Return frm Body Shop... Not the Same, Loss of power? Electrical? - Page 2 - Toyota FJ Cruiser Forum
 3Likes
post #11 of 20 (permalink) Old 01-19-2017, 07:25 AM
I Have a V-8!! Moderator
BIGGUY's Avatar
Quoted: 7039 Post(s)
Re: Return frm Body Shop... Not the Same, Loss of power? Electrical?
Good to hear that you found someone that can fix it for you.
Go ahead, skin it! Skin that smoke wagon and see what happens...
I'll ride in on a sunny day, Sing you a song, steal your heart away Like a cowboy Hang my hat like I'm here for awhile Kick off my boots and drive you wild Like a cowboy Well baby you know I can't stay long You wake up, I'll be gone Until then I'll hold on Like a cowboy.
TLCA #9031
BIGGUY is online now
post #12 of 20 (permalink) Old 01-19-2017, 10:43 AM
Quoted: 9 Post(s)
glad to hear you found it. My first guess was they crushed exhaust off roading.
boom boom is offline
post #13 of 20 (permalink) Old 01-22-2017, 04:38 PM Thread Starter
Quoted: 2 Post(s)
Oh no! I was super worried someone joy rode it! I'm going to look under it!
FJ.Candice is offline
post #14 of 20 (permalink) Old 01-31-2017, 05:44 AM Thread Starter
Quoted: 2 Post(s)
Stalling... Could it be electrical?
I purchased my 07 Manual in September with 106k miles. No known issues.
My friend backed into the fender in the beginning of December, starting the saga from HELL.
The power distribution box had to be replaced, approx., 300 miles after this repair (which I drove in under 18 hours from the repair, through a blizzard), and two jumpstarts...
It stalled in motion, while I was attempting to turn left. 3/4 tank fuel.
It would not restart, eventually I was able to keep it running to get it out of the intersection.
Battery cable was loose.
It was towed back to where repair was done.
Technician informs me they are getting a fuel vac lock code?
Ideas? What is the common mileage for fuel pump failure? Are there early symptoms? Could this be a computer glitch caused by battery cable? I might add that PDB failure scorched the mainline...
post #15 of 20 (permalink) Old 01-31-2017, 05:52 AM
Joabmc's Avatar
Quoted: 594 Post(s)
A rear end collision can be enough to prematurely end the life of a fuel pump. I'm not sure there are early symptoms though. I've had a few fail over the years on different vehicles and usually they work until they don't if that makes sense.
Joabmc is offline
post #16 of 20 (permalink) Old 01-31-2017, 05:22 PM Thread Starter
Quoted: 2 Post(s)
The damage was a small dent to the drivers side fender.
post #17 of 20 (permalink) Old 01-31-2017, 05:28 PM
Joabmc's Avatar
Quoted: 594 Post(s)
FJ.Candice previously said: View Post
Scratch my thought then.
Joabmc is offline
post #18 of 20 (permalink) Old 01-31-2017, 07:17 PM
Quoted: 1365 Post(s)
" ... and the Master guy, over at Don Joseph Toyota in Kent, OH over the phone explained that somehow there is backflow coming from the power distribution box."
Hard to say, maybe the Master guy thought he had to "dumb it down" when trying to explain an electrical problem to a chick, but if he thinks there is "backflow" going on, then he's clueless as to what is actually going on in the circuit.
FJtest is offline
post #19 of 20 (permalink) Old 02-01-2017, 05:15 AM Thread Starter
Quoted: 2 Post(s)
The dumbing down explanations are really frustrating. This whole thing is really frustrating. Additionally, I had a guy pass off my insistence of this ongoing electrical issue that started post repair... as "well, did it occur to you that you purchased a used vehicle?"
Venting now: Yes, I am aware, but it's not a rag, I wanted this specific car, which I drove for 90 days without any issue before you took apart my front , lost my key and fried my electronics.
Yes, they can explain things to me with big words, If I have a question I will ask.
Does anyone here have experience with electrical issues?
The power distribution box was replaced, why wouldn't that be the logical place to start? And why won't these people give me the actual code, instead of making stuff up. Uggh.
post #20 of 20 (permalink) Old 02-01-2017, 10:16 AM
CurbCrawler's Avatar
Quoted: 143 Post(s)
1. My first guess would be a bad ground from battery to chassis. On the fender between the battery and fuse box, there is major chassis ground for a portion of the electrical system. I thought there was one wire coming from the negative side of the battery, but 2 or more coming from the wire harness where they meet & connect at the fender. I would guess that fuse box and or interior use that ground wire for a multitude of relays and or instrumentation, could even be charging circuit and/or ECU?
2. Second guess would be as others have mentioned, fuse box wiring or connections/connectors for various circuits.
GL
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
