The only thing I don't like about my FJ - Page 6 - Toyota FJ Cruiser Forum
I'd Like to Tell Toyota... This is for constructive suggestions to be made to Toyota regarding the FJ Cruiser. This is a flame free forum and heavily moderated.
 58Likes
post #51 of 98 (permalink) Old 06-18-2016, 10:25 AM
rev. 3:11's Avatar
Quoted: 57 Post(s)
Re: The only thing I don't like about my FJ
AtomicFJ previously said: View Post
I have the same complaint...even my 84 oldsmobile had a mist feature.... Also no heated mirrors!
Atomic,
You might check these out:
https://www.fjcruiserforums.com/forum...ng-2016-a.html
Even if group buy is over (?), still worth it!
They offer the EZ View mirrors plus heated mirror pads.
2 birds w/ one stone!
Pretty basic install; heating pads come w/ wiring & terminals.
(have't used heaters yet, I'm in Houston, sooo... more of a add-on for when I travel)
& LOVE the mirrors!
D
AtomicFJ and FatJohnson like this.
Silver '11 FJ
Snorkel, CAI, dual batt., scuba mod, TRD susp., up-graded brakes, LED lightbar, pushbar, EZ View mirror, "shorty" ant., ARB comp., remote jumper cables, MaxTrax, hi-lift jack, Scangauge II, Fresnel lens, LEDs, Tuffy console, Frontrunner drawer, Springtail basket & rear rack, Chi-Town pwr rear window, 12.3" HU, & various bling...
ready to install: Metal Tech hidden winch, Switch-Pro panel, wheel flares, Wits' End remote air coupler/batt.
'87 Grand National
resto-modding...
rev. 3:11 is offline
post #52 of 98 (permalink) Old 06-20-2016, 10:34 AM
Kaiju's Avatar
Quoted: 49 Post(s)
amaclach previously said: View Post
yeah but 2 problems -- people wolud ***** that it has no creature comforts, and crash tests - LOL. This is why the Defender went the way of the dinosaur after 67 years.
That was my point, use the old J40 body styling, but upgrade the safety and technical aspects of the vehicle to modern standards. It doesn't look that much different than a modern squared off Jeep Wrangler and it would look waaaaay cooler.
Army Green 2011 FJ. My baby, the green strange beast.
Kaiju is offline
post #53 of 98 (permalink) Old 06-20-2016, 01:19 PM
Desert Moderator
amaclach's Avatar
Quoted: 3005 Post(s)
Kaiju previously said: View Post
Got it. New wrangler will be interesting - better aero out of the factory with cheap plastic on the front which can be easily removed is my guess - and more rake on the windshield.
Black '14 6MT
Stock bumpers
Some mods
Rear Diff Lock on Demand mod: https://www.fjcruiserforums.com/foru...mand-hack.html
Nannies Off Mod: https://www.fjcruiserforums.com/foru...ml#post1183262
amaclach is offline
post #54 of 98 (permalink) Old 06-21-2016, 05:59 AM
norm356's Avatar
Quoted: 520 Post(s)
…wait, you are describing an FJ Cruiser then
Not an original body on a modern chassis (which is what Icon Motors does), but you want a modern body in the style of a classic vehicle. OK, then you want an FJ Cruiser, or any Jeep Wrangler, ever.
As already pointed out, people will b*tch about the lack of creature comforts if you don't modernize it, but if you do then you don't have the classic anymore.
In either case, this theme is pretty much the opposite of what this thread was supposed to be about: what DON'T you like about your FJ?
norm356 is offline
post #55 of 98 (permalink) Old 06-21-2016, 09:40 AM
jim.laite's Avatar
Quoted: 20 Post(s)
I could do without the cracked windshield. I need to add the side window air deflectors.
jim.laite is offline
post #56 of 98 (permalink) Old 06-21-2016, 09:59 AM
Desert Moderator
amaclach's Avatar
It cant drive or wash itself...
amaclach is offline
post #57 of 98 (permalink) Old 06-23-2016, 06:26 PM
norm356's Avatar
Quoted: 520 Post(s)
regarding the lack of a mist wipe, I think I have found an answer for us!
There was an era of Land Cruiser/LX/GX which used our column and our switch, but it also had a headlight cleaner. That switch is exactly like ours in every other respect but with an added button on the end of the stalk (it was used to operate the headlight cleaner on those models).
Plan: buy one of these from a scrap yard, then fit it to my FJ with the following modifications to the body side wire harness connector before plugging it into this new switch: swap the wire from WF to B (same size terminal so that should be easy), and add a ground wire to L.
Later, after I've confirmed this works I'll post a more complete tutorial in the "how to" section, but a quick summary is this: removing the WF wire from the original location eliminates the washer spray when you pull back on the stalk, turning that action into the mist wipe. Moving the WF ("washer, front pump") connector over to the B terminal connects the front washer pump to one side of the new stalk end button and adding the ground wire to L completes the circuit so the washer pump will operate when you push the button.
The result will be very natural: pull back for mist wipe, and press button for spray.
norm356 is offline
post #58 of 98 (permalink) Old 06-24-2016, 10:51 AM
Desert Moderator
amaclach's Avatar
You can't just flip the lever down and up?
Either that or set the intermittent wipe timer as slow as possible & just leave that on?
amaclach is offline
post #59 of 98 (permalink) Old 06-24-2016, 12:50 PM
monflores11's Avatar
Quoted: 229 Post(s)
Rlew0083 previously said: View Post
Wouldn't it be great if they still put the window vents like they used to put on cars? I don't get why they don't do that anymore.
Same minor complain here. But I had the window deflector from WeatherTech installed for a while which reduced that wind but added a new 'version' of noise though. But in general, serves my purpose.
a.k.a. Monching
w/ Lakandula (2014 TTUE)
monflores11 is offline
post #60 of 98 (permalink) Old 06-24-2016, 01:02 PM
Serenity Now's Avatar
Quoted: 439 Post(s)
Yeah the wind in the ear thing is probably my "only" thing...I tried the window vent deflector things, but didn't like how they restricted visibility and what little "open" feel the FJC has.
If any of the rear door windows were operable this wouldn't be an issue.
CalderaJones likes this.
Steve in MN, sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > I'd Like to Tell Toyota...
