Installing OEM roof rack. Help - Toyota FJ Cruiser Forum
 7Likes
post #1 of 17 (permalink) Old 06-14-2019, 08:48 AM Thread Starter
Quoted: 5 Post(s)
I finally got a OEM roof rack and was planning on installing this weekend. I ordered the OEM install kit with all the bolts and washers.
I was curious if I should put a sealant under the feet or around the bolts to ensure I dont get a roof leak. If so what kind and where should i put the sealant under the feet , around the bolts or both?
Thank you everyone for your help
Fjgonzo is offline
post #2 of 17 (permalink) Old 06-14-2019, 08:52 AM
Bad Wolf's Avatar
Quoted: 315 Post(s)
Re: Installing OEM roof rack. Help
Not sure about placement but I have read people sometimes use marine sealant .
Bad Wolf is offline
post #3 of 17 (permalink) Old 06-14-2019, 09:27 AM Thread Starter
Quoted: 5 Post(s)
Thank you that's what I found also but most are a adhesive / sealant I just want to make sure I use the right one in case I remove the rack later
Fjgonzo is offline
post #4 of 17 (permalink) Old 06-14-2019, 01:28 PM
Quoted: 1325 Post(s)
Do NOT use any supplementary "sealant", use the flat-gasket seals provided with the install kit and you'll be fine.
Many people slather the bolt threads with RTV silicone or other sealants, not realizing that the waterproof seal is NOT made AT the bolt threads, but outboard of the threads, at the ends of the metal "spools", which are the spacers between the roof surface and the underside of the rack "feet".
Use the Toyota mastic and fiber-washer seals, apply and position them correctly, and make sure that the sealing surfaces on the roof and the spools are clean, dry, flat and undamaged.
Make sure you have a copy of the factory installation instructions:
http://www.lastgreatroadtrip.com/wp-...stallation.pdf
Hannibal, Bad Wolf and FJFool like this.
FJtest is offline
post #5 of 17 (permalink) Old 06-14-2019, 05:33 PM Thread Starter
Quoted: 5 Post(s)
Thank you so much, I will be giving it a go tomorrow, weather permitting
Fjgonzo is offline
post #6 of 17 (permalink) Old 06-15-2019, 06:24 AM Thread Starter
Quoted: 5 Post(s)
Just unpacked my roof rack and it seems that it is missing 5 of the metal sleeves/ inserts that the bolts go through? Please tell me these are available separately ? I have not been able to find a part number
Fjgonzo is offline
post #7 of 17 (permalink) Old 06-15-2019, 06:55 PM Thread Starter
Quoted: 5 Post(s)
Here are pics of what I'm looking for hopefully a part number or if anyone has some
ID:	1082758   Click image for larger version
Fjgonzo is offline
post #8 of 17 (permalink) Old 06-15-2019, 07:11 PM
A-Team Moderator
Hannibal's Avatar
Quoted: 2591 Post(s)
"spools", so that's what they're called.
I thought you meant the plastic tube inserts that the bolt passes through.
Name:	bracket, roof rack under headliner.jpg
WebSnyper likes this.
トヨタ
Hannibal is offline
post #9 of 17 (permalink) Old 06-16-2019, 07:21 AM Thread Starter
Quoted: 5 Post(s)
Thanks to everyone trying to help. I just need 3 more feet / spools. This community is great
Hannibal likes this.
Fjgonzo is offline
post #10 of 17 (permalink) Old 06-20-2019, 10:31 PM
olongapo2's Avatar
Quoted: 51 Post(s)
Several of my friends added aftermarket roof racks and experienced water damage on their interior headliner. They corrected the problem by removing the rack then re-installing it with a generous amount of silicone sealant. I presume it depends on the brand of rack being installed.
FJFool likes this.
olongapo2 is offline
  Toyota FJ Cruiser Forum > Newbie Town > Newbie Discussions
