Cabin Air Filter - Toyota FJ Cruiser Forum
 3Likes
post #1 of 76 (permalink) Old 08-18-2008, 09:31 AM Thread Starter
XeNoN40's Avatar
Quoted: 2 Post(s)
Cabin Air Filter
I don't know what has been said about the cabin air filter, but I thought I'd post a picture of mine. I just took it out and here it is (a picture is worth a thousand words.)
I'm guessing that the leaves are coming from the vents at the bottom of the windshield, if so any suggestions on how to keep the leaves out?
"Don't argue with idiots.......they will drag you down to their level and then beat you with experience!"
Unknown
XeNoN40 is offline
post #2 of 76 (permalink) Old 08-18-2008, 09:36 AM
Gottagetone's Avatar
Quoted: 11 Post(s)
Re: Cabin Air Filter
The only suggestion is to get a big good quality home air filter and cut it down to size. It is much cheaper and filters better that the toilet paper they have stuffed in there. You can also afford to change the filter more often this way. Mine get filthy quick!
“Since you have chosen to elect a man with a timber toe to succeed me, you may all go to hell and I will go to Texas.”
Davy Crocket
My Rig: - well, that was my rig...
TLCA Member # 20540
Gottagetone is offline
post #3 of 76 (permalink) Old 08-18-2008, 09:39 AM
Banned
Quoted: 0 Post(s)
no help on keeping the leaves out.
but I do have this for you:
https://www.fjcruiserforums.com/forum...ghlight=filter
CaliChaos is offline
post #4 of 76 (permalink) Old 08-18-2008, 09:39 AM
tshort1's Avatar
Quoted: 0 Post(s)
I havent really looked for this filter yet Could you all save me some time and tell me where it is located.
tshort1 is offline
post #5 of 76 (permalink) Old 08-18-2008, 10:41 AM Thread Starter
XeNoN40's Avatar
Quoted: 2 Post(s)
I knew I had seen something about using a home filter, so thats what I did.
Unknown
XeNoN40 is offline
post #6 of 76 (permalink) Old 08-18-2008, 10:56 AM
JAXTOY's Avatar
Quoted: 1 Post(s)
Keep the air on recycle mode, it keeps the system from drawing air from outside. I have heard that you do need to draw outside air every once in a while otherwise the system gets moldy. Don't know if this is fact ot fiction.
07 Vodoo Blue M/T 4x4, Sold but not forgotten!!!
JAXTOY is offline
post #7 of 76 (permalink) Old 08-18-2008, 11:00 AM
RoverGGM's Avatar
Quoted: 86 Post(s)
tshort1 previously said: View Post
check behind the glove compartment
RoverGGM is offline
post #8 of 76 (permalink) Old 08-18-2008, 11:03 AM
SoonerFJ's Avatar
Quoted: 0 Post(s)
Gottagetone previously said: View Post
This is exactly what I did with mine. It took about 10 minutes of "labor" and a 4 dollar filter that was cut down to size. I was pretty shocked at the dust, seeds, and bugs that the filter had trapped.
SoonerFJ is offline
post #9 of 76 (permalink) Old 08-18-2008, 11:03 AM Thread Starter
XeNoN40's Avatar
Quoted: 2 Post(s)
It's behind your glove box. there is a little shock (for lack of a better word) on the right side, pop it loose at the top attatchment point and squeez the sides of the glove box together and let it lay all the way down, you'll see a white plastic rectangle cover with an arrow on it, press on the left and right side and it'll slide out.
Unknown
XeNoN40 is offline
post #10 of 76 (permalink) Old 08-18-2008, 11:04 AM
DocME's Avatar
Quoted: 14 Post(s)
JAXTOY previously said: View Post
Just turn off the recirc function a few minutes from turning your vehicle off each time you use your a/c. It will blow out the condenser for you to eliminate the mold smell.
2007 Black Diamond 4x4 Upgrade Package #2
DocME is offline
