What mount is needed to mount Rotopax to the stock roof rack? - Toyota FJ Cruiser Forum
post #1 of 10 (permalink) Old 08-19-2011, 10:28 AM Thread Starter
Hellbound13's Avatar
Quoted: 8 Post(s)
Anyone know? I looked on the Rotopax website but can't find anything..
Hellbound13 is offline
post #2 of 10 (permalink) Old 08-19-2011, 10:48 AM
Get_Lost's Avatar
Quoted: 1 Post(s)
Re: What mount is needed to mount Rotopax to the stock roof rack?
As far as I know there isn't a mount but I could be wrong. I believe that everybody doing this is just securing them with ratchet straps and that 2 of the large Rotopax fit just about perfect up there.
Hopefully someone will come along that has personal experience with it.
Get_Lost is offline
post #3 of 10 (permalink) Old 08-28-2011, 07:55 AM
Wilderness Joe's Avatar
Quoted: 1 Post(s)
The Rotopax system is really versatile. They make mounts, extensions, and a lockable mechanism to secure the cans. It's up to you to decide where and how you want to implement the mounting.
I don't have a proper write up on this mod, but here's some pictures to give you an idea for how to mount the Rotopax cans to your crossbars.
One of the great features about the cans is that you can inter-lock them end to end. I chose not to mount them this way to allow for easier access. I use the red cans for fuel and the white cans for water.
Each lock comes with a key set. Just turn the handle to tighten and secure the can. To remove, turn the key, pull the lock out of the handle then turn to loosen. The can is easily lifted for removal.
Notice there is some deformation of the fuel cans due to pressure and heat. I first noticed this happen when I was in Colorado...I put fuel in the cans in Texas. Several weeks of 100+ F weather may have contributed to the deformation, but to date there's been no leakage. The Rotopax seals very well. At the time the pictures were taken the cans were empty of fuel.
Here you see one can secured to the mount. Above the can is the extension added to allow a second can to be mounted. The handle with a lock comes with the original mount.
And now with no cans. You can now see the mount, the four bolts that are holding the mount to the grill I fashioned, and how I bolted the grill to the crossbars. I painted the bolts, nuts and washers to help them blend in and not be so noticable.
This setup allows the grill to flex a little, but the mount keeps the cans secured to the crossbars. I don't know what advantage this gives, if any, but so far it has worked without failure. I've had this on my FJ continuously since the beginning of July and it's survived a trip to the Summit, trails and daily driving.
I hope this helps and gives you ideas for how you want to mount your Rotopax cans. I bought all my RotoPax accessories from Jacque at TRDparts4U.com. Give them a call...they stock all that I've shown you and more.
Supporter
Anyone, anywhere, any time.
http://www.ouraymountainrescue.com/index.html
Wilderness Joe is offline
post #4 of 10 (permalink) Old 08-28-2011, 07:58 AM Thread Starter
Quoted: 8 Post(s)
Thanks so much for the pics! They helped a lot.
2011 Army Green TTSE. Mods: Boztek CB Mount, Cobra 75W CB with Firestik, Uniden BCT8 mounted on MPAC Saddle Rack, MPAC Cargo Side Rack, MPAC Rear Rack, Husky Liners, Scepter Cans Roof Mounted, Rugged Ridge Headlamp Guards, Body Armor Tail Lamp Guards, Warrior Shovel Mount, Baja Basket, Metal Tech Front Bumper with Bash Plate, Rigid Dually D2 Roof Rack Lights, Ellis Precision Knobs in Stealth Black, ARB Safari Snorkel
post #5 of 10 (permalink) Old 08-28-2011, 10:05 AM
Get_Lost's Avatar
Quoted: 1 Post(s)
Nice! Shows what I know!
Get_Lost is offline
post #6 of 10 (permalink) Old 06-27-2013, 11:39 AM
Libertysand's Avatar
Quoted: 2 Post(s)
Send a message via AIM to Libertysand
Relink?
Libertysand is offline
post #7 of 10 (permalink) Old 06-27-2013, 01:27 PM
elDiablo's Avatar
Quoted: 19 Post(s)
Send a message via AIM to elDiablo Send a message via Skype™ to elDiablo
i didn't want to drill into my cross bars, so i just fabricated a clamp system to hold the mounting plate in place - just needed two pieces, left and right... The large mounting plate isn't absolutely necessary because the separate mounts come with their own circular plates, but its just easier to get them spaced apart just right. mine holds two of the 2 gallon rotopax that clip together.
ID:	77079   Click image for larger version
ID:	77080   Click image for larger version
2012 Trail Teams Edition FJ
elDiablo is offline
post #8 of 10 (permalink) Old 06-27-2013, 01:29 PM
Banned
Quoted: 1039 Post(s)
hellbound, look up Aikidoka`s rotopax mount on the oem rack...
51062 is offline
post #9 of 10 (permalink) Old 06-30-2013, 01:45 PM
K5WRE's Avatar
Quoted: 13 Post(s)
See this post for how I mounted my Rotopax to the OEM roof rack.
https://www.fjcruiserforums.com/forum...ml#post2475494
Used the large Rotopax Universal mount.
It does require you to drill two cross members. I bought two new ones to use when I want the Rotopax on top and use the originals the rest of the time.
There's a little additional info a few posts down from the one listed.
- K5WRE -
(Robert)
While in the Never-ending pursuit of my Dream FJ the following Venders and Manufactures have supplied a helping hand.
Venders:
TRDparts4U, Toyota of Dallas, Pure FJ Cruiser, Elliotís Hardware, West Marine, 4WheelParts, HRO
Manufactures:
ScanGauge, Rigid Industries, Old Man Emu, ARB, Warn, Icon Vehicle Dynamics , Demello Offroad, AMI, Blue Sea, WeatherTech, Oznium, Raw Mind Engineering, Rocktek, Cobra, Firestik, Bandi, Ironman, BudBuilt, Ellis Precision, Rotopax, Hi-Lift, Ricochet Offroad, Yaesu, Diamond, Springtail
K5WRE is offline
post #10 of 10 (permalink) Old 09-19-2019, 02:34 PM
Quoted: 0 Post(s)
I didn't want to drill holes in my OEM crossbars and decided to use 3/4 inch square steel pipe to tighten a universal mount below the crossbars. This has worked well for a couple of months now.
ID:	1093652   Click image for larger version
Steve Dixon is offline
