Cleaning after off roading - Page 2 - Toyota FJ Cruiser Forum
post #11 of 19 (permalink) Old 01-27-2013, 05:26 PM
nkybrad's Avatar
Quoted: 5 Post(s)
Re: Cleaning after off roading
If it gets really muddy and sticky I make sure to let it sit for a day and get hard and clunky and then drive it down the street past my neighbors house watching the mud rockets launch from all over onto the road
BRAD
MR. NAUGHTY AVATAR
2007 SUN FUSION
WWW.FORGEOVERLAND.COM
nkybrad is offline
post #12 of 19 (permalink) Old 01-27-2013, 05:38 PM
FJess's Avatar
Quoted: 423 Post(s)
I usually just drive mine through a car wash with the undercarriage sprayer. I've been through some deep water with no breather relocation and haven't noticed water in my fluids. YMMV...
Jessica
2011 Cavalry Blue with some added stuff.
Iconic_ previously said:
Donít be afraid to use your rig! Dents can be popped out, scratches can be buffed out, but in the end the memories you have make it so worth it!
FJess is offline
post #13 of 19 (permalink) Old 01-27-2013, 05:56 PM
mikey's Avatar
Quoted: 1486 Post(s)
Pam cooking spray works great for bugs never tried it for mud.
Place a sprinkler under the FJ overnight it will do a good job of cleaning and rinsing the undercarriage.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #14 of 19 (permalink) Old 01-27-2013, 05:58 PM
willinno's Avatar
Quoted: 97 Post(s)
If it's thick mud (is there really any other kind though?), you'll want to get that out from under your FJ as soon as you can. There are a lot of little nooks under there where it will lodge.
A useful tip someone gave to me is to use a yard sprinkler. Set it up under your truck and turn it on. Let it keep spraying back and forth under the truck. It will loosen up most everything under there. I do it at night. Next morning, get under there with your hose to knock all the loosened mud out. Don't forget your engine compartment.
Black 2010 w/ Offroad & Convenience Packages. TLCA # 21403. Louisiana Land Krewesers. Thanks to Friends for Help!
Icon. Light Racing. All-Pro. Goodyear MT/R. XD-125. BajaRack. Springtail M-PAC. Body Armor. Expedition One. Rugged Ridge. BudBuilt. Richochet. Toy Outfitters. PIAA. Flowmaster. TRD. Demello. Rigid. FourTreks.
willinno is offline
post #15 of 19 (permalink) Old 01-29-2013, 12:40 PM
No-Jeep-Jarrod's Avatar
Quoted: 5 Post(s)
I've pushed mud with my skid plates once or twice. After I get home from the car wash I deburr my rock rails and touch up the flat black as needed, I also grease up the drive train to push any moisture out. I also stick the garden hose in the frame in several locations and give it a good rinse. I also rinse the lower half of the radiators, they get pretty dirty. The reason I even mess with the factory rock rails is because I've cut myself on a burr while working under the FJ.
No-Jeep-Jarrod is offline
post #16 of 19 (permalink) Old 01-29-2013, 12:45 PM
Smalldog's Avatar
Quoted: 647 Post(s)
The best way to clean the underside is a hand held power washer wand hitting it from every angle. None of the automatic washers will do the job well enough. I place the power washer up above my skids as well to
Flush those out. I'm not sure the sprinkler idea hits it hard enough, or gets all the right angles. The power washer is much more powerful. I have salt to deal with here so I go to all lengths to clean the underside from all angles..
Sent from AutoGuide.com App
  • 2007 Voodoo 6MT
  • AllPro Walker Evans lift
  • AllPro Uniball UCAs
  • Allpro Rear Lower Links
  • Allpro Roof Rack
  • LCNW Front Tube Bumper
  • LCNW Rear Tube Bumper
  • Warn 9.5 TI Winch with Syn Line
  • Stealth Custom Series Matte Bronze Wheels
  • 285 70 17 Duratracs
  • URD 6MT Quickshifter
Smalldog is offline
post #17 of 19 (permalink) Old 01-29-2013, 12:57 PM
Joeg180's Avatar
Quoted: 59 Post(s)
I follow the sprinkler method and for the radiator cleaning I use the following:
Thexton 467A High Pressure Air/Water Cleaning Wand | SJDiscounttools.com
Works great for cleaning out the fins of the radiator.
08 Sandstorm, CQ, OF, C7, CF, All Wthr Mats, TG Sliders, Extra Horn, Tundra Handles, Wet Okole Seat Covers, Springtail M-PAC HD Side Rack, Basket, , Stand Alone Fuse Block, IPF 968, LED's under hood, extra 12v outlets, FJTOYMAN's rear shock skids, Scuba Mod, IronMan Front Coils/ToyTec Rear Coils, Bilsteins, ToyTec Swaybar Relo Kit, IMP Shift & Tcase knobs, BudBuilt Skids, Demello/EXp1 Bumpers, 10lb Powertank, Viper Max 12k Winch with Amsteel Synth Line, FrontRunner Slimline II Rack and accessory mounts, LED Spot Lights on rack, SPC LR UCAs, Bandi Body Lift & BMC
KD2HWV
TLCA #19565
GCLC #2128
http://www.fjnortheasters.org
Joeg180 is offline
post #18 of 19 (permalink) Old 01-29-2013, 01:10 PM
Quoted: 250 Post(s)
Send a message via Yahoo to MotioncontrolMike
I know most of you know this, but the primary reason to wash out and off the mud is because it contains moisture(wata). The thicker the mud build up, potentially the more moisture it contains...and you dont want that sitting up in/against and under the FJ. Espescially goes for shoreline dwellers like me...salty air/dirt/sand...can be real enemies to the FJ's undercarriage(obviously)...
If you live in an area where they salt the roads, this should be a routine for you -off-roading or no...
I get the hose out and put on clothes that can get wet and shoot out everything at every angle(mindful of electrical areas). Then I "rinse and repeat" 30 min later...because much dried mud that did not come out on the first wash has softened, and then gets blown out on the second pass. I have seen it!
Mike
MotioncontrolMike is offline
post #19 of 19 (permalink) Old 01-29-2013, 01:26 PM
iwashmycar's Avatar
Quoted: 1145 Post(s)
Send a message via AIM to iwashmycar
Yeah dont forget to stick that garden hose up behind the fender flare plastics. Youll get dirt out of there for a while!
-Adam
'07 Black Diamond 4WD AT UR
TLCA #22985
295s | 3" | BL | Lights | Armor | Rails | Snorkel | CB | Dent(s)
Feb. 2017 Member of the Month
In the Midwest? OHIO FJ Owners
iwashmycar is offline
