2014 spark plug change. - Toyota FJ Cruiser Forum
post #1 of 1 (permalink) Old 05-06-2019, 01:06 PM Thread Starter
Quoted: 1 Post(s)
Did a lot of searching here for the spark plug change on the 2014 model but came up empty. Lots of spark plug info but no how too. The video I linked is on a 4runner but everything looks the same under the hood as my TTUE. Everything is straight forward with only one word of caution. When separating the air pump from the metal tube make sure you secure the thin metal gasket and don't drop it like I did.
Replaced with Denso oem plugs. Four made in US and two from Japan. The plugs made in the us had a metal puck which looked to have a circular weld around it on the ground strap when viewed through a jewellers loupe. The Japanese plugs looked spot welded and the puck was not as prominent.
https://youtu.be/bS0MZailBdo
Sent from my SM-G928V using Tapatalk
Cull is offline
  Similar Threads
Spark Plug...too tight? Blindman13 Newbie Discussions 8 06-03-2013 12:21 PM
Spark Plug Change aroundawhile Maintenance Tech 3 03-19-2012 05:39 PM
2nd spark plug change. ibdliquidator Maintenance Tech 2 03-12-2012 07:51 PM
MPG drop after spark plug change mafbxh Maintenance Tech 7 08-13-2011 07:22 PM
Please Critique my Spark Plug Change Hemingway Misc. Technical Discussion 64 12-19-2010 09:26 PM
