Crackrock-crawler Build
96K views 253 replies 71 participants last post by  toyotacolin
#1 · (Edited)
Crack rock-crawler Build
Okay I figured I would start my own build thread for Alex's Crack rock Toyeti now that I purchased it, as I'm going to be doing my own things to it and just didn't want to flood his thread and confuse people. So lets start off with what Alex did... Well that's everything right now. So here it is...
The way I got it.
IMG_6407 by Captures by Colin, on Flickr
And the way it looks now.
1154466
IMG_9605 by Colin F, on Flickr
Here is the link to Alex's build thread as well, tons more info there! My addiction- the "crack rock Toyeti"
Also here is a link to my Flickr photography page, TONs of pictures in here. Colin F
NEW UPDATE.
Put on new Demello Rally aluminum bumper, more Baja Designs LEDs, and Level 8 bully pro wheels.
IMG_0491 by Colin F, on Flickr
Current modifications: as of 2-26-21 My changes done in blue.
Suspension/ Steering-
Front-
All Pro +2” Long Travel (UCA/ LCA) (now running, Total Chaos +2 LT pro kit)
2.5” Fox Coilovers w/ external reservoirs (Now running King 2.5")
Timbren Bump stops
All Pro Spindle Gussets
Total Chaos Tower Gussets
Total Chaos Cam Gussets
Currie +2” CrMo Axles (Broke both those so far. LOL)
All Pro HD Steering system (gone)
SS extended brake lines
Rear-
Custom Metal Tech Long Travel
ICON Omega Twin Tube Bypass- Custom lengthened for LT set up
Light Racing Jounce Shocks with custom welded spacers
Metal Tech Long Travel Springs Now replaced with New Apache Dobinsons 3.5" long travel springs.
APACHE OFFROAD 3″ VARIABLE RATE MEDIUM LONG TRAVEL REAR SPRINGS (PAIR) | TOYOTA FJ CRUISER/4RUNNER , LEXUS GX470/GX460 | Apache Offroad
Day Star 1.5" Spring Spacer ---Removed.
Metal Tech 3" Bump Drop spacers
Timbren Bump stops- modified
All Pro HD Upper Links (Control Arms) Now running Resz Fab
Metal Tech Offset Lower Links (Control Arms) Now running Resz Fab
Wheels/ tires/ accessories
17" x 9" Level 8 Bully Pro Wheels from Discount tire
35x12.50x17r Yokohama X-MT
Past-
17” x 8.5” Trail Ready HD Bead Locks with Blue anodized World Series Rock Rings (w/ rock ring spacers)
35” x 12.5” 17R Pitbull Rockers (Tennis ball, golf ball and airsoft pellet balanced)
MTRs, STT pros, Ko3s
Spidertrax 1.25” Spacer- Rear only
ARB Airdown tool
ARB Compressor (See TC / Gearing)
Transfer Case/ Gearing
Marlin "Lefty" with 30 Spline CroMo Output shafts (Front and Rear), 23 Spline Competition 4.7.1 Gears and 4.0 Inchworm Adapter Plate. Installed with Tummy Tuck package- 4" additional break over clearance.
Nitro 4.56.1 Gears (Front and Rear)
8" ARB Air Locker- RD121 for 8" IFS Clamshell
ARB Compressor- Hi-output- CKMA12- 12 Volt w/ 2 Gallon reserve tank- Air lines plumbed to rear bumper with quick connect (also used to activate locker)
Armor/ Exterior
Front Bumper- Demello Aluminum Rally bumper
Rear Bumper- LoD with Tire Swing out- includes Hi-Lift mount, RotoPax mounts and tray
Briareos Bumper Mod
Bud Built 5 piece "Tummy Tuck" skids- PC Hammertone Grey
Bud Built Rear Differential Skid- PC Hammertone Grey
Demello X-Wing Heavy Duty kick out sliders
Rocktec Upper link armor
Outrider Lower link armor
FJToyman Shock armor
Plastic fender removal
Pinch weld "correction" with BFH
BMC
Threadworkz Custom CB antenna Flags (Toyeti & Punisher)
Lighting (changing constantly)
New Headlights! A local friend made me a set of retrofit Bi-Xenon projectors with RGB Halos.
