How To: 2011 Oil Change - Page 25 - Toyota FJ Cruiser Forum
 19Likes
post #241 of 249 (permalink) Old 04-10-2017, 07:27 PM
Quoted: 11 Post(s)
Re: How To: 2011 Oil Change
BlindWilly previously said: View Post
If I understand you correctly, the center tube that holds the paper filter must be in there.
I bought the metal housing that fix Lexus and FJ's. I had to swap the center tubes, as there were different sizes.
Worked great!
The TRD filters have their own metal center tube and the cheaper filters do not. You just drop the TRD filter in over the metal center tube on the filter housing.
I've been thinking about buying the metal housing as well, ~$30 on ebay.
RNA554 is offline
post #242 of 249 (permalink) Old 04-11-2017, 11:33 AM
BlindWilly's Avatar
Quoted: 843 Post(s)
This is the one I ordered.
The center piece was shorter than the FJ tube.
I just pulled it out and snapped the one from the stock plastic piece in there.
Now it doesn't feel like I'm going to break it every time I change the oil.
https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
Datajockeys likes this.
Proud owner of "Muddy", my 2013 Quicksand FJ.
http://www.txpedition.com
"No Matter Where You Go, There You Are"
-Buckaroo Bonzai
BlindWilly is offline
post #243 of 249 (permalink) Old 08-15-2017, 04:09 PM
Quoted: 2 Post(s)
"front skid plate. It is held on with four 12 mm bolts" and "the oval shaped metal plate covering the engine oil pan and drain plug. It has two 12 mm bolts" Where can I buy these four 12 mm bolts & two 12 mm bolts? part number? since I literally broken all four bolts..
Ric27 is offline
post #244 of 249 (permalink) Old 08-20-2017, 08:17 PM
Dynamo's Avatar
Quoted: 36 Post(s)
Ric27 previously said: View Post
I believe the part number you are looking for is 90080-11373, and I *think* all 6 are the same. You can get them from any Toyota dealer but have them verify that it is the correct part number.
I order all of my OEM parts from https://parts.autonationtoyotasouthaustin.com/ and just pick them up since they are local.
Dynamo is offline
post #245 of 249 (permalink) Old 08-22-2017, 07:22 PM
Quoted: 12 Post(s)
Local hardware store. M8x1.25 pitch. 25mm length. Just needed to do this myself.
Sent from my iPad using Tapatalk Pro
rockpharmer is online now
post #246 of 249 (permalink) Old 01-23-2018, 07:42 AM
Nick_Kellogg9's Avatar
Quoted: 29 Post(s)
floppyD previously said: View Post
nice writeup
haven't done the 1st oil change on the 2010 yet, but for some reason i thought the oil draining was all done through the plastic nozzle. did not know there was still the pan drain plug. now i hate this cartridge filter setup.
Sorry, I know this is an old thread. But I have to agree 100%. I just did the oil change on my 2013 FJ for the second or third time. And I also did my mom's 2012 Sequoia. They both have the stupid cartridge thing. Well, it's stupid on the bottom. I did an oil change on a 2009 Porsche 911. They use the same cartridge thing, but it's easily accessible via the rear lid for the engine. It's sitting right there, easy to get at, and doesn't leak everywhere. Toyota should take a hint. I also just changed the oil on a mercury outboard, and it had a normal style filter that's screw on/off and it was so much better. I miss those days.
To achieve anything, you must be prepared to dabble on the boundary of disaster.
2013 AT 4x4 Fj, Black, vair compressor.
Nick_Kellogg9 is offline
post #247 of 249 (permalink) Old 08-26-2018, 04:08 PM
Quoted: 38 Post(s)
Wow, just did my first since buying this a little over 9K miles ago. The Mercedes stealership did the last oil change. I needed a Cheater Bar to get the oil filter cap off, the wrench I bought at wally world is a POS that kept slipping off. All Skid plate bolts where freaking over tight as was the drain plug.
I think I know whats happening, the people today, lazy millennials, working on our vehicles now use the cordless impact wrenches for everything. when back in the day we used hand wrenches and had the proper feel for torque values.
fjeffnutah is offline
post #248 of 249 (permalink) Old 08-26-2018, 05:01 PM
formerly 13FJTT
BlueRidgeCruiser's Avatar
Quoted: 145 Post(s)
That's why I do them myself
BlueRidgeCruiser is offline
post #249 of 249 (permalink) Old 04-09-2019, 10:46 AM
Serenity Now's Avatar
Quoted: 422 Post(s)
Just gave my 2010 its 100,000 mile oil change. My, how times have changed. Used to be (back in the olden days ), a motor was usually pretty shot at 100K. Whereas this one still doesn't burn a drop that I can tell in 10,000 miles. Actually, the whole vehicle seems tight and new-ish (other than the new car smell being absent) after 9 years and 100K. Kudos, Toyota.
IDFJ, javylsu and Prius2FJ like this.
Steve in MN, sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
crjdirt
