2007 FJ > 200,000 miles - $11.6K - should I? - Toyota FJ Cruiser Forum
 4Likes
post #1 of 14 (permalink) Old 09-06-2016, 02:07 PM Thread Starter
simbob's Avatar
Quoted: 2 Post(s)
I've been looking for a low cost FJ - seems like an oxymoron :-) So, I've found a 2007 FJ with MT, 4X4, A-TRAC with just over 200,000 miles for $11,600. So, I'm wondering if I'd just be buying something that's at the end of its life. I don't want to have to continually dump large quantities of cash into it to keep it alive. And I need the truck to be reliable enough to pull a MC trailer (2000 lbs total weight) on trips (500-1500 miles each way). This truck has a very good history of oil changes every 5000 miles, so it obviously seemed to be owned by someone who cared a bit. But, there are a lot of things that can go wrong. I plan to go test drive it later today. Anyone have any thoughts, like things to look/listen for, or expected longevity of a well-maintained FJ? Thanks!
simbob is offline
post #2 of 14 (permalink) Old 09-06-2016, 02:37 PM
Iconic_'s Avatar
Quoted: 2648 Post(s)
Re: 2007 FJ > 200,000 miles - $11.6K - should I?
Man, when I read this thread title my response was going to be: Do it as long as you don't drive long distances. But adding a trailer even tougher.
My parents have a sequoia with 190k on it. It still feels very solid and it a towed our camper on many trips.
If it must be a 200k mile vehicle, what better to do it in than a Toyota?
Papa Dragon and citislicker like this.
Iconic_ is online now
post #3 of 14 (permalink) Old 09-06-2016, 04:06 PM
Bar3K's Avatar
Quoted: 1868 Post(s)
Your going to spend some money on it. Depends on what is still original.
Only a handful on here with over 200K
Bar3K is offline
post #4 of 14 (permalink) Old 09-06-2016, 04:12 PM
CurbCrawler's Avatar
Quoted: 143 Post(s)
Perfect for a build to the max project
The reason why we retain memories is because we are not caught in a time loop. The reason why we are not caught in a time loop is because it is not possible to go backwards in time only forward!
*CurbCrawler fabricated hidden front receiver.
*CurbCrawler fabricated Hi-Lift receiver mount.
*CurbCrawler fabricated SS dual battery tray & Walmart Battery.
*CurbCrawler fabricated 4-Gauge dash pod.
*CurbCrawler fabricated Aux fuse/relay panel.
Gibson cat-back exhaust (Dyno Proven)
Complete set of aluminum skid plates.
Receiver mounted 9k-lb rear winch.
Hayden trans cooler w/electric fan.
Factory rock rails.
Moon roof.
LED fog & backup lights.
Husky mats: front, center & rear.
CurbCrawler is offline
post #5 of 14 (permalink) Old 09-06-2016, 04:27 PM
hydro556's Avatar
Quoted: 110 Post(s)
If maintained properly, and you can do a thorough inspection, offer him 10k or so.
I prefer an auto, but the manual transmission is a big plus. No auto to worry about rebuilding.
If the frame looks good, and there aren't rust issues, it could be a good buy and easily go another 200k.
citislicker likes this.
hydro556 is offline
post #6 of 14 (permalink) Old 09-06-2016, 07:19 PM
Sanderhawk's Avatar
Quoted: 999 Post(s)
The FJ for fun 200K would be ok. Constant long trips with a trailer I would buy something with less miles JMO
Steve.... 07 FJ with almost enough mods.... August 2017 Member of the month
Sanderhawk is offline
post #7 of 14 (permalink) Old 09-06-2016, 08:54 PM Thread Starter
simbob's Avatar
Quoted: 2 Post(s)
Thanks for all the replies. I drove the FJ today, and it seemed really tight. No rust anywhere (Memphis is a good climate for that). Underneath looked really clean - must have spent it's life on the highway, as there is no rust on the suspension as a sand-blasted truck would have. Only things I noticed were:
  1. Clutch engages near the top of the pedal travel - might this be an indication of clutch wear, or is this normal?
  2. There is a whine in the drivetrain. Stops with the clutch disengaged at speed, so not the tires or parts that keep rotating. Expected, or possible issue?
Bob
2014 TTUE MT w/TRD Quickshifter
simbob is offline
post #8 of 14 (permalink) Old 09-06-2016, 10:19 PM
Bar3K's Avatar
https://www.fjcruiserforums.com/forum...st-repair.html
Search for throw out bearing on your noise
Bar3K is offline
post #9 of 14 (permalink) Old 09-06-2016, 10:26 PM
Voight Kampff's Avatar
Quoted: 1238 Post(s)
Buy it.
200K - it's just getting warmed up.
What size tires will fit on my FJ?
The owner's manual for your FJ is right here. <--- This is a link. Many answers to your questions are contained within.
See the relationship between highway speed and MPG here.
TLCA 5301
Voight Kampff is offline
post #10 of 14 (permalink) Old 09-07-2016, 11:26 AM
cwheeler's Avatar
Quoted: 68 Post(s)
My Fj has 226k miles. Just freshened up the suspension. No squeaks, no rattles. Transmission is smooth as butter.... Rear end does whine a bite. And I have replaced alternator twice. Otherwise it has been great. You should make sure to change the trans fluid and install a cooler.
cwheeler is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