Now I changed out all the Baja Designs lights for Diode Dynamics! Why did I do this? Baja's were great, but only my rich friends could afford them and Diode Dynamics
controls their light patterns better, with better lenses, same made in USA quality, street legal options and they are more then 50% cheaper!
1154459
All my lights are controlled wireless from up to 250 feet away with this NSA Switch Panel This NSA unit is awesome! It makes having all these lights a breeze to turn on and off, check it out for sure!
OLD set up was-
1 Pair- Lightforce Blitz 240’s with yellow/ clear lens covers/diffusers spot/flood combo beam (REMOVED-sold already to a friend)
"1 Pair- Scorpion-LED 109 watt LED (5”)- flood beam-
1 Pair- Rigid Dually D2’s- euro beam-
1 Pair- PIAA LP530- LED lights in rear bumper
I went and replaced everything for Baja Designs!! Which then got replaced by Diode Dynamics
2 pairs of the new bad ass XL-pro 80s in combo beam!!!
1 pair of the Squadron pro in wide cornering on the cowl mounts ( These will shock you! highly recommend)
1 pair of Squadron pro in amber wide corning.
1 pair of Squadron sports used as DRL/ cornering lights
1 pair of S2 pro mounted on rear bumper mounted on teflon washers and aim-able as needed from side light to rear lights.
LA Trail Teams 10- Side Mirror Light Mod- Amber LED
Insanely bright interior leds! Amazon.com: LEMONBEST Pack of 4 New Energy-saving Vehicle White COB LED Dome Light Roof Lamp Car Interior Plate COB LED Light For Lighting In Car Reading Light: Automotive
also used as rock lights.
Recovery
ComeUP 9000 lb wireless winch with synthetic rope.
Warn Industries Winch solenoid shut off w/ remote switch
Custom made Aluminum Fairlead with my logo on it from Greg at GZila Designs
48” Hi-Lift Extreme
Hi-Lift Base
Rocktek Hi-Lift/ Slider adaptor
Bushranger X-Jack (AKA- The Orange Marshmallow) (sold)
ARB Premium Recovery (9000 Snatch block, Snatch strap, Tree saver, Winch extension, Shackles, winch line isolator and gloves)
Wheel chocks
RotoPax 4 x 2 Gallon gas cans
Trail Spare +2” CV (Total Chaos axle)
Additional Shackles
Sound system- 17 speakers
Pioneer AVH- P8400BH head unit
JL Audio XD600/6 600watt x 6 amplifier
JL Audio XD500/3 100watt x 2/ 300watt x 1 amplifier
JL Audio remote level controller
6 x 9" Focal Access 690 CA1 SG's 2-Way Coaxial speakers (Door)
TacoTunes 6 x 9" Speaker door mounts
3 1/2" Infinity Reference 3002CFX 2-Way Coaxial speakers- (Dash)
4" Focal Polyglass 100CVX 2-Way Coaxial speakers (Rear Pods)
4" VersaPod enclosures
3 1/2" Polk Audio DXi350 2-Way Coaxial speakers (Rear Pillar)
10" JL Audio 10TW3 Slimline Sub woofer
SubThump FJ Cruiser subwoofer enclosure
Kicker 4 gauge OFC wire- to amps and ground
100 amp AGU Fuses/ 50 amp MAXI fuses
12 gauge Monster speaker wire throughout- soldered connections
JL Audio power distribution block and Battery mount
Dynomat Xtreme Light- 20 sq ft- front doors
Fat Mat sound insulator- 100 sq/ft- floor/ walls/ remaining doors
Communication/ Audio
Cobra LX 29 Limited Edition -Post- 537
Astatic Noise Cancelling Microphone
4’ Firestik FS4 antenna
Firestik SS Spring
Quik-Disconnect
Bandi Mount
Astatic PDC1 SWR meter -(so you can help others tune their radios)
Wilson 801212 Dual Band Car Cell Phone Booster Antenna
Garmin Nuvi 500- Offroad GPS
Ultra gauge- OBD2 controller/ scanner
Engine/ Electric Other
Stock airfilter (the best to run if you are on dust)
Megan SS catback exhaust- post 309
Dirty Parts Dual Battery Kit w/ Odyssey PC2150 battery and Sears Platinum Battery w/ Lots of booger weldz- post 505
Blue Sea Systems 3000HD battery switch/ single circuit On/Off- 600 amp continuous
Interior
PRP Podium Racing seats SOLD and replaced with Corbeau seats that I could fit into. Now those are sold and I have some awesome SCHEEL-MANN seats out of BakesFJ old FJ.
