2019 FJ Summit: Fuel consumption log. CA > CO & back - Toyota FJ Cruiser Forum
 12Likes
post #1 of 14 (permalink) Old 07-27-2019, 09:12 PM Thread Starter
Quoted: 1337 Post(s)
Finally had a chance to review all my fuel receipts for the Summit trip from So. California, with some interesting observations.
Vehicle is 2014 FJC with 2 medium-size adults + 1 medium-size dog, hard-shell RTT, aluminum armor + steel sliders and a full compliment of camping gear. Weighed the rig in Cortez, CO and was slightly shocked to see the curb weight was 5,540 lbs with a full fuel tank & 5 gallons of water. This is only 30 lbs under max GVWR. Tires are 265-75R16, "E" range BFG KO2s kept at 45 PSI for highway use. Air conditioning was on for 90+% of the entire trip, which typically reduces efficiency by 1 - 1.5 MPG. Cruise control was usually set at 70 MPH.
Total distance traveled was 2,355 miles, average fuel consumption for the entire trip was 19.11 MPG, with a total of ~122 gallons burned. Best mileage was 24.12 on the downhill run from Flagstaff AZ to Newberry Springs, CA where I got 339 miles out of the tank and the reserve light wasn't on yet.
Average MPG was 20.66 on the highway, and 15.56 on the trail runs, some of which included a fair amount of highway driving (Ouray to Telluride, etc.).
The only things I did to enhance fuel economy was to turn off cruise control as we approached grades to avoid screaming 4K RPM downshifts into third, and occasionally turned the AC off for short periods on the steeper grades. Given that much of the trail running was in low range, 1st and 2nd gear, with less than 10 MPG showing on Torque Pro, the overall fuel economy seems pretty good for a 5,500+ pound brick.
Name:	FJ Summit 2019 fuel consumption log.JPG
FJtest is online now
post #2 of 14 (permalink) Old 07-28-2019, 08:44 AM
DubstepPear's Avatar
Quoted: 458 Post(s)
Re: 2019 FJ Summit: Fuel consumption log. CA > CO & back
FJtest previously said: View Post
Vehicle is 2014 FJC with 2 medium-size adults + 1 medium-size dog, hard-shell RTT, aluminum armor + steel sliders and a full compliment of camping gear. Weighed the rig in Cortez, CO and was slightly shocked to see the curb weight was 5,540 lbs with a full fuel tank & 5 gallons of water. This is only 30 lbs under max GVWR. Tires are 265-75R16, "E" range BFG KO2s kept at 45 PSI for highway use. Air conditioning was on for 90+% of the entire trip, which typically reduces efficiency by 1 - 1.5 MPG. Cruise control way usually set at 70 MPH.
Thanks for sharing!
NESSIE, 2011 NSSE edition
-DO steel rally bumper
-IronMan FCP coilovers
-OME/MetalTech cheap LT rear
-285/70r17 Cooper STT Pro tires
DubstepPear is online now
post #3 of 14 (permalink) Old 07-28-2019, 09:46 AM
Sanderhawk's Avatar
Quoted: 977 Post(s)
Yeah mine doesn`t get near that good of mpg. I`m pretty sure i`m between 13-15 and i`m totally cool with that. Didn`t buy it for the mpg
MotioncontrolMike likes this.
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is online now
post #4 of 14 (permalink) Old 07-28-2019, 10:53 AM
Mean Time Moderator
ZerosFJ's Avatar
Quoted: 1396 Post(s)
Good info thanks for sharing
2014- FJC Cement "Eddystone" US spec personal import - mods in progress https://www.fjcruiserforums.com/foru...eddystone.html
ZerosFJ is offline
post #5 of 14 (permalink) Old 08-07-2019, 06:18 AM
wallace55's Avatar
Quoted: 3 Post(s)
That's pretty darn good, you should be happy with that, I've never seen anything over 18.5
wallace55 is offline
post #6 of 14 (permalink) Old 08-07-2019, 08:25 AM
mikey's Avatar
Quoted: 1463 Post(s)
Fuel grade?
Were you at 45psi to compensate for the additional load?
"It's not easy being Green"
Kermit the Frog
mikey is offline
post #7 of 14 (permalink) Old 08-07-2019, 09:23 AM
Serenity Now's Avatar
Quoted: 417 Post(s)
I'm surprised you can get 19 mpg with a RTT on...usually that is at least a 2 mpg hit.
Steve in MN
Sponsored by Blue Sun Corporation
2010 FJ, now with exciting grill and shifter knob mods
"Speed has never killed anyone. Suddenly becoming stationary, that's what gets you." - Jeremy Clarkson
Serenity Now is offline
post #8 of 14 (permalink) Old 08-07-2019, 04:04 PM
Quoted: 249 Post(s)
Send a message via Yahoo to MotioncontrolMike
Gotta love those AZ gas prices. SoCal is fully taken advantage of...
Mike
MotioncontrolMike is offline
post #9 of 14 (permalink) Old 08-08-2019, 01:22 PM Thread Starter
Fuel grade?
Oops, forgot to include fuel grade. I normally run Regular, but for this trip I used Mid-Grade exclusively, as much of the trip was at ambient temperatures of well over 100F.
The 45 PSI is my normal "on-road" tire pressure, primarily for reduced rolling resistance (fuel economy).
I was shocked at the 5,540 curb weight. This was the first time I ever weighted the vehicle, and it was definitely less heavily loaded than it was for the '17 Summit.
post #10 of 14 (permalink) Old 08-08-2019, 01:24 PM Thread Starter
Serenity Now previously said: View Post
It's a hard-shell Maggiolina, mounted as low to the roof as possible, so it's pretty streamlined, but obviously it does increase the total frontal area substantially.
The highway-only fuel consumption was 20.66 MPG, the 19.11 MPG was for the entire trip, including the off-road sections.
When the truck was brand new, W/O any mods or even a roof rack, it occasionally got 23+ MPG on the flat at 65 MPH, but that was during the 5K mile break-in and it was being driven pretty conservatively.
