frame rust opinions needed - Toyota FJ Cruiser Forum
Maintenance Tech This forum is for discussion of all aspects of maintenance that should be performed on the FJ Cruiser to keep it operating at maximum efficiency. Advertisement
 4Likes
  • 2 Post By Mulie
  • 1 Post By philFJ
  • 1 Post By Mulie
post #1 of 7 (permalink) Old 04-10-2019, 11:40 AM Thread Starter
Quoted: 7 Post(s)
terrible pictures provided by the dealer, especially considering the amount of time and care they put into the professional photos on their listing. i guess if i was a dealer i wouldnt be providing professional shots of rusty underbodies, but anyway here are the pics. this is from the illinois/ohio area, so to me, this isnt too bad. worst area seem to be skid plate and axle cover surface rust. then again the pictures are potato quality and im comparing to my jeeps lol.
ID:	1074972   Click image for larger version
ID:	1074974   Click image for larger version
ID:	1074976   Click image for larger version
ID:	1074978   Click image for larger version
ID:	1074982   Click image for larger version
ID:	1074984   Click image for larger version
ID:	1074986   Click image for larger version
ID:	1074988   Click image for larger version
philFJ is online now
post #2 of 7 (permalink) Old 04-10-2019, 12:01 PM
Mulie's Avatar
Quoted: 41 Post(s)
Re: frame rust opinions needed
Actually it does appear to be fixable from the pics that are shown. I bought my 2010 in 2014. It was a truck from Missouri. It had, I believe, a little more severe problem than the one that you have. It is totally fixable. It will take a week of hard labor to wire wheel, wire brush, sand and treat all of that rust. Remove as much as the rust as you can. Treat with a rust inhibitor and then paint it. I use rust-oleum from lowe's for both paint and rust inhibitor. Make sure you treat the tops of the frame rails and if you can remove the rear bumper and treat back of the frame because you will find the corrosion worst there. At that point you can have it coated with one of the many commercial undercoats available. A second option is instead of doing the undercoating, every spring I crawl under my fj and then treat the rust and repaint those rusty areas. It also gives me the opportunity to do a complete visual inspection while I am down there. When I go on break I will take a pic of my truck's underside so you can see how your FJ could look to. Good luck with your purchase.
jimmy-buffett and Bad Wolf like this.
"You don't need to worry about visibility over the hood....thats why cactus are so tall...just point the truck where the no cactus are and floor it."
-Rick Snell
Mulie is offline
post #3 of 7 (permalink) Old 04-10-2019, 12:05 PM Thread Starter
Quoted: 7 Post(s)
Mulie previously said: View Post
Actually it does not appear to be non fixable from the pics that are shown. I bought my 2010 in 2014. It was a truck from Missouri. It had, I believe, a little more severe problem than the one that you have. It is totally fixable. It will take a week of hard labor to wire wheel, wire brush, sand and treat all of that rust. Remove as much as the rust as you can. Treat with a rust inhibitor and then paint it. I use rust-oleum from lowe's for both paint and rust inhibitor. Make sure you treat the tops of the frame rails and if you can remove the rear bumper and treat back of the frame because you will find the corrosion worst there. At that point you can have it coated with one of the many commercial undercoats available. A second option is instead of doing the undercoating, every spring I crawl under my fj and then treat the rust and repaint those rusty areas. It also gives me the opportunity to do a complete visual inspection while I am down there. When I go on break I will take a pic of my truck's underside so you can see how your FJ could look to. Good luck with your purchase.
cool thanks. sounds like an opportunity for me to offer $500 less.
Mulie likes this.
post #4 of 7 (permalink) Old 04-10-2019, 04:08 PM
Mulie's Avatar
Quoted: 41 Post(s)
Here is the pics that I promised. As you can see I have a few little spots that need to be touched up. That is a project that will be accomplished in 3 weeks. But overall it is pretty rust free.
ID:	1075018   Click image for larger version
ID:	1075020   Click image for larger version
Bad Wolf likes this.
-Rick Snell
Mulie is offline
post #5 of 7 (permalink) Old 04-10-2019, 04:45 PM
Bad Wolf's Avatar
Quoted: 230 Post(s)
I agree with Mulie. It's fixable, but lots of elbow grease required.
Bad Wolf is online now
post #6 of 7 (permalink) Old 04-10-2019, 08:30 PM
Serenity Now's Avatar
Quoted: 370 Post(s)
Or just hit it with Fluid Film once or twice a year. It seals out the oxygen so the rust can't progress any further.
Steve in MN
Sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is online now
post #7 of 7 (permalink) Old 04-10-2019, 08:46 PM
Bad Wolf's Avatar
Quoted: 230 Post(s)
Just a couple tips about spraying undercarriage after prep. Don't paint or get any paint on the cats or muffler unless it's high heat rated. And cover your diff breather etc also.
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
DonWinslow
  Similar Threads
Frame Rust kleibinz Maintenance Tech 8 03-19-2019 01:02 PM
Frame rust.... Is this worth it? Kitzir Dealer Negotiations/Test Driving 2 05-06-2018 08:36 PM
Frame Rust... Revisitied FlyFishNut Misc. Technical Discussion 7 04-26-2017 10:51 AM
Frame Rust Revisited Bostonian1976 General Discussion 46 08-13-2016 07:13 AM
Rust Converters cadcard General Discussion 22 01-05-2014 08:22 PM