Metal Tech PRP seat brackets w/ SRS delete switch (sold)
Ellis Precision shifter handle- Stealth Black
Bones- DeadPedal replacement mod
Custom ARB locker/ Compressor switches
DIY- 12 Volt receptacle
SpringTail Side M-Pac Rack with Large MOLLE bag
SpringTail M-Pac- 1st Aid MOLLE Bag
TPMS light- always on (same with compass- hoping thy burn out soon)
Custom Aluminum Dead pedal - Bone Offroad
Interior grab handles- Gzilla Designs custom Captures by Colin logo in aluminum
So not a bad starting point for a rig uh? :wink
2-26-2021 Finally updated the mod list a bit and here is a new picture.
1154460
1154461
4-26-21. After 6 years I finally decided to put on a roof rack! I went with the Sherpa Fuji. The Fuji (2007-2014 FJ Cruiser Roof Rack)
I also put on the Diode Dynamics 42" light bar of course!
1160669
1160668
#33 ·
Its going to replace the springtail molle system he had in the back holding his air tank. I wanted something I could use Molle with and hold stuff.
And thank you, close it was.
Canon EOS 6D
50mm sigma 1.4 art
ƒ/14.0
50.0 mm
1/50
100 iso
#35 ·
#43 ·
#44 ·
This is going to be picture heavy thread I see...:lol::lol:
Glad to see the CRC still rocking :D
#50 ·
I just saw on the FJ Summit page they said when they will be opening up registration in March. So who is going to the Summit this yr? I wasn't able to do black bear last yr, but now I have a rig with ultra low range that will make me feel a bit better when I do go do it. This cracks me up each time I see it.
#157 ·
BLACK BEAR PASS, CO: OFFROAD - YouTube
Holy moly. I didn't know whether to cringe or laugh the whole time. I don't think I could have handled that. :surprise
#51 ·
So I had to take that 240w double row led bar off as it melted the wiring it came with! So I ordered a new 22" bar that will be here next week. In the mean time I threw a 10" that I had laying around to sell for the time being. I also put on some DRLs on, wired them up with the little FJ cowl mounts.
IMG_6503 by Captures by Colin, on Flickr
IMG_6511 by Captures by Colin, on Flickr
IMG_6509 by Captures by Colin, on Flickr
#64 ·
Installed some new LED dome and map lights to the CRC tonight. Man these things are BRIGHT! Crazy bright and awesome!
First picture is my awesome PRP seats that are for sale now! As My new seats will be here tomorrow.
Here you can see the old rear cargo light (with the new front ones on) vs the new LED one next.
Lastly I installed some LED headlights as well.
#65 ·
What kind of seats are you replacing the PRPs with?
#66 ·
I'm going with the Corbeau xrs as they were the only ones that I could actually sit in to try out to make sure they fit my "Fluffy" stature. They still have quite a bit of bolstering but not as bad, plus they recline which will make getting the baby seat in and out a lot easier.
Great snow pics! Looks like you are fully enjoying your new ride. :)
Thanks Jess! I'm really am having fun with this rig, can't wait to get the seats and change up a few more things.
#72 ·
#76 ·
Went and tried to install the seats tonight but Nathan is going to have to fab up a bracket to make it work first. So instead We went out and took pix of his new sweet SCS wheels he put on his 4runner today.
IMG_6643 by Captures by Colin, on Flickr
IMG_6636 by Captures by Colin, on Flickr
