ROTATE TIRES yourself? Balance & align? - Toyota FJ Cruiser Forum
 10Likes
post #1 of 19 (permalink) Old 08-18-2019, 11:44 AM Thread Starter
eggsandwich's Avatar
Quoted: 9 Post(s)
Lightbulb ROTATE TIRES yourself? Balance & align?
Do you rotate your wheels yourself? or do you get a tire place/dealer to do it...since don't they also BALANCE and ALIGN them? Or is that balance and alignmnt not needed? ...another stealership ruse?
For how to do it I have read many posts here including "Toyota FJ Cruiser Discussion > Wheels and Tires > 5 Tire rotation"...so will use the REARWARD CROSS rotation method when it comes to it.
And for how regularly I understand there's nothing to be lost from rotating as often as every 500 miles but maybe every 1500-2500 miles is a good amount if you want to do it more often than the normal 5000 miles.
Thanks!
Bluto likes this.
eggsandwich is offline
post #2 of 19 (permalink) Old 08-18-2019, 12:15 PM
DubstepPear's Avatar
Quoted: 458 Post(s)
Re: ROTATE TIRES yourself? Balance & align?
I always rotate my tires myself using the 5 tire "rearward cross" shown above. I do it (and an oil change) every 5k miles. In theory you can do it as often as you want as long as the interval is consistent, but I'm a busy college student and I get pretty even wear with 5k intervals. Only time I get the FJ aligned is when I've done some mod that affects it, or if it feels like it needs aligned. The shop I get my tires from does a good job of balancing them from the start, so I've never had to go back and get them re-balanced.
eggsandwich likes this.
NESSIE, 2011 NSSE edition
-DO steel rally bumper
-IronMan FCP coilovers
-OME/MetalTech cheap LT rear
-285/70r17 Cooper STT Pro tires
DubstepPear is offline
post #3 of 19 (permalink) Old 08-18-2019, 12:24 PM
mikey's Avatar
Quoted: 1486 Post(s)
I don't rotate the tires, i drive the FJ for what it is a lumbering SUV not a sports car. In 13 years the tires have worn evenly. IMO checking your tire pressure regularly is paramount to long tire life.
Alignnment - only when i mess around on the front end or if i hit a big pothole or big impact.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #4 of 19 (permalink) Old 08-18-2019, 12:42 PM
Iconic_'s Avatar
Quoted: 2608 Post(s)
No need to do it more often than 5k miles unless you're having problems with wear. Only get it aligned if you have problems with wear also or if you just mounted some new expensive tires it wouldn't hurt.
Serenity Now and eggsandwich like this.
Iconic_ is online now
post #5 of 19 (permalink) Old 08-18-2019, 01:32 PM
NVDojo's Avatar
Quoted: 79 Post(s)
Rotate my own tires using the 5 tire method shown in the diagram. It's easy because you only have to have 1 corner jacked up at a time.
"Not all who wander are lost"
"Eric the Red": 2012 Trail Teams Edition
NVDojo is offline
post #6 of 19 (permalink) Old 08-18-2019, 06:00 PM
Sanderhawk's Avatar
Quoted: 988 Post(s)
I rotate my tires myself. I only do it when I notice the tires starting to feather a bit. About every 5K miles. I only get it aligned if I knock it out offroading or maybe once a year if I just want it checked.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #7 of 19 (permalink) Old 08-18-2019, 06:18 PM
Quoted: 7 Post(s)
When I was a starving college student I used to rotate the tires myself - but now I go to the dealer. They're fast, usually torque the nuts in the 85-90ftlb range, and I don't get dirty. :- )
I go to the dealer to rotate every 8-10K miles and also have the dealer rebalance every 20K (they have a Hunter RoadForce balancer) I've found that my cars and trucks ride a lot smoother at highway speeds if I rebalance every 20K - I'm always amazed at how different the balance weights are (in both weight and rim location) each time.
I only rotate four tires, leaving the spare to live out its life as a (hopefully) un-needed hatch ornament.
Bob Dobbs is offline
post #8 of 19 (permalink) Old 08-19-2019, 07:30 AM
Quoted: 13 Post(s)
i rotate just the 4, myself, every 5k miles. i don't think rotating 5 adds that much mileage and it's less painful only having to buy 4 tires at a time. when i get a new set mounted i swap one out with the spare so i don't end up with a 12 year old spare. i have been running TreadWright M/T's since the truck was new and have gotten 40k on each set. they still had plenty of tread left when i swapped them but they get so damn loud you can't hear yourself fart. i'm on my 3rd set now.
i just bought a quick-jack lift which should make the job a lot easier in the future.
pyrofreek is offline
post #9 of 19 (permalink) Old 08-19-2019, 12:08 PM
Serenity Now's Avatar
Quoted: 423 Post(s)
I used to do it myself, but Discount Tire does it for free so I let them do it.
5,000 mile interval is plenty.
USA4X4 and Thorn661 like this.
Steve in MN, sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
post #10 of 19 (permalink) Old 08-19-2019, 01:07 PM
In.The.Wild's Avatar
Quoted: 6 Post(s)
Every 5k miles I rotate my tires, change my oil, and grease my zerks. I have a 6MT which means my FJ is full time four wheel drive so I only do the four tire rotation. I get an alignment after suspension or steering alterations, or after moving to a noticeably larger tire size, not after a tire rotation.
MODS: RADFLO 2.5" COILOVERS W/ REMOTE RESI'S | RADFLO 2.5" SHOCKS W/ REMOTE RESI'S | RADFLO 3" LIFT SPRINGS | ICON TUBULAR UCA'S W/ DELTA JOINT | METALTECH 4X4 REAR LOWER LINKS | 33" GOODYEAR DURATRAC'S | EXP-1 TRAIL DIAMOND FRONT BUMPER | WARRIOR REAR BUMPER | COME UP 9.5 RSI WINCH | FACTOR55 FLATLINK | BAJA DESIGNS SQUADRON DRIVING LIGHTS | VIAIR 400H COMPRESSOR | PIONEER AVH-W4500NEX | PIONEER 10" SUB | BACK-UP CAM | GZILA GRAB HANDLES | AJT CLIMATE KNOBS & FOB -- MORE TO COME
In.The.Wild is offline
