Iconic's Partial To Blue Build - Page 125 - Toyota FJ Cruiser Forum
 2905Likes
post #1241 of 1398 (permalink) Old 09-16-2019, 07:17 PM
Firemedic831's Avatar
Quoted: 588 Post(s)
Re: Iconic's Partial To Blue Build
Have you checked with your old axle that the mounting distances are the same ?
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is offline
post #1242 of 1398 (permalink) Old 09-16-2019, 07:40 PM Thread Starter
Iconic_'s Avatar
Quoted: 2693 Post(s)
Ok it just took some ummmph and I was able to squeeze it back to center. The rear calipers were making some noise somehow against the rotors but I think I "unstuck" them. Just installed new TRD pads also. Not parking brakes, I have them completely torn out still and the cables zip tied to the top of the sliders lol.
Front brake dust shield was rubbing on the rotors, fixed that too. All is quiet again.
ECGS is overnighting me the new longer passenger side brake line and shock mount bushings. Handling right now is terrible since the shocks are loosey goosey on the lower mounts. I didn't ask them to send me a new line and was planning to go to the local autoparts store and cross my fingers they have one in a length close enough but much appreciated from them.
I've asked the mod gods for a much needed break of wrenching as my body is telling me no more but they said a few more days... I'm getting too old for this....
Diff breather installed yesterday:
Still so much left to do, shoulda left it stock.....
Iconic_ is offline
post #1243 of 1398 (permalink) Old 09-16-2019, 07:47 PM
Primer's Avatar
Quoted: 183 Post(s)
"I'm getting too old for this...."
GIVE ME A BREAK!
bazross, FJX2000, debFJVT and 1 others like this.
Alan
- Primer at Imogene Pass 13,114'
2013 TT SE
BMC / Exp-1 Rear Bumper with Swing Arm / PIAA 5190's front, and rear bumpers / King Rear Rem Res W/Ride Cntrl / MT lower links / ICON Front Extended Travel Coil Overs / TC UCA's / SCS F-5 wheels / 285/75R16 Goodyear Duratracs / Shrockworks Front Bumper / Warn 9.5xp / sPOD / Kenwood DNX890HD / Lots of RAAMaudio sound deadening / WickedCAS PODS / Focal PC 165's / Focal IC 690's / Arc Audio Black 10V2 / JL Audio HD900/5 / All Pro HD Sliders and Al IFS Skid Plate / ARB CKMTA12 / Rear SCUBA / Hella Supertones / Dirty Deeds Hi Tuck Tailpipe / FJToymanOffroad Skids / Redline Skids / I seem to have run out of characters...
Primer is offline
post #1244 of 1398 (permalink) Old 09-16-2019, 08:39 PM
bazross's Avatar
Quoted: 1843 Post(s)
Primer previously said: View Post
GIVE ME A BREAK!
OLD MAN DEV !!!!!!!!
bazross is offline
post #1245 of 1398 (permalink) Old 09-17-2019, 05:54 PM Thread Starter
Iconic_'s Avatar
Bought and installed a shorter 9/16" bolt today for the panhard bar. I used alot of grade 8's. Then installed the lower shock mount bushings ECGS overnighted me. The ride has improved. Initial notes are a slightly stiffer ride and less body roll from the MT LT springs and leveled panhard, the rear end has been lifted quite a bit more and the new stance provides even less visibility out the back. The 4.88's are noticeable and the torque take some getting used to from a dead stop. It'll jump pretty good when going from reverse directly to drive. Besides that I haven't even gotten it past 50 mph yet.
The rubber spring isolators are squeezing almost all the way out from under the springs, passenger brake line needs to be replaced with the longer one, upper link mounts need to be ground down and zerks inserted into the upper links. Then airlockers hooked up. Then I start thinking about straps, bumps, and King shocks after cycling it.
Iconic_ is offline
post #1246 of 1398 (permalink) Old 09-17-2019, 07:21 PM
bazross's Avatar
Attachment 1093376
Attachment 1093378
Shaking head.....Butt fugly.... for an old man ..... I should have picked it up ...quicker..... but being an old man, I can't move that fast....
( nor can Lee ) .... hahahahahaha
So when you going 40's ..or 42's ?.....
Cheers
Baz
old
bazross is offline
post #1247 of 1398 (permalink) Old 09-17-2019, 07:59 PM
Quoted: 588 Post(s)
The rear springs should settle a little You went with the HD ones correct? I was looking at some stuff today . and it may work for what i think you are trying to do . Look up BAMF tacoma shock relocation mounts
post #1248 of 1398 (permalink) Old 09-17-2019, 08:25 PM Thread Starter
Iconic_'s Avatar
Cheers
Baz
old
I ain't goin any bigger than 37's and nobody can convince me otherwise!
Firemedic831 previously said: View Post
Yeah the HD's. I'm ok with the ride height increase, if I get the Marlin kit I will jack the front up a little higher also.
I looked at those but feel like the angle is wrong for our FJ's. The Tacoma bed goes directly vertical and has a ton of room. FJ's also don't have room to weld on the top of the frame quite as easily. Plus I think they only work with 2.0" shocks which are fine but not what I ended up with. I bought some tubing for $30 and just need to ask Larry to help me bend it one of these days.
bazross likes this.
Iconic_ is offline
post #1249 of 1398 (permalink) Old 09-17-2019, 08:35 PM Thread Starter
Iconic_'s Avatar
I need a vehicle lift. Hopefully that happens in a few more years and comes complete with a fully equipped garage, welder, tube bender, LED lighting, 10+ acres..........
Hey I can dream!!!! For now, driveway wrenching at its finest.
Also, does anyone want to buy a complete e-locker axle assembly?
bazross and jamesepoop like this.
Iconic_ is offline
post #1250 of 1398 (permalink) Old 09-17-2019, 10:04 PM
HeisKai's Avatar
Quoted: 218 Post(s)
Some serious progress made. Look forward to seeing some flex test with those 14" kings
Iconic_ and jamesepoop like this.
HeisKai is online now
Tags
blue , build , iconic
