Replacing the fuel pump - Toyota FJ Cruiser Forum
 3Likes
  • 2 Post By FJC-MAN
  • 1 Post By FJC-MAN
post #1 of 3 (permalink) Old 05-29-2019, 08:39 PM Thread Starter
FJC-MAN's Avatar
Quoted: 4 Post(s)
I just completed this task yesterday and Iíd like to pass on a couple of pointers. If your like most of us, you donít have a lift in your garage. You have to jack it up high enough to get the large HF jack stands under the rear axle pretty extended. Because once you have the tank on the floor, you have to slide it out from under the frame. So, unless your plan is to replace the whole pump / sump / fuel gauge sender assembly ( expensive ) here is my important tip about disassembling the unit to replace just the pump. Where the pressurized gas is coming out of the top of the pump there is a O-RING! If you buy a OEM pump it probably wonít come with this o-ring. I ended up re-using the old one which worked fine. Slip the o-ring onto the plastic post in the sump before pushing the pump in the housing. I rest my rant.
HERSOG and Lee44 like this.
FJC-MAN is offline
post #2 of 3 (permalink) Old 05-29-2019, 09:31 PM Thread Starter
FJC-MAN's Avatar
Quoted: 4 Post(s)
Re: Replacing the fuel pump
Hereís a pic of where o-ring seated when installed. Also a pic of the oem pump with attached filter screen.
ID:	1081042   Click image for larger version
HERSOG likes this.
FJC-MAN is offline
post #3 of 3 (permalink) Old 05-30-2019, 09:24 AM
HERSOG's Avatar
Quoted: 364 Post(s)
Thanks for the write-up and great info.
ďThere is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter.Ē
2010 TT 6MT. 4.56+ARB locker, Icon Coil Over Shocks+FOX 2.5 Rear+Icon UCA. All pro HD steering Kit. Metal Tech tube bumper with Caterpillar GTB 9000 Winch. Light Force Striker 170 HID. K&N cooled Air Intake. Ricochet Skid Plate. All-Pro Rear LCA. ARB Half Rack. Boztech Diff skid 285/75/16 Goodyear MTR, Edelbrock Exhaust. URD Short Shifter. Total Chaos LCA Skids.
And Death Valley Is The Place To Be
HERSOG is offline
