Master Cylinder - Toyota FJ Cruiser Forum
post #1 of 5 (permalink) Old 07-08-2014, 02:17 PM Thread Starter
cruizer27's Avatar
Quoted: 5 Post(s)
Master Cylinder
I have a 2007 FJ out of warranty. Dealership wants to charge $2100 for brake master cylinder part number 4705035052. I was able to find a FJ at a local junk yard. Cost for the part if I took it off myself is $200. Seems like a no brainer to me. The only issue is if I do get a used master cylinder it needs to be installed at a dealership. Has anyone else tried to replace the master cylinder on their own?
cruizer27 is offline
post #2 of 5 (permalink) Old 07-08-2014, 02:23 PM
Quoted: 161 Post(s)
Re: Master Cylinder
have you checked at a local auto parts store? I would think you could get a rebuilt one there and then do a core exchange and it would be more reliable than a junkyard and cheaper than the dealership.
L68SWEET is offline
post #3 of 5 (permalink) Old 07-08-2014, 02:39 PM Thread Starter
cruizer27's Avatar
Quoted: 5 Post(s)
Re: Master Cylinder
I'm taking it off a salvaged FJ with 4000 miles. Part looks good but before I buy it I need to find out if I can install it or have to go into a dealership to get it installed.
post #4 of 5 (permalink) Old 07-08-2014, 02:42 PM
iwashmycar's Avatar
Quoted: 1154 Post(s)
Send a message via AIM to iwashmycar
Re: Master Cylinder
According to the service manual the dealer has to hook it up to bleed the MC after install. Not sure if you could get all the air out the old fashioned way :shrug:
FSM instructions on how to bleed the master cylinder:
4. BLEED MASTER CYLINDER SOLENOID
HINT:
If the brake master cylinder is disassembled, the brake line is disconnected from the brake master cylinder or if the reservoir becomes empty, bleed the brake master cylinder.
(a) Connect the intelligent tester to the DLC3.
(b) Turn the ignition switch to ON.
(c) Select "ACTIVE TEST" mode on the intelligent
tester.
(d) Connect the vinyl tube to the rear brake caliper.
(e) Loosen the bleeder plug.
(f) Select "SRMF" to drive the solenoids and bleed air
from the rear brake caliper (step F).
NOTICE:
• Do not depress the brake pedal.
• Keep the brake fluid in the reservoir tank
above the MIN line during the above
procedures.
HINT:
• Brake fluid is sent through the pump.
BRAKE – BRAKE FLUID
BR–7
• To protect the solenoids, the intelligent tester turns OFF automatically 2 seconds after every solenoid has been turned ON.
(g) Repeat step F until all the air in the brake fluid is bled out.
(h) When the air is completely bled out of the brake fluid through the bleeder plug, tighten the bleeder plug. Torque: 11 N*m (110 kgf*cm, 8 ft.*lbf)
(i) Repeat the above procedures to bleed the other brake line.
(j) Turn the ignition switch to OFF.
(k) Turn the ignition switch to ON.
(l) Clear DTC (see page BC-45).
-Adam
'07 Black Diamond 4WD AT UR
TLCA #22985
295s | 3" | BL | Lights | Armor | Rails | Snorkel | CB | Dent(s)
Feb. 2017 Member of the Month
In the Midwest? OHIO FJ Owners
iwashmycar is offline
post #5 of 5 (permalink) Old 09-05-2014, 10:32 AM
Quoted: 4 Post(s)
Send a message via AIM to MeLvYnRaY Send a message via Skype™ to MeLvYnRaY
Re: Master Cylinder
Has anyone tried to get the air out the old fashioned way? Im going the same. Installing a new MC well a used one, but im wondering if i have to make a dealer visit.
2007 Fj Cruiser
*MetalTech Winch Tube Bumper
*MetalTech Rear Lower Control Arms
*MetalTech Rear Upper Control Arms
*Bilstein 2100 Adjustable shocks
*Rough Country 3" Lift Rear
*Engo 10k Winch
*35" BFG Km2
*G2 4:56 Gears front and rear
*6k HID hella Fog Lights
*Rigid dually LED
*All Pro IFS, Tranny, Elocker, Xfer case, Rear Diff Skids.
*Rear tire mount delete
MeLvYnRaY is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Problems / Dealer Service
