspension stuff may not be an actual issue (I doubt if the lower control arms actually need replacing...).
Steve in MN, sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
post #6 of 8 (permalink) Old 09-06-2019, 03:24 PM Thread Starter
Quoted: 1 Post(s)
Serenity Now previously said: View Post
I was thinking the same, there were some items on there that were nitpicking. As far as the rust is concerned I did talk with the inspection mechanic and there was no rust damage. The car has lived in northern california its whole life, not near the ocean.
Thanks!
post #7 of 8 (permalink) Old 09-07-2019, 07:22 AM
Sanderhawk's Avatar
Quoted: 1008 Post(s)
PowdaSuga previously said: View Post
Hi all!
Thanks in advance!
-Powda
I have owned my FJ for 13 years now and the timing cover has leaked for probly 12 1/2 years Nothing to worry about.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #8 of 8 (permalink) Old 09-07-2019, 07:51 AM
oldMattB's Avatar
Quoted: 27 Post(s)
We have a 2007 with similar mileage. Our timing cover also had a seep for years, but never enough to spot the driveway. I just ignored it, other than checking the parking space once in a while.
It was recently corrected when a timing chain guide broke, and the cover was R&R for the repair.
Good luck!
Matt B
oldMattB is offline
