My shuddering transmission story - Page 10 - Toyota FJ Cruiser Forum
post #91 of 97 (permalink) Old 08-31-2011, 06:42 AM
jimmiee's Avatar
Quoted: 145 Post(s)
Re: My shuddering transmission story
Transmission or torque converter shudder is often miss diagnosed. An engine misfire can feel like a torque converter shudder. Also an engine miss can't be felt until the torque converter locks up. To tell the difference between an engine miss and a lock-up shudder you need a scan tool like the Toyota factory scanner or an aftermarket scanner like a Snap-On Modis or Solus Pro.
Here's how to diagnose the shudder. First look for any misfire codes. If you have misfire codes the odds are the shudder is an engine problem. If there are no codes in memory next check for any pending codes.
Look at the Long Term Fuel Trim. The long term trim should be close to ZERO. If the trim is over +7 or under -6 you have an engine problem for sure.
Finally drive the truck and get it shuddering. While it's shuddering watch the short term fuel trim along with the downstream O2 sensors. If it's really a Torque Converter Shudder the ST fuel trim and the O2 sensors will remain stable. If it's an engine misfire the ST trim will go negative and the O2 sensor will show the changes.
*All the work on this truck was done by me!*
<NO SNORKEL> _OME Lift -LR UCAs - DeMello FB - 12K# Winch - Hi Lift -Warn RB - TRD muff - Cobra CB / Bandi - A-Trk, Diff Lock, VSC, Chime Hacks - BMC -305-70-16 MTR's & Raceline Renegade's - Wolo - Hi Lift - Tube Grill - Ellis Shift Knbs - Silver Star H4s- Clazzio Leather - Blue Sea Panel - Optima Yellow - Kenwood DNX6980 - Oznium LED- Prodigy BC - SCUBA -Window Tint - Springtail Racks - Tru Cool 4454 - VIAIR Sys -AP Sliders-Ricochet HD Skids - BozTec Diff Skid - ToyTec LCAs & Panhard - Front ARB - 4:56 Gears - Smitty CO2 Cyl - AIRAID CAI - Baja Rack - Lowrance Baja
https://www.facebook.com/jim.eberhart
TCLA Member 4407
jimmiee is offline
post #92 of 97 (permalink) Old 09-15-2011, 07:09 AM
tailwaters's Avatar
Quoted: 0 Post(s)
Well at 103,000 miles I too now have the low speed shudder. I experience mine at low speed and light acceleration between 20-25mph. What I have noticed is I experience it pretty consistently with the air conditioner on and its spur attic without the air on. Also like everyone else it’s only in D/OD. If I drop it into 4 it goes away. I took it to the dealer and after 4 hours the only thing they could come up with was possible u-joints at the cost of about $500. I told them to hold off as I’ve never heard of a set of u-joints making a shudder at 20-25mph. So I decided to take it to another shop and they confirmed my thoughts the u-joints looked fine. So from there I went to discount and had them re-balance my all the tires. Did find one out of balance but it still did not solve the shudder issue. From there I went to a local transmission shop. Owner took it out and I rode along to see what he thought. He feels there’s nothing wrong with the tranny or torque converted but rather a possible engine issue. He’s thinking a maybe a plugged injector or possible gasoline contamination. He stated at such a low speed that there no way the torque converted could be an issue. So I’m going to take it back to the dealer and have them scan the computer for errors.
tailwaters is offline
post #93 of 97 (permalink) Old 09-15-2011, 08:07 AM
Quoted: 0 Post(s)
I bought my FJ with 50k on it and I have the shutter symptom as well. If it is the torque converter does anyone know what kind of dollar amount I am looking at to have this fixed? Also if I let it continue is it going to end up costing me more money in the long run?
Sent from my Autoguide iPhone app
Matt_Finley is offline
post #94 of 97 (permalink) Old 01-25-2012, 01:32 PM Thread Starter
Quoted: 0 Post(s)
jimmiee previously said: View Post
I was wondering what happened with the OP's transmission? Did he ever get a new transmission or a torque converter? It seems like the thread was hijacked and he quit posting or did I miss the 'fix'?
I had forgotten about this story until I read another thread about the same problem. Unfortunately I didn't get a new transmission, they did the fluid flush and so far, problem solved. However, I've seen more than one instance where the fluid flush was only a temporary solution and the problem returned sometime down the road. If I feel any shudder at all that baby is going back to the dealership.
I have around 90k miles on the FJ and the warranty is good until 100k so I have some time, knowing my luck though, it'll probably happen around 101k miles.
PuyallupCoug is offline
post #95 of 97 (permalink) Old 01-25-2012, 04:52 PM
Quoted: 0 Post(s)
OP,
Although this issue was resolved for you, I do appreciate the time you spent detailing the troubleshooting of your shutter. I too have started to experience this issue with my 07 FJ. Today I had the Transmission fluid flushed and replaced. Obviously the shuttering is still there, but I'll prob need to drive a couple hundred miles to see if that worked. I'm also going to replace the Spark Plugs just in case.
Anyway, I just wanted to thank you. It's detailed forums like this that help us all save time and money. For those that are still following this issue, i'll update my progress to the shuttering issue as it unfolds.
--BJ
Irish_Pride_9 is offline
post #96 of 97 (permalink) Old 04-06-2012, 07:51 PM
Quoted: 0 Post(s)
"So thanks for the tip Beerz; I'm glad it worked for you. At least I've got new plugs!"
Good gosh, I am so sorry for messing you up! You replaced the spark plugs because of me? I am really sorry for sharing my experience! Hey, man, by all means, replace that transmission and torque converter!
Beerz is offline
post #97 of 97 (permalink) Old 04-22-2012, 09:43 AM
Toyota_Tech's Avatar
Quoted: 1 Post(s)
glad they did something for you OP, its been MONTHS since I ve looked at this post or been on this site...I remember talking to you about this whole situation though.
Alot of times, if you catch it in time, a fluid exchange can correct the issue if the plates and clutches in the TQ are not destroyed enough. Sounds like in your case you are good to go!
Toyota_Tech is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Problems / Dealer Service
