Doug Thorley Y-pipe on your FJ in California? - Page 2 - Toyota FJ Cruiser Forum
Socal Region Regional forum for the Southern California area.
 15Likes
post #11 of 20 (permalink) Old 07-03-2018, 03:41 PM
SuperSiick's Avatar
Quoted: 114 Post(s)
Re: Doug Thorley Y-pipe on your FJ in California?
I have a used set taking up space between my manifolds and muffler. Rattles a little bit like my last set did. Thinking about swapping to URD Y pipe and BA muffler/resonator to drown out the URD rasp. Would also open up area to install an Atlas...
If u swap, go the URD U spec exhaust (equal lenght y pipe & cat back) that's what I'm currently running with the Magnuson Supercharger.
Sent from my Moto Z (2) using Tapatalk
Thorn661 likes this.
SuperSiick is offline
post #12 of 20 (permalink) Old 07-03-2018, 03:42 PM
SuperSiick's Avatar
Quoted: 114 Post(s)
jamesepoop previously said: View Post
He replied to me on brown room. I wonder if he has a used set taking up space :
Just got back to you on brown room
post #13 of 20 (permalink) Old 07-04-2018, 07:48 PM
Quoted: 51 Post(s)
As I am sure you know, in California if it doesn't have a CARB sticker its illegal.
The smog stations are getting picky now days cause they don't want to fined or lose the license.
I think once a station sees the illegal device it gets noted and no matter where you go, it can not be passed. Just a heads up.
TLCA 19971
07 FJ
MODS:
A/T KO2's, SWAY-A-WAY ,TOTAL CHAOS UCA, GPS MIRROR MOUNT, PRE-CLEANER, SIDE VISORS,
METALTECH OPOR SLIDERS, SCAN GAUGE, MPAC GOODIES, DUAL BATTERY MOD, TOY OUTFITTERS FRONT BUMPER KIT, RICOCHET ARMOR
MORE ON THE WAY
Past Vehicles:
70 FJ40
73 FJ40
USA4X4 is offline
post #14 of 20 (permalink) Old 07-04-2018, 07:58 PM
SuperSiick's Avatar
Quoted: 114 Post(s)
USA4X4 previously said: View Post
Yeah I passed smog with them. The resonators look as the secondary cats thus passes visual. As for throwing any code or diff reading once hooked up to the obd port. The scanner reads everything as it would be with the factory y pipe. This has also been tested to be true when doing tunning with Magnuson Superchargers. Factory O2 sensors still get used in the same location as on the OEM y pipe. But that's correct it doesn't have a CARB number.
post #15 of 20 (permalink) Old 07-04-2018, 08:24 PM
Quoted: 6 Post(s)
...Thinking about swapping to URD Y pipe and BA muffler/resonator to drown out the URD rasp.
Can you clarify what you're referring to here? I've got URD MT parts and am getting a "chirping noise" from the replacement throw-out bearding assembly I bought with the Stage II clutch assembly...
PLC92084 is offline
post #16 of 20 (permalink) Old 07-04-2018, 09:38 PM
Iconic_'s Avatar
Quoted: 2549 Post(s)
PLC92084 previously said: View Post
I'm just talking exhaust. The URD offroad Y pipe removes the factory cats and replaces them with straight pipe. This will create quite the raspy noise with our V6's. (V8's still sounds alright) The full URD exhaust setup usually includes an additional resonator in the tailpipe to stop the rasp sound.
The Doug Thorley Y pipe also removes the cats but replaces them with resonators.
Iconic_ is offline
post #17 of 20 (permalink) Old 07-09-2019, 02:49 AM Thread Starter
jamesepoop's Avatar
Quoted: 1103 Post(s)
Finally installed mine. The DT has a slight roar/ rasp on acceleration. Can an exhaust leak be confused as raspy-ness?
bazross likes this.
jamesepoop is online now
post #18 of 20 (permalink) Old 07-09-2019, 03:11 AM
bazross's Avatar
Quoted: 1780 Post(s)
Paging Deb @debFJVT
debFJVT and jamesepoop like this.
bazross is offline
post #19 of 20 (permalink) Old 07-09-2019, 04:31 PM
Iconic_'s Avatar
I always thought an exhaust leak sounds similar to a cylinder is missing. With the DT Y pipe I noticed the exhaust gets a little more "untamed" louder and raspy. Not much but slightly noticeable.
jamesepoop likes this.
Iconic_ is offline
post #20 of 20 (permalink) Old 07-10-2019, 02:34 AM Thread Starter
jamesepoop's Avatar
Good to know. I'm going to check my AFE exhaust. The slip fit might be off and causing some leaking.
LEDLIYFJL: Live Every Day Like Its Your FJ's Last
Mad Maxxine Build - 2007 Fresco Silver Metallic
My Travels: http://www.downtownfotos.com
  Toyota FJ Cruiser Forum > Regional Forums > Socal Region
