(photo credit rwdunn)
Been building up "RavenFJ" since 2015, and feel like we're finally ready for an attempt at a proper build thread, so here goes...
(click any photo for hi-res)
INITIAL BUILD GOALS
• Daily driver
• Toy hauler (windsurfing/paddling/skiing/etc)
• Occasional off-road/overlanding adventure platform
I've never been a "car guy" (never even used to change my own oil) but I always had a background fascination with rugged 4x4s, and FJs in particular. So when I needed a new vehicle to haul more water toys and such than my AWD BMW 3-series wagon could handle I decided to go with an FJ Cruiser, and to build it up a little to explore where it could take me. And since I'm an engineer (electrical, but pretty mechanically inclined too) – with perhaps slightly beyond a healthy dose of OCD – I decided to do as much of the build-up as possible with my own two hands.
Turned into a little more than I'd initially planned...
________________________________________________________________________________
THE BLANK CANVAS (purchased Feb2015 @~16Kmiles)
2013 Toyota FJ Cruiser, Black, 4x4, 6-speed
• Convenience Package (remote lock, cruise, rear camera, etc)
• Upgrade Package (A-TRAC, rear e-locker, inclinometer, etc)
• nothing else! zero aftermarket mods, certified pre-owned, superb condition
THE WORK IN PROGRESS (as of May2018 @~45Kmiles)
TIRES & SUSPENSION:
• BFG T/A KO2 285/70R17 (33"×11")
• SPC front UCAs*
• ToyTec Boss 2.5" coilovers*
• ToyTec Boss 2.5" rear shocks*
• ToyTec "HD" rear coils*
• Metal-Tech offset rear lower links
• Timbren bump-stops front & rear*
• MOOG greaseable cam bolts*
BUMPERS/ARMOR/WINCH/ETC:
• Demello aluminum bumpers front & rear
• Warn M8000-S winch + "Splicer" thimble
• All-Pro Heavy Duty rock sliders
• BudBuilt steel skid plates (4-piece set)
• BudBuilt stainless rear diff skid
• Icon "shin guard" rear shock protectors
• OPOR "link guard" rear LCA bracket skids
• breather mod for rear diff & e-locker
CARGO MODS:
• semi-custom BajaRack
• full-custom MAXTRAX mounts
• full-custom DIY cargo drawers
• full-custom "2up" rear bike/cargo rack
• full custom "belly stash plate" for RotopaX
• Demello steel hitch receiver
• brake controller + trailer connectors
LIGHTS:
• Rigid SAE LED fog lights & backup lights
• cheapo chinese flood-beam drive lights
• Sylvania SilverStar Ultra headlight bulbs
• switch-controlled DRL-disable + "BLINK" mods to factory lights circuits
ELECTRICAL:
• Odyssey 31M-PC2150ST dual-terminal battery
• full-custom "BatTerm" battery terminal distribution blocks
• full-custom "AuxPower" relaybox / switchbox aux power system
• Anderson PowerPole distribution block & outlets for interior 12V power
• Anker 5-port USB power hub
COMMUNICATIONS:
• Midland MXT115 GMRS radio
• Midland MXTA10 GMRS antenna on NMO mount
• Midland 75-822 CB radio
• FireStik FS-3BK CB antenna at OEM radio antenna location
• antenna diplexer (one antenna for both CB + AM/FM radio)
CREATURE COMFORTS:
• Wet Okole front seat covers
• adhesive fisheye blind spot mirrors
• fresnel lens windshield add-on for traffic light visibility
• custom machined dash device bar w/ magnetic mounts
• custom laser-cut "MAX A/C STOP" plate
*ToyTec/Timbren/MOOG suspension upgrade is a recent addition (May2018) installed by the good folks at the4x4center, replacing some Daystar "budget boost" PU spacers I had added to the stock suspension. Everything else installed (and in many cases designed from the ground up) by yours truly.
CORE USE MODES (versatile "transformer" vehicle)
LOCAL WHEELIN' MODE (armored, and stocked with recovery gear etc, but otherwise stripped to the basics):
(photo credit Mike Hecht)
WINTER MODE (skids off, FluidFilm coated below, and Packasport System115 roofbox up top for skis etc):
OVERLANDING MODE (with James Baroud Explorer Evolution RTT + FoxWing awning):
FULLY-LOADED MODE (with XVENTURE XV-1 trailer):
WATERSPORTS MODE (with custom-machined Yakima cross-bar mounts on the BajaRack):
TLC (fall routine)
Vermont winters are Raven's enemy. Every fall I provide some serious TLC (thorough deep-clean, wire-wheel off any visible rust, rattle-can paint touch-up, thorough Fluid-Film professional application) in an effort to keep rust at bay.
