Brake bleeding sequence for 2010 fj - Page 3 - Toyota FJ Cruiser Forum
Maintenance Tech This forum is for discussion of all aspects of maintenance that should be performed on the FJ Cruiser to keep it operating at maximum efficiency. Advertisement
 4Likes
post #21 of 32 (permalink) Old 06-04-2016, 08:42 AM
Quoted: 145 Post(s)
Re: Brake bleeding sequence for 2010 fj
I installed speed bleeders and they make bleeding brakes a one person job.
WASP in Republic of Texas
2008 Sun Fusion
4x4 6-MT
Supercharged
WASP is offline
post #22 of 32 (permalink) Old 06-04-2016, 07:39 PM
Sanderhawk's Avatar
Quoted: 1006 Post(s)
WASP previously said: View Post
I was thinking of using these but I wasn`t sure if they were good.....guess they are
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #23 of 32 (permalink) Old 06-14-2016, 01:57 PM
Kaiju's Avatar
Quoted: 49 Post(s)
What about performing a vacuum bleeding procedure? Anyone done it that way? If you have, did you have to turn on the key to get it done?
Army Green 2011 FJ. My baby, the green strange beast.
Kaiju is offline
post #24 of 32 (permalink) Old 06-14-2016, 08:47 PM
Sanderhawk's Avatar
I just bled my brakes this last weekend. I had my son pump the brake pedal while I used a 10 mm wrench to open the bleeder valve. Flushed out all the old fluid. Brakes work a lot better now
post #25 of 32 (permalink) Old 06-15-2016, 01:58 PM
Kaiju's Avatar
Quoted: 49 Post(s)
Anyone got anything to comment on about the vacuum bleeding method?
Something I also noticed in my 2011 FJ manual about bleeding the brakes. They said that only when bleeding the rear brakes does the motor come on during the procedure and that the pedal doesn't need to be pumped then, only held down so that the motor will run and push out the old fluid and to not let the motor run for more than 100 seconds at a time. According the the manual, the motor apparently doesn't activate while doing the front set, and they also warn about having to reset any trouble codes that get thrown. Has anyone noticed this while doing their brake bleeding using the 2 person pedal method and have you had any TDC's been thrown?
Kaiju is offline
post #26 of 32 (permalink) Old 06-15-2016, 06:51 PM
Sanderhawk's Avatar
Kaiju previously said: View Post
I`ve never had a code thrown for bleeding the brakes. This is the simplest project in the world to do. It takes a total of 10 minutes to do all 4 brake lines. I think some people over think these procedures. Just do it
post #27 of 32 (permalink) Old 06-15-2016, 07:01 PM
CurbCrawler's Avatar
Quoted: 143 Post(s)
Just bleed the farthest line first and work your way to the shortest, replenish the fluid in the reservoir before it drains it's cavity (there is a cavity for front and rear divided in the single reservoir). This way you wont get air introduced into the circuit, which could be much more difficult to remove. This method is safe and plenty effective and can be done all by your lonesome. You can hang a small 1 quart bottle or so at each caliper as I make my rounds and use clear tubing to fit tightly over the bleeder screw. Place the hose down in the bottle with about an inch of fluid. Open the bleeder and then slowly push the brake pedal down until it stops, let off slowly and repeat. With the hose in the fluid it will not suck air back into the system. Cycle 5 or so times, tighten the bleeder, refill the reservoir and move on. It will take 15 minutes and your done. I generally drain most of each circuits fluid (one front, one rear) on the first cycle, that keeps the new fluid from being contaminated by the old. Alternatively you could pump the fluid from the reservoir, full with fresh and then begin the bleed cycle. The only time you should have to bleed a master cylinder is if you replace it. GL
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
post #28 of 32 (permalink) Old 06-16-2016, 02:14 PM
Kaiju's Avatar
Quoted: 49 Post(s)
Well, that's the way to go it sounds like.
Kaiju is offline
post #29 of 32 (permalink) Old 06-16-2016, 11:29 PM
RomaBoy's Avatar
Quoted: 70 Post(s)
This is what I've used for years making it a one man job.
https://www.amazon.com/Mityvac-MV800...ords=mitty+vac
RomaBoy is offline
post #30 of 32 (permalink) Old 06-17-2016, 11:41 AM
Kaiju's Avatar
Quoted: 49 Post(s)
RomaBoy previously said: View Post
I don't have that unit, just a high quality hand vacuum pump and a large jar with fittings for the hoses. It's worked fine for all my other cars, but only one of them had anti-lock brakes, and it worked great for that car too. I guess if I can't get my spouse slave to pump the brakes when I want to do the job, I'll use my vacuum pump setup. By the way, what do you use the seal the threads on the bleeders so that air won't be pulled in around the threads when they are under a vacuum RomaBoy? I've tried thread tape and really thick silicone grease, but I tend to still get a few bubbles being pulled around the threads during the bleeding process.
Kaiju is offline
