Installing OEM roof rack. Help - Page 2 - Toyota FJ Cruiser Forum
 7Likes
post #11 of 17 (permalink) Old 06-21-2019, 08:51 AM
OffRoadAssault's Avatar
Quoted: 1 Post(s)
Re: Installing OEM roof rack. Help
Can you share the link of where you bought the kit for your OEM roof rack?
OffRoadAssault is offline
post #12 of 17 (permalink) Old 06-21-2019, 09:05 AM
A-Team Moderator
Hannibal's Avatar
Quoted: 2614 Post(s)
@OffRoadAssault Are you talking to me or ?
https://www.fjcruiserforums.com/foru...an-toyota.html
oderint dum metuant
トヨタ
Hannibal is offline
post #13 of 17 (permalink) Old 06-21-2019, 09:34 AM
Roman@Toyota's Avatar
Quoted: 8 Post(s)
Here's a link to the hardware kit for the roof rack:
https://parts.toyotaofcoolsprings.co...t-pt27835130hw
It includes the following:
Quantity - Description
12 - Screw, M8x43mm, Wafer Head
12 - Fiber Washers
12 - Foam Washers
1 - Operator Caution Card
8 - Thumb Wheel Assembly
4 - Clamp Assembly RH
4 - Clamp Assembly LH
4 - Screw M5x1.81x16, T25
Let me know if I can help with anything!
-Roman
parts.toyotaofcoolsprings.com
post #14 of 17 (permalink) Old 06-21-2019, 10:04 AM
A-Team Moderator
Hannibal's Avatar
@[email protected] , can you get the spools?
oderint dum metuant
トヨタ
Hannibal is offline
post #15 of 17 (permalink) Old 06-21-2019, 10:35 AM
Quoted: 8 Post(s)
Hannibal previously said: View Post
I dug around, but it doesn't appear that Toyota has a listing for the spools.
Hannibal likes this.
-Roman
post #16 of 17 (permalink) Old 06-21-2019, 11:55 AM
Quoted: 1341 Post(s)
I think the 'spools' are integral parts of the roof rack, and may not be available individually.
Since you already have a few, you could take one to a local machine shop and have them make some duplicates using 300 series stainless steel.
Or, see if anyone on the forum has a damaged and valueless roof rack that could donate a few.
FJtest is offline
post #17 of 17 (permalink) Old 06-21-2019, 12:48 PM
Quoted: 0 Post(s)
Congrats on the new rack - I think the worst element of the FJ is the stock rack, but won't get into that. I installed a Baja flat rack and am loving it. However, had some serious headaches when removing and installing because of the bolt-clips below the roof and under the headliner.
Basically, the Baja rack provided only bolts and stanchions, but no spacers, fiber washers, or anything to cover the access to the bolt holes through the roof. I installed mine with the original FJ clips found under the original rack stanchions, though there is no instruction to do so. Simply adding silicone sealant to the thread holes won't waterproof the system as there are gaps where water can get in through the roof. I ended up gunking up the works with silicone and hoping for the best. So far, no problem, but I have a very low confidence that this fix will last. I'm just going to keep an eye no things to see if there are any leaks. I'm more concerned that leaks will find their way past the roof into the body, without being evident on the headliner. Hopefully that won't happen.
I purchased my 2012 used and the previous owner did sound proofing/reducing under the headliner and elsewhere. This resulted in gumming up the threads on the clips, ultimately causing me to have to remove the headliner after the metal clip slipped and made it impossible to take the bolts out. I also stripped several of the factory bolts in the process, also necessitating the removal headliner to access the bolt clips. Several bolts had to be drilled out to remove them. I don't think an original installation would have had as much of a problem. It looked to me that spray paint had made it onto some of the bolts, thus creating an unusual problem.
So glad to be rid of the original FJ rack. Now can walk on the roof if I need to, sleep up there, and have a thousand attachment points. Expensive, but worth it.
frisboy901 is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
