Polishing a shiny turd - Page 29 - Toyota FJ Cruiser Forum
 487Likes
post #281 of 288 (permalink) Old 07-08-2019, 09:25 AM
Loganbeere's Avatar
Quoted: 817 Post(s)
Re: Polishing a shiny turd
jamesepoop previously said: View Post
Do it right or do it over. My wife has been telling me to spend more and do it right the first time. Although I think she's talking about stuff around the house or taxes, I chose to apply it to the FJ
Angle grind, BFH, and got to work. Thought the Warrior Products spare extension mount would do it but I nixed that and knocked out the stock studs and drilled holes for the 1.25" spacer. No sloppy rear door from an extended mount. I can fit 37s no prob, maybe 39s, but we'll leave that for another day...
Genius
2013 Iceberg AT 4x4 | Ghost FJ Build | Instagram
Loganbeere is offline
post #282 of 288 (permalink) Old 07-22-2019, 07:05 AM Thread Starter
jamesepoop's Avatar
Quoted: 1106 Post(s)
(Power Steering) Rush to Ouray
This is one mod I knew I wanted to do for the longest time. In fact, I had a tube and fin style cooler in my pile of parts. After seeing some possibilities with coolers and talking with some race shops (bad ideas), there's a lot of issues running just any old style. You may cause more problems than solve (in my opinion). The fact is, tube and fin have an oil passage to follow thru before the fluid can return (think of a path of least resistance). Plus fluid capacity is still limited to your OEM reservoir and you're using factory recommended Dex-III ATF.
1) Building my kit, I was able to choose the reservoir, lines, and cooler. I decided on a Derale unit for the value, but definitely would consider the Howe inline cooler instead. The design is much more well thought out, being ribbed instead of finned. This may allow you to run it in narrower places.
Both of these style heat sink coolers are single pass in-n-out and are a heat sink relying on pulling out the heat with the aluminum. I relate this to computer heat sinks which are solid chunks of ribbed metal instead of radiator style coolers with small fins that require air to pass through. The air cooling does help but the heat sink is in the larger direct fins.
2) Upping fluid capacity help aids in cooling since you're able to cycle through more fluid. In addition, the several aftermarket options offer an internal or external filter that will help keep your fluid cleaner. I spoke to a race shop and they don't bother with magnet filters like magnefilter. Filter media similar to engine oil filters work best.
The reservoir is heavy duty and huge. Fill up is about twice the capacity of the OE reservoirs. I converted to Swepco 715 power steering fluid[/URL]. There wasn't any really data in researching a new fluid other than finding PS fluid that is high paraffin base and Dexron-compatible if you plan to upgrade your system. Maybe someone could tell me more. I was worried that a non Dexron rated fluid would ruin the seals but I've ran the FJ under heavy conditions and the Swepco fluid under heavy conditions with no funny effects. The only recommendation is to use their flush kit with heavy duty mineral oil and remove all the old ATF that is abrasive. Swepco fluid is built to resist cavitation, anti foaming, aaaaand they run this on desert trophy trucks by some of the best in the industry.
Parts
Derale 13249 kit
Evil racing -6AN kit with 10ft hose and fittings
-10AN 45 or 90 degree fitting
PSC reservoir kit SR-146
1 yd of metal flat bar 1" width 3/16" thickness
1 plate of 3/16" thick 6x6"
M7x25mm x8 bolts/nuts/washers
M6x35mm x4 bolts/nuts/washers
Swepco flush kit (1 gallon flush oil, 3 quarts 715 PS fluid)
Install
1. Lift the vehicle properly with the tires off the ground. You'll have to flush with the Swepco mineral oil flush. It's gallon sized. I did the whole gallon just in case and after the 3rd quart it was showing pretty clear. Pull the smaller hose from the reservoir and plug the reservoir with a 10mm cap. Put the hose into a catch can.
2. Remove the skids plates. Remove the stock reservoir and lines attached to the pump feed and steering rack return nipple.
3. Loosen the rack line brackets to remove the return line and passenger side 19mm subframe bolt. You'll be making two brackets to mount the heat sink. One will run off the middle PS line bolt and the other (offset L bracket) of the subframe bolt. For the Derale ports, I used one -6AN 45 and one -6AN straight port.
4. Mount the new reservoir and measure up the the brackets. I repurposed the previous reservoir bracket. You'll want to bend some Z-shaped brackets to hold the reservoir in a firm position. Vibration is not good for power steering reservoirs.
5. After everything is soft mounted, you can reuse the OEM rubber hose from the steering rack to the heat sink for the low pressure side or return line(straight port). For the out port of the heat sink, measure and cut the return line with the provided -6AN hose with approximately 2.25ft and attach 90 -6AN fitting.
