FJ Cruiser Freedom Windows - Unhappy. - Page 5 - Toyota FJ Cruiser Forum
 43Likes
post #41 of 51 (permalink) Old 06-16-2018, 12:21 PM Thread Starter
kurieren's Avatar
Quoted: 11 Post(s)
Re: FJ Cruiser Freedom Windows - Unhappy.
norm356 previously said: View Post
all you need to do is find a hot rod glass maker and have them make you tempered glass the right shape, using your old glass as the pattern, tint it and be all set
It won't be cheap, but having glass would always be better than plastic in an application like this (scratch resistant, rigid enough to deform the weatherstrip without warping, and made the right shape).
All I read was, "All you have to do is spend an additional X amount of money to get what you paid for initially"
- If I'm here, I probably should be studying instead. -
kurieren is offline
post #42 of 51 (permalink) Old 06-17-2018, 08:03 PM
aeroeng's Avatar
Quoted: 3 Post(s)
Automotive closures engineer here.
It looks like your hinges aren't aligned. I compared your hinge angle with their install video and website photos. I'd check the plexi w/o any hardware attached and put it against the window opening and check for flush. If the plexi looks ok, then It's probably your hinges.
FJNewGuyCO and CRayFJ like this.
aeroeng is offline
post #43 of 51 (permalink) Old 06-26-2018, 06:44 AM
JLerna's Avatar
Quoted: 14 Post(s)
Can someone post a link to the weather stripping? dont't want to buy stuff that wont hold up or is the wrong size..
I have the same exact issues as the OP
2012 FJ Quicksand
JLerna is offline
post #44 of 51 (permalink) Old 07-18-2019, 10:54 PM
bnbsnive's Avatar
Quoted: 2 Post(s)
Iím sorry if this is an ignorant question but could you have a custom glass shop cut holes in the original glass and use that instead of the plexiglass? Once the original glass windows were removed, they could use the plexiglass as a template for the hardware mounting holes and simply transfer the hardware to the glass. Oem fit would be all but guaranteed if that route was possible.
"To me, driving is an art.
The only problem is that my fellow artists are bringing finger paints and crayons to the canvas."
bnbsnive is offline
post #45 of 51 (permalink) Old 07-19-2019, 05:08 AM
norm356's Avatar
Quoted: 510 Post(s)
Unfortunately, tempered glass cannot be drilled after tempering. It is "spring loaded" so that even the tiniest of chips/scratches and it will shatter into tiny cubical pieces.
New glass would have to be cut, drilled, and then tempered.
norm356 is offline
post #46 of 51 (permalink) Old 09-06-2019, 08:24 PM
lucasahall's Avatar
Quoted: 4 Post(s)
I love mine. However, I have lost a couple of the lift pins and need to replace the lift hinges on the window. Anyone know where to get them?
ID:	1092482   Click image for larger version
bazross likes this.
lucasahall is offline
post #47 of 51 (permalink) Old 09-07-2019, 07:46 PM
Tstormin's Avatar
Quoted: 122 Post(s)
Over 5 years with my GEN 1 Freedom windows installed, and not a drop of water has leaked in.
YES They scratch! They are PLASTIC. They follow the scratches that are on my FJ paint leading up to them.
Gen 2 does not have quite the curve that gen 1 had.( I Have found as I lined mine up with other Freedom window owners)
yes, I have run a 2nd strip with weather stripping per Nestah, and have never had an issue.
LOVE THEM, and Recommend them! Will be putting a set in my wifes FJ next spring.
bazross likes this.
2014 Trail Teams Ultimate Edition
With a "Few" mods. See Build
My Build
(Previous 2012 Owner)
Tstormin is offline
post #48 of 51 (permalink) Old 09-07-2019, 08:39 PM
bazross's Avatar
Quoted: 1828 Post(s)
G'Day
ditto to @Tstormin comments.... 5 years and not a drop of water inside, plenty of dog slobber....
I ran a second strip as well, per Nestah's recommendation, on the outer edge of the frame...
Never had an issue with the install or alignment
Cheers
Baz
bazross is online now
post #49 of 51 (permalink) Old 09-07-2019, 09:00 PM
Tstormin's Avatar
Quoted: 122 Post(s)
G'Day
Cheers
Baz
BAZ!!!!! How ya been man?
bazross likes this.
My Build
Tstormin is offline
post #50 of 51 (permalink) Old 09-07-2019, 09:18 PM
bazross's Avatar
Tstormin previously said: View Post
Livin the dream mate .... how's you been ?
Cheers
Baz
