Do most of you run E-rated (10 ply) tires when upgrading from stock? - Toyota FJ Cruiser Forum
 13Likes
post #1 of 34 (permalink) Old 02-04-2015, 03:34 PM Thread Starter
Reptile Christ's Avatar
Quoted: 27 Post(s)
Seems that the majority of people go with a 285/70r17 or 275/70r17, most of which are E rated tires (also known as 10 ply).
My newbie questions:
- Is the norm around here to go with E-rated tires?
- Is there any added benefit when wheeling to have an E-rated tire?
- Any other pertinent info I should be aware of when looking at the load range?
Thank you
Reptile Christ is offline
post #2 of 34 (permalink) Old 02-04-2015, 03:40 PM
NW FJC's Avatar
Quoted: 310 Post(s)
Re: Do most of you run E-rated (10 ply) tires when upgrading from stock?
E rated tires have a little extra support in the sidewall when aired down...
And, 16" tires are a good bit less expensive fwiw...
NW FJC is offline
post #3 of 34 (permalink) Old 02-04-2015, 04:07 PM
thane's Avatar
Quoted: 277 Post(s)
I have ran both E and D and LT tires and for the FJ I favor D sidewalls which typically let you run higher pressure for the same contact patch as an E side wall.
On trails I typically run 20 PSI and in sand 14 PSI.
With E sidewalls you have to run the pressure lower to net the same effect sometimes lower than 8 PSI in sand which takes you closer to losing the bead seal.
Airing back up is faster and road comfort is much improved with D.
If you want your ride to feel more truck like and you plan on destroying your tires get E sidewalls.
thane is offline
post #4 of 34 (permalink) Old 02-04-2015, 08:17 PM Thread Starter
Quoted: 27 Post(s)
thane previously said: View Post
Thank you for the input. My FJ is a daily driver who will see lots of Colorado's trails on the weekends, nothing too crazy though! Sounds like D rating might best suit my needs.
post #5 of 34 (permalink) Old 02-04-2015, 08:22 PM
Muvovr's Avatar
Quoted: 948 Post(s)
Reptile Christ previously said: View Post
My experience with this forum is that NO it is NOT the norm....
Heavy wheelers run them for a reason... But as a "Norm" no.
I have NEVER run E rated tires on any of my FJ's or Jeeps.
ArupFJ likes this.
2014 Build.
Silver Roof, Pro Comp Lift 3", TRD Wheels, Cooper A/T3 285x70x16, TT Black Out Parts, ARB Touring Rack, Baja Ladder, Bushwacker Fenders, Rigid Upper & Lower Grille w/ SR 6" LED's & D2 LED's, Front Grille Guard, Rigid SR-M Rear LED's, ANZO Headlights & Turn Signals, M-PAC Side Rack, Ellis Precision, TTUE Skid Plate, Rocktek Rear Bumper, PRG Snorkel
..........................____
...............______//__{\___
............./__(0)_//__/_(0)_/
My Post may not be disseminated, without the express written consent of myself or a doppelgšnger with a worse attitude then my own.
Muvovr is offline
post #6 of 34 (permalink) Old 02-04-2015, 08:54 PM
dwm2112's Avatar
Quoted: 214 Post(s)
I run the E's for the additional protection and strength gained in the sidewalls already mentioned. Not sure what the "norm" really is but I do see many running the E's.
fidelityflip likes this.
2012 FJ Cruiser, Silver Fresco Metallic, Convenience and Upgrade packages, Roof Rack, and Towing package, Toytec Boss 3" lift, Light Racing UCA, BMC, Warn Front and Rear Bumpers, Warn Zeon 10-s Winch, Factor 55 Flatlink and Winch Lock, OEM Rock Rails, MB 352 16 X 8.5 -6 offset Wheels, 305/70-16 Goodyear DuraTracs, PIAA 520 Series Driving Lights, Baja Rack Insert, Hi-Lift extreme, DeMello roof rack mounts, Scuba Mod, RCI Front, Transmission, Transfer Case, and Lower Control Arm Skids, Red Line Land Cruiser Lower Link Skids, Ellis Precision Shifter Knobs, Heated Seats, Boztec CB mount, 3' Firestik, Midland 75-822 CB Radio, Garmin Nuvi 500 GPS, hood decal blackout, 10 lb. CO2 PowerTank
dwm2112 is offline
post #7 of 34 (permalink) Old 02-04-2015, 08:56 PM
Bar3K's Avatar
Quoted: 1853 Post(s)
I run Es.
I don't like the stiffer but I like the stronger sidewall.
Depending on how much weight you carry on the trails should be a factor on your decision also. When you load your FJ for camping, head for the mountains, and air down, load range E gives you some piece of mind.
BlindWilly and fidelityflip like this.
Bar3K is offline
post #8 of 34 (permalink) Old 02-04-2015, 09:26 PM
KS13TT's Avatar
Quoted: 126 Post(s)
Bar3K previously said: View Post
I run Es.
This.
"The fear of death follows from the fear of life. A man who lives fully is prepared to die at any time." Mark Twain
2013 Trail Team: ICON LT Lift / ICON tubular UCA's / MetalTech rear offset LCA's / Duratrac 285/75R16 / Demello Hybrid Sliders / Industrial Forming Panamint Console Roll Top / Scangauge2 / Springtail/MPAC / FJNEWB SCUBA DRIVER Mod / lzalusky's Washer Reservoir Relocation Kit (Shrockworks) / Demello Aluminum Rally Bumper / LED lights - the cheap ones
KS13TT is offline
post #9 of 34 (permalink) Old 02-04-2015, 10:10 PM
sweptwingnut's Avatar
Quoted: 248 Post(s)
E rated. Love them.
My Build Thread - The Boontoolies
sweptwingnut is offline
post #10 of 34 (permalink) Old 02-04-2015, 10:24 PM
Moab Junky's Avatar
Quoted: 831 Post(s)
E rated are tougher, but you got to pay to play. They will cost you significantly more at the pump. I ran Toyo E's on my Jeep. I swear I could run them flat and not lose a bead. I pulled them off and switched to a C rated cooper. The HP gain was astounding.
For me, E's for the Super duty, 3 ply sidewall C's or D's for the FJ or other 6 cylinder rides.
Moab Junky is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
