Iconic's Partial To Blue Build - Page 132 - Toyota FJ Cruiser Forum
 2905Likes
post #1311 of 1398 (permalink) Old 10-08-2019, 03:31 AM
MOAB SUPERSTAR
debFJVT's Avatar
Quoted: 2256 Post(s)
Re: Iconic's Partial To Blue Build
It did happen to me, but I was also throwing codes. And turns out it was the front actuator, not the switch. But I kept the manual switch on my dash for 4wd anyhow. In your case Id be suspicious of wiring and sensors, not actuator.
Firemedic831 likes this.
Member of the Month November 2016
TLCA# 25170
debFJVT is offline
post #1312 of 1398 (permalink) Old 10-08-2019, 12:05 PM
jamesepoop's Avatar
Quoted: 1161 Post(s)
Have you set your alignment yet? I don't really rub too often. Although i know our track width is several inches off, my contact is really only at the top and back fender well on high speed compression. But it looks like you kept your dust shields. So that may limit some things.
Eventually if I don't have someone do it for me, I'll probably cut/ tub my fenders myself a few inches higher. Maybe something to consider in the future.
jamesepoop is offline
post #1313 of 1398 (permalink) Old 10-08-2019, 12:38 PM Thread Starter
Iconic_'s Avatar
Quoted: 2693 Post(s)
jamesepoop previously said: View Post
Another issue with my FJ. Driver side LCA alignment is seized. Passenger side has a little more room because the shop was able to get positive caster out of it.
Iconic_ is offline
post #1314 of 1398 (permalink) Old 10-08-2019, 07:39 PM Thread Starter
Iconic_'s Avatar
I jumpered the 3 switches on the T-case and still could not achieve 4wd. I tested to see if I have voltage coming in thru the actuator plug and a few pins have 12 volts going to the actuator. I'll loosen the front diff and pull the actuator out tomorrow after draining the fluid. I've reached 500 miles break in, except maybe the front diff since I was never actually in 4WD.
Mason swapped the actuator over while I welded on the motor mount gusset during the front diff regear. We'll see if he sabotaged me since I think its possible to install it off the sliding collar.
Its like one step forward and two steps back.
Iconic_ is offline
post #1315 of 1398 (permalink) Old 10-08-2019, 08:09 PM
Firemedic831's Avatar
Quoted: 588 Post(s)
First he puts the Bolts in wrong on the rear links and now this . This wild man is out of control . While we are on the Subject . do you recall the torxs size socket to get the Pass side axle tube off ? 13 mm going to pull mine this weekend
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is offline
post #1316 of 1398 (permalink) Old 10-08-2019, 08:40 PM Thread Starter
Iconic_'s Avatar
E14 external torx
Iconic_ is offline
post #1317 of 1398 (permalink) Old 10-09-2019, 12:45 PM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3525 Post(s)
Seems like a lot to go through for an extra inch(of clearance). May be worth it to some ladies I've been pondering some of these challenges moving forward with mine. Those LCA cam bolts can be a bear too. I replaced all of mine last year but I probably do about 2 dozen sets per year. Not the funnest job but they pay good.
R.I.P.- Echo
Solitude Allows One to Reflect While Others are Reacting...
It Is Easier To Walk On Hot Coals Then It Is To Walk On Egg Shells...-CC
Member of the month-October 2017
CabinCruiser is offline
post #1318 of 1398 (permalink) Old 10-09-2019, 05:24 PM Thread Starter
Iconic_'s Avatar
Alright I feel stupid. The solution to my lack of 4WD is simple. We forgot to swap over the front diff stub shaft when I regeared. ECGS is sending me one for free. Lets see if I can install it without completely pulling the front diff out again.
toyota-clamshell-stub-shaft-removal.pdf
I just changed the oil in my rear diff. My FJ with 37's and 4.88's pulls harder than it did on stock gears and 34's (as I might expect). I would say I've put it back close to factory, or 33" tire range of acceleration under WOT. Not bad at all.
bazross, Loganbeere and saabturbo like this.
Iconic_ is offline
post #1319 of 1398 (permalink) Old 10-09-2019, 05:36 PM Thread Starter
Iconic_'s Avatar
CabinCruiser previously said: View Post
Yep, it is. I wasn't planning on 37's until I heard Marlin RCLT was rumored. That was a little over a year ago. So yeah, its a big step. I know 35's have gotten alot of people alot of places. But 35's are the minimum for me and what I want to do, that's what I should have got instead of 34's.
Loganbeere and Firemedic831 like this.
Iconic_ is offline
post #1320 of 1398 (permalink) Old 10-09-2019, 05:55 PM
bazross's Avatar
Quoted: 1843 Post(s)
Don't worry.... won't be the last time.....
glad you identified the issue....
good practice !!!!.... hehehe
Cheers
Baz
Iconic_ likes this.
bazross is online now
Tags
blue , build , iconic
