StopTech true BIG Brake Kit for 400$ (DIY) - Page 36 - Toyota FJ Cruiser Forum
 253Likes
post #351 of 400 (permalink) Old 03-25-2019, 05:20 PM
Iconic_'s Avatar
Quoted: 2617 Post(s)
Re: StopTech true BIG Brake Kit for 400$ (DIY)
ZoSoIV previously said: View Post
What’s tire weight on the 37” compared to the 35”
66 lbs vs 75 lbs for the STT Pro's.
I went from my 34's that weighed 75 lbs tire/wheel to 105 lbs tire/wheel combo.
Iconic_ is online now
post #352 of 400 (permalink) Old 03-25-2019, 06:11 PM
ZoSoIV's Avatar
Quoted: 1135 Post(s)
Yeah that’s a big difference in weight , what about mpg ?
ZoSoIV is offline
post #353 of 400 (permalink) Old 03-25-2019, 06:22 PM
Iconic_'s Avatar
I've only had them on a week, not even a full tank yet. Actually I'm gonna be going back to my 34's for now until I can fit them easier. The weight is definitely noticeable.
cliffy likes this.
post #354 of 400 (permalink) Old 03-25-2019, 09:07 PM
jamesepoop's Avatar
Quoted: 1120 Post(s)
Jus like you, I'd definitely consider an aftermarket caliper after moving to bigger tires when/if it becomes an issue. Stoptech or Wilwood would do quite nicely. Matching performance with the hardware. Who knew we'd be dipping into the 100lb unsprung wheel weight.
jamesepoop is offline
post #355 of 400 (permalink) Old 03-25-2019, 09:30 PM
Iconic_'s Avatar
jamesepoop previously said: View Post
I like the RR racing because they actually pair Wilwoods with OE Centric 5th Gen 4runner rotors, which most of us in this thread already have.
https://www.rr-racing.com/RR-Racing-...gx4fbk0002.htm
post #356 of 400 (permalink) Old 03-25-2019, 09:53 PM
jamesepoop's Avatar
Sweet! Looks like a good option. Let me know how it goes when you upgrade
post #357 of 400 (permalink) Old 03-26-2019, 11:17 AM
ZoSoIV's Avatar
Idk man yeah 37” are probably pushing the limits of an FJ unless you went with a solid axle and a LS v8 swap engine
ZoSoIV is offline
post #358 of 400 (permalink) Old 03-29-2019, 04:39 PM
StHarris's Avatar
Quoted: 6 Post(s)
Send a message via AIM to StHarris Send a message via Yahoo to StHarris
cliffy previously said: View Post
What do the manufacturers do? I can't see them running brand new vehicles up to 40 mph with hard to moderate stops 6-10 times. Still some guys are getting over 100k miles out of originals... using machines???
FWIW: These were the directions (50MPH, hard brake, rinse and repeat 5-6 times) that came with the TRD BBK that was factory installed at the port on my 2012 TTSE.
07 Sun Fusion [Magellan]
12 Radiant Red TTSE [Red Rider]
TLCA # 16633
DO Rocks!
StHarris is offline
post #359 of 400 (permalink) Old 03-29-2019, 07:10 PM
cliffy's Avatar
Quoted: 657 Post(s)
StHarris previously said: View Post
Yea, that's pretty much the same as Centric recommends. I just was pointing out new vehicle brakes seem to last a lot longer even though I don't believe auto manufacturers are taking newborn vehicles through these break in procedures.
Dec 2017 member of the month
cliffy is online now
post #360 of 400 (permalink) Old 04-02-2019, 06:38 AM
StHarris's Avatar
Quoted: 6 Post(s)
I think the reason for that is that Centric/StopTech makes the Rotors for the TRD BBK used on the FJC.
FWIW: Our 2007 FJ (factory brakes) seems to last longer on the brakes than the 2012 TTSE w/the TRD BBK system.
cliffy likes this.
TLCA # 16633
DO Rocks!
StHarris is offline
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
Beagle1
