High idle after cleaning throttle body - Toyota FJ Cruiser Forum
post #1 of 13 (permalink) Old 03-01-2019, 06:09 PM Thread Starter
Quoted: 3 Post(s)
So I cleaned my throttle body manually open the butterfly and got the common high idle after. Before cleaning park RPMs were at 900 after cleaning park RPMs were at 1100.Drive RPMs were at 550 to 600 and post cleaning there are at minimum of 850. So I drove it for a week and a half with a zero change to the RPMs. Since I didn’t see any improvement I took it to a Toyota dealership where they told me I needed a new throttlebody I just happened to purchase a throttlebody before I took it in because I found for a good deal and just had a hunch that I might need a new one. So they installed the new throttlebody for me and the RPMs did not change. I have checked for vacuum leaks using starter fluid and found nothing I also cleaned the MAF sensor. The dealership told me that since the RPMs were between 700 and 900 that those are what Toyotas stock idle should be and that they couldn’t find an issue regarding high idle. The only reason the RPMs concern me is because the car seems to not shift right anymore so I’m wondering if anyone else has had this issue or anyone has insight on what the issue could be. The FJ has no codes and no check engine lights. Is a 2007 FJ cruiser six-cylinder automatic.
Brandon_ggg is offline
post #2 of 13 (permalink) Old 03-01-2019, 06:36 PM
Datajockeys's Avatar
Quoted: 198 Post(s)
Re: High idle after cleaning throttle body
Check to see if AC is on.
Sent from my iPad using Tapatalk
Army Green 2011 NSSE (Option Package 3) w/ Tribal Graphics
Datajockeys is offline
post #3 of 13 (permalink) Old 03-01-2019, 06:47 PM
Quoted: 243 Post(s)
Send a message via Yahoo to MotioncontrolMike
Mine idled high too after a throttle body cleaning and it took a few uses and starts to bring it back. Hopefully you didn’t affect the butterfly mechanism adversely?
Mike
MotioncontrolMike is offline
post #4 of 13 (permalink) Old 03-01-2019, 07:14 PM Thread Starter
Quoted: 3 Post(s)
Ac is off
post #5 of 13 (permalink) Old 03-01-2019, 08:32 PM
mikey's Avatar
Quoted: 1446 Post(s)
Mine did the same thing after cleaning, it took some time for it to get back to normal.
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #6 of 13 (permalink) Old 03-01-2019, 08:45 PM
Quoted: 13 Post(s)
Did you disconnect the battery?
i_m_2_sane is offline
post #7 of 13 (permalink) Old 03-01-2019, 08:57 PM Thread Starter
Quoted: 3 Post(s)
Yes i did
post #8 of 13 (permalink) Old 03-01-2019, 09:01 PM Thread Starter
Quoted: 3 Post(s)
i_m_2_sane previously said: View Post
Yes i did.
post #9 of 13 (permalink) Old 03-01-2019, 09:02 PM Thread Starter
Quoted: 3 Post(s)
How long?
post #10 of 13 (permalink) Old 03-01-2019, 09:02 PM Thread Starter
Quoted: 3 Post(s)
Datajockeys previously said: View Post
Ac is off
  Similar Threads
Throttle Body Cleaning w/Pics Gottagetone Maintenance Tech 53 06-18-2017 06:45 PM
The facts on high octane mooncruiser Engine Performance 23 07-09-2008 02:45 PM
Scan Gauge II Briman42487 Stereo / Electronics / Electrical 29 05-29-2008 04:22 PM
Throttle response mikey Engine Performance 12 03-04-2008 07:48 PM
