water leaking from exhaust pipe!!! - Toyota FJ Cruiser Forum
Off-Topic Discussion This area is for discussion of off-topic related items. This area can be viewed by everyone so please keep it clean.
 3841Likes
Closed Thread
post #1 of 9568 (permalink) Old 02-07-2014, 07:55 PM Thread Starter
Banned
Quoted: 1039 Post(s)
hellllp! I see water leaking from somewhere along the exhaust system when I first fire up the truck in the morning!!!
will my SS exhaust systems rust out?
will this water cause any corrosion or rust if it drips on any other metal part of the frame???
Man I`m really nervous and worried that this will break my FJ
helllllp!!!
I mean with the wheel shake, the drive shaft thud, the vibrating shifter and NOW this, it`s time to trade it in and be done with this headache of a rig!
and before you ask, NO I`m not carrying to much weight on my stock suspension!!! and I need every bit of BS I have on my rig and rack!
51062 is offline
post #2 of 9568 (permalink) Old 02-07-2014, 08:03 PM
Cooter2's Avatar
Quoted: 47 Post(s)
Re: water leaking from exhaust pipe!!!
You forgot about the seatbelt tensioner recall...
Cooter2 is offline
post #3 of 9568 (permalink) Old 02-07-2014, 08:04 PM Thread Starter
Banned
Cooter2 previously said: View Post
dagummit
51062 is offline
post #4 of 9568 (permalink) Old 02-07-2014, 08:07 PM
Quoted: 87 Post(s)
pretty sure that's just normal condensate if it's cold out...
my wheel shake disappeared completely when I switched tires
mikeeslick likes this.
hiflyerx is offline
post #5 of 9568 (permalink) Old 02-07-2014, 08:12 PM
Dynamo's Avatar
Quoted: 36 Post(s)
Is this a serious thread or a parody thread?
If serious then it's nothing more than condensation from a cold exhaust and it's normal. It's why they always say to not make short trips without letting the engine come up to operating temperature. If you don't then the condensation will stay in your exhaust and engine where it will cause rust, etc.
Dynamo is offline
post #6 of 9568 (permalink) Old 02-07-2014, 08:21 PM
Quoted: 671 Post(s)
PR, this is from not purging the exhaust correctly in a cold climate, up here just after shutting down the vehicle you need to place your lips over the tail pipe and just blow, this removes the left over moisture from the Catalytic converters.
WaJohnZ is offline
post #7 of 9568 (permalink) Old 02-07-2014, 08:26 PM
Vapor Locked
lqdchkn's Avatar
Quoted: 1854 Post(s)
Dynamo previously said: View Post
Seriously.
What gives PR? I would think you should know enough to know that but you didn't post this in Off Topic so I'm not sure what to think here
2016 Brownstone Duramax Z71Chevy Colorado View My Colorado Build
2012 Quicksand SOLD View My Build
N00bs click here for free help
lqdchkn is offline
post #8 of 9568 (permalink) Old 02-07-2014, 08:28 PM
FJ Moose's Avatar
Quoted: 1572 Post(s)
I can't help the short trips, work is only 2 miles from home.
I thought I have seen that in summer time too on vehicles, I always thought it was the catalytic converter doing its job.
Water is a normal byproduct of the catalytic converter changing CO to CO2 and water.
So expect your pipes to rust regardless past the cat.
Lead additives (to boost HP) can kill your cats. Also, separation of Ethanol from the gasoline can produce water in the gas tank, which can kill your cats.
2013 Quicksand
Mikey previously said: "You guys are like built in forum spam........"
"Everything is easy after you figure out how to do it" -- Moose
"Memphis Beer & BBQ":
https://www.fjcruiserforums.com/forum...er-bbq-28.html
"FJ Flirt":
https://www.fjcruiserforums.com/forum...-fj-flirt.html
"Limb Risers":
https://www.fjcruiserforums.com/forum...flector-3.html
"2013 Quicksand and Bronze Wheels":
https://www.fjcruiserforums.com/forum...ml#post2357199
FJ Moose is offline
post #9 of 9568 (permalink) Old 02-07-2014, 08:29 PM Thread Starter
Banned
lqdchkn previously said: View Post
Seriously.
of course I know better, ooops,mods move to off topic please... hahahahaha
come on, don`t you know me by now...
51062 is offline
post #10 of 9568 (permalink) Old 02-07-2014, 08:29 PM
FJ Moose's Avatar
What was the cause of the vibrating shifter? is that the drive gears or the transfer case shifter?
2013 Quicksand
"FJ Flirt":
"Limb Risers":
FJ Moose is offline
Closed Thread
  Toyota FJ Cruiser Forum > Off-Topic Area > Off-Topic Discussion
51062, BIGGUY, BIOHZRD, Old Cruiser, Soup, WaJohnZ
