Looks like my Transmission Leaking (thoughts?) - Page 4 - Toyota FJ Cruiser Forum
post #31 of 36 (permalink) Old 03-26-2008, 09:45 AM
PaulThePhotographer's Avatar
Quoted: 1 Post(s)
Re: Looks like my Transmission Leaking (thoughts?)
CtheProducer previously said: View Post
O, they gave me a Prius!!!
Cool, lets take that to RRR today!!!
PaulThePhotographer
WonderfulPhotography
When you come to the fork in the road, go straight!
PaulThePhotographer's Blog
FJCruisersFlorida Forum!
Facebook Group "FJCruisersFlorida
PaulThePhotographer is offline
post #32 of 36 (permalink) Old 03-26-2008, 09:53 AM Thread Starter
CtheProducer's Avatar
Quoted: 0 Post(s)
Ok, well you will pay for the damage right? You really don't realize how big the FJ is until you get stuck in something like that!
2010 Tundra CM 4x4 Limited Trim - Powerstick Mufflers - Custom GPS mount
CtheProducer is offline
post #33 of 36 (permalink) Old 03-28-2008, 12:18 PM Thread Starter
Quoted: 0 Post(s)
Got my FJ back last night! All warranty!!! Only thing that sucks is they had to drain my oil (just put royal purple in) but thats ok cause I didn't pay for NOTHING!!!
And the FJ felt like a tank after driving the Prius for 2 days.
post #34 of 36 (permalink) Old 03-28-2008, 06:59 PM
DEWFPO's Avatar
Quoted: 78 Post(s)
JAXTOY previously said: View Post
Rear main seal sounds right, but I think we have timing belts not chains. Might want to get them to clarify, I would like to know myself.
We have a timing chain.
DEWFPO
Engine Block Heater, '08 Cyclone Pre-Filter, Dual horns, Phillips Osram 70W/65W H4's, RockBlocker and 3M Clear Film, Toyota RearSight Backup Camera, Ultra-Gauge MX 1.3.
"Enjoying the Journey"
DEWFPO is offline
post #35 of 36 (permalink) Old 10-13-2018, 09:52 AM
Tyler.sergent's Avatar
Quoted: 1 Post(s)
I’ve got a leak coming from somewhere near the end of my drive shaft, I just replaced the cv axle yesterday and the seal was leaking on that too but now there’s another leak coming from the rear end if the drive shaft...any ideas?
Tyler.sergent is offline
post #36 of 36 (permalink) Old 10-14-2018, 10:07 AM
Iconic_'s Avatar
Quoted: 2616 Post(s)
Tyler.sergent previously said: View Post
Iíve got a leak coming from somewhere near the end of my drive shaft, I just replaced the cv axle yesterday and the seal was leaking on that too but now thereís another leak coming from the rear end if the drive shaft...any ideas?
Sounds like you are describing a leaking rear pinion seal, area 1? Make sure its not instead leaking from area 2 this is much more common from what I've seen, which is where the third member bolts to the housing with a gasket between. Either way, its not a huge deal. Wash the area good and determine if the leak is bad enough to warrant fixing by checking after a few days of driving. Once you drive it heats up the fluid enough that it can seep out. The procedure to fix it should be the same for all Toyota 8" rear ends. Check out some youtube videos if you want to attempt it yourself, otherwise your mechanic will know how its done.
Iconic_ is offline
  Toyota FJ Cruiser Forum > Toyota FJ Cruiser Discussion > Problems / Dealer Service
  Similar Threads
Jerry Cans leaking? Hube01 General Discussion 7 01-29-2008 09:57 PM
Battery is leaking... Innovations Engine Performance 18 11-17-2007 09:09 AM
Tranfer case now leaking opg4759 Problems / Dealer Service 23 08-03-2007 05:45 PM
Front Diff leaking 10257 4x4 / Off-Road Tech 14 07-03-2007 04:30 PM
My FJ is leaking... I think. FJconvert? General Discussion 39 06-08-2006 12:53 PM
