Door Panels Rattle with Stereo (2013 - Page 2 - Toyota FJ Cruiser Forum
 35Likes
post #11 of 20 (permalink) Old 12-14-2016, 09:05 PM Thread Starter
kevinrfoote's Avatar
Quoted: 86 Post(s)
Re: Door Panels Rattle with Stereo (2013
kevinrfoote previously said: View Post
I'm sure this is a common topic. As a newbie, would love to get links to:
1) common solutions
2) directions on removing either the painted panel piece (that rattles) or the door panel as a whole
This is on my 2013 TT that I picked up a few weeks ago. . I imagine just some tightening and maybe cotton or I insulating material will solve this simple, yet extremely annoying, problem.
I'd hate to scratch something or break a fastener.
Ok. All of you rock. Even though not "rocking out" with my stereo is the best option.
I hate the stereo. My '08 had the premium with the subwoofer - this tricked out Trail Teams has the cheapie. After adding other doodads and saving up some cash, I'll think about the stereo. In the meantime, double sided tape, feminine napkins, and/or rattle tape is the best track.
I just live in fear of snapping some fasteners!
bazross likes this.
Kevin | Eagle County, CO
#2 2013 Trails Team Edition | Concrete with Custom Black Top | ARB Front Bumper with Smitty Winch | Toytec Adjustable Lift with Heavy Duty Springs; Bilstein 5100 extended travel in rear | Bed line on Plastic Components | BPRM cat back exhaust
#1 2008 Sunburst Yellow | Manual AWD | Super Charger | Other goodies | RIP after accident: FJ vs Elk Herd and guard rail
kevinrfoote is offline
post #12 of 20 (permalink) Old 12-14-2016, 09:20 PM
bazross's Avatar
Quoted: 1828 Post(s)
G'day Kev,
The fasteners on the door panels are pretty rough.
I have not managed to snap any of mine yet, and had the panels off several times..
The thing to watch for with the panels is to correctly reattach the door handle mechanism ..there are two cables, one for the lock, and one for the door latch, get wrong way round and you wont be able to open the door, but they are colour coded from memory... and ensure the cables are seated fully.
the other tricky part is the connector behind the panel itself. Its a multi pin connector and can be tricky to un clip, its sort of a push pull connector ... and until you release it the panel will just hang itself. Helps if you have a second pair of hands ..but can be done solo ( with a few expletives thrown in for good measure )
good luck,
cheers
Baz
kevinrfoote likes this.
bazross is offline
post #13 of 20 (permalink) Old 12-15-2016, 06:35 AM
Irving Zisman's Avatar
Quoted: 510 Post(s)
Absolutely what bazross said! Make sure you document which of the 2 door cables go where. Do what I did not do and take a picture of it while it is still attached to that back of the door handle. I got them put on in the wrong order and it was no having to redo all that work I had just done. If I remember correctly, the door will not open from inside and I had to use my alarm remote to unlock the door before I could open it from outside.
"Those who cannot remember the past are condemned to repeat it." - George Santayana
"Any society that would give up a little liberty to gain a little security will deserve neither and lose both" - Benjamin Franklin
"You have enemies? Good. That means you stood up for something sometime in your life." - Napoleon
"Quotes found on the internet are rarely correct." - George Washington
Irving Zisman is online now
post #14 of 20 (permalink) Old 12-15-2016, 07:19 AM
FatJohnson's Avatar
Quoted: 880 Post(s)
I also put them in backwards once and almost went into a panic attack because the door handles will no longer open the door, and I was in the driver's seat. With the door closed you can no longer remove the panel to fix the error. I figured out that the door key turns into a door handle, which you can use to open the door.
WebSnyper and kevinrfoote like this.
FatJohnson is offline
post #15 of 20 (permalink) Old 12-15-2016, 10:35 AM
norm356's Avatar
Quoted: 507 Post(s)
The good thing about the plastic clips (and the little "manhole cover" for the screw) is they are cheap, and readily available from local Toyota or internet. Often (if I am planning ahead), before I tackle an interior job is buy a couple of extras before starting.
But, as Bazros said, they hold up well.
Regarding sound deadening behind the doors: be sure that anything applied to the outer panels is not water absorbing (=rust). Someone mentioned feminine napkins, make sure something like that is only used in a permanently dry area.
One thing that can be really handy when curing rattle noises is felt tape (available at most hardware stores, in the crafts section) because you can stick it to the mating face between two plastic parts (colored plastic door inset panels anyone?) and prevent them from rattling together.
Tap your fingers on each panel before disassembly to find out which ones are making noise, then felt away while they are apart.
N
norm356 is offline
post #16 of 20 (permalink) Old 12-15-2016, 02:35 PM
FoxtrotJuliet's Avatar
Quoted: 83 Post(s)
The sound dampening advice - while good, will not solve the rattle (I had on my 2013 TT) - see post #11 in this link:
https://www.fjcruiserforums.com/forum...el-rattle.html
This solved it.
FoxtrotJuliet is offline
post #17 of 20 (permalink) Old 12-15-2016, 04:34 PM
smoking_rubber's Avatar
Quoted: 394 Post(s)
The talented gentlemen at the stereo store did mine. I've taken the door panel off myself (to paint the mirror and replace the handles) and I would say it's been pretty easy. I've got a LOUD stereo and my doors don't rattle at all. Jump in the water's fine.
Irving Zisman and kevinrfoote like this.
2013 Toyota FJ Cruiser - Black
AT 4x4 w/ CRAWL. Kenwood eXcelon HU w/German Maestro Sound "Life is a beach"
"I spent a lot of my money on booze, birds and fast cars - the rest I just squandered." George Best
smoking_rubber is offline
post #18 of 20 (permalink) Old 12-15-2016, 07:22 PM
FatJohnson's Avatar
Quoted: 880 Post(s)
Door panel removal takes about 5 minutes, just don't forget to take the 2 screws out before you start reefing on it. Use a bench under the door to hold the panel while disconnecting the switches and actuator rods to make it an easy one-person job.
post #19 of 20 (permalink) Old 12-16-2016, 03:41 PM
WebSnyper's Avatar
Quoted: 192 Post(s)
A set of these helps as well when removing panels...
5 Piece Auto Trim and Molding Tool Set
And are often even cheaper than this in store. I think I got mine for like $6
2007 Titanium FJ Cruiser
WebSnyper is offline
post #20 of 20 (permalink) Old 01-24-2017, 06:44 PM Thread Starter
Quoted: 86 Post(s)
WebSnyper previously said: View Post
Just ordered some, thx!
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