I was able to reuse the OEM feed line from the larger reservoir port with a -10AN fitting to the power steering pump. Test fit the hose and you'll see that it's too long. Cut ~1" off of the rubber hose on the PS pump side and the lines will match up.
Now that all the hoses match and clamps and brackets are tightened, fill with Swepco 715. Turn the steering, lock to lock, with the tires off the ground and let it take in the new fluid. Flush the system with the the extra 3 quarts. Make sure all ports, adapters, and brackets are snug and you're ready to rock!
jamesepoop is offline
post #283 of 288 (permalink) Old 08-02-2019, 07:40 AM Thread Starter
jamesepoop's Avatar
Thankful for friends that can fabricate. @Iconic_ fab prototyped a charcoal canister for our rigs to avoid getting pierced or tagged by any debris. After running the trails, I've already seen the abrasions starting to appear from rocky trails. The stock plastic canister is fairly resilient. Luckily when coming off a huge boulder that looked round, ended up being flat faced on the backside, sliding off it straight and the landing was so hard. I was able to tag as high the rear frame. Get
at @Iconic_ and tell him you want protection!
Install: 30 minutes
10, 12, 13mm sockets
Needle nose pliers
Remove two 12mm bolts on the rear facing and one 12mm up towards the front side.
Remove the two 10mm bolts holding the rear facing bracket. Discard.
Bend tab hook on the front bracket mount in a flat position with needle nose pliers.
Slide skid protector over the charcoal canister. Locate rear holes and screw in 10mm bolts by hand.
Used included 3/4" spacer in between the skid and canister mount hole. Screw in 12mm bolt on the front facing by hand.
Screw two 12mm bolts on rear facing bracket by hand.
Once everything is positioned, final tighten to a snug fit (about 15ftlbs)
Not sure you'll see these in production but they're beefy and worth the added peace of mind. Make sure to reach out to iconic_ and tell him!
ID:	1088154   Click image for larger version
ID:	1088156   Click image for larger version
ID:	1088158   Click image for larger version
ID:	1088160   Click image for larger version
debFJVT, FJFool, Iconic_ and 1 others like this.
Iconic_ previously said:
LEDLIYFJL: Live Every Day Like Its Your FJ's Last
Mad Maxxine Build - 2007 Fresco Silver Metallic
My Travels: http://www.downtownfotos.com
post #284 of 288 (permalink) Old 08-02-2019, 11:37 AM
Iconic_'s Avatar
Quoted: 2559 Post(s)
Good job! I changed my mind, currently looking into getting some more made...
debFJVT and jamesepoop like this.
Iconic_ is offline
post #285 of 288 (permalink) Old 08-02-2019, 01:30 PM Thread Starter
jamesepoop's Avatar
Nice! Thinner gauge sheet this time? This is friggen heavy duty. I hope people realize how easy it mounts up as well. I completed most of it in the sand flats parking lol
post #286 of 288 (permalink) Old 08-02-2019, 03:21 PM
Iconic_'s Avatar
Yep, 12 ga instead of 10 ga and slotted holes to make install easier. Should still be plenty beefy lol.
FJFool likes this.
Iconic_ is offline
post #287 of 288 (permalink) Old 08-02-2019, 05:28 PM
Firemedic831's Avatar
Quoted: 500 Post(s)
Great product
Hannibal, Iconic_ and jamesepoop like this.
09 AT Toytec Boss performance 3inch lift, Demello sliders , TRD brakes , MT offset Lower links . Rad Rubber splash guards ,Cobra CB,
Firemedic831 is offline
post #288 of 288 (permalink) Old 08-17-2019, 09:09 AM Thread Starter
jamesepoop's Avatar
The numbers don't lie. Just recommending oils blindly is a thing of the past. I've switched to Supertech aka Walmart brand. I'll perform 7500 mile oil change intervals confidently. $15.50 for a 5 gallon jug.
One concern that I did have on copper as that's a sign of wear metals but upon some searching, PPM was very low. Not worried about the latter of overheating so levels are looking good.
Per stratson.eu:
"If a different oil brand is used, the different formulation may remove the protective film and form a new film thereby providing a spike in the copper level again. If the engine oil is overheated or overdue for a change, corrosive acids may form that will attack the copper and other metals"
Comments regarding the analysis
JAMES: This oil seemed to work just fine. It's a little hard to compare to last time just because this interval was a lot shorter, and because silicon is a lot lower -- that improvement may account for some of the drop in aluminum and other metals. The viscosity stayed in grade, though again, this was a shorter interval, so
there wasn't as much time for the engine to shear the viscosity. But so far, so good. The silicon thing is a passing issue, aluminum looks better, and the TBN was plenty strong at 2.3. You'd be fine to run this oil longer next time -- you haven't exhausted it yet.
Explanation of the metals: https://www.blackstone-labs.com/serv...-explanation/*
Iconic_ and Loganbeere like this.
