I brought mine into the dealership a while back and asked them. One of the guys told me "i can power wash all that dust out of there for you if you want". I asked him about it and he told me it's fine as long as the car is on. I took him at his word and let him.
Cleaned mine this past weekend as it was full of mud. Little bit of diluted simple green sprayed on a warm (not hot!) motor. Used a brush with fairly soft bristles to agitate the dirt in a few places, then used a garden hose with nozzle to spray down the entire engine bay paying attention to the fuse box and electronics so they don't get a direct stream of water. Had to wash it twice since it was so filthy but it worked great and started right up afterwards! Good luck!
For a quick rinse, I use the powerwasher wand at the car wash without holding the trigger down....just the low flow that comes out of the wand without engaging it....
For a deep clean, I do the same with simple green. Just don't spray directly on the plugs, etc. general light spraying :rocker:
Thanks for the tip. Just tried this without activating the pressure. Worked well and I let it dry a bit with the hood open. I'll need a second rinse with cleaner I think though to really get it super clean!
1 more vote for garden hose and simple green. I'd say do it on a cold engine as spraying cold (that ever the hose temp is) water on a hot-ish engine could be really bad for you, seen (or rather heard then seen) it happen a couple times
I use and recommend Black Magic Engine Shine. It is a mild degreaser that leaves plastic looking OEM new. It does NOT leave a fake greasy glossy look like you see at used car lots.
My favorite way is to use some wheel cleaner. I get the kind that is PH balanced so not to harm any finishes. This is especially nice on the underside of the hood. I usually do it at the DIY car wash bays. Then I use the spray soap and go over it, and finally a nice rinse.
Dont go drying it off before starting it....the fan will blow all the water from the shroud back on everything... start it, and possibly go around the block, then come back and towel as much off as you can... will look great!
Mine needs a good cleaning something fierce. I'll see if I can find some of this. I had a math teacher once who liked to say, "life is the pursuit of easiness", among other things. Seems appropriate.
I am a bit surprised no one has said Castrol Super Clean in the Purple jug... I have used this on a ton of things with good results, depending on how dirty,or oily you can dilute with water if needed. I have used it on my snowmobiles full strength and on mountain bikes where you cannot use a powerful water spray with no damage to paint or plastics. I have also cleaned grease spots from carpet,brake dust from wheels and tires... One of my go to cleaner products for most things.
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.6K members
Since 2005
