Question on a 2007 - Toyota FJ Cruiser Forum
post #1 of 3 (permalink) Old 01-30-2017, 01:40 PM Thread Starter
Quoted: 1 Post(s)
Question on a 2007
I'm looking at a 2007 4x4 with 126K miles. The test drive seemed fine, however afterward I popped the hood & checked the oil. The dip stick shaft has a good rubber seal inside the dip stick tube. When the seal broke as I extracted the dip stick, there was a noticeable release of pressure? The salesman said this was normal, but I've never experienced that on any other engine. Normal? Why would pressure build up in the lower end unless there was a ring problem or something else? I'd appreciate any comments from experienced owners.
jmun is offline
post #2 of 3 (permalink) Old 01-30-2017, 03:04 PM
Quoted: 63 Post(s)
Re: Question on a 2007
jmun previously said: View Post
I have the same thing after I drive for a little bit after the engine is cold like when I change the oil, most likely just expanded air. I have a 2008 with 100K on er and she runs perfectly so I don't suspect a problem
SandyTime is offline
post #3 of 3 (permalink) Old 01-30-2017, 04:00 PM
トヨダ Master
CabinCruiser's Avatar
Quoted: 3455 Post(s)
I was thinking PCV valve. I never check my oil because it doesn't use or leak any but she's low mileage.
R.I.P.- Echo
Solitude Allows One to Reflect While Others are Reacting...
It Is Easier To Walk On Hot Coals Then It Is To Walk On Egg Shells...-CC
Member of the month-October 2017
CabinCruiser is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
