How to Install New 6x9 Speakers in the Doors - Toyota FJ Cruiser Forum
 24Likes
post #1 of 124 (permalink) Old 05-10-2010, 10:19 PM Thread Starter
Cement Phantom's Avatar
Quoted: 9 Post(s)
For those of you interested in replacing those paper 6x9 speakers in the doors with some real speakers (without using an amp and leaving the factory wiring intact), here's an easy how-to so you can get the job done easily and quickly.
I used the factory housing and replaced the speakers with http://www.amazon.com/gp/product/B002CMUL30?ie=UTF8&tag=mcconchie-20&linkCode=as2&camp=1789&creative=9325&creativeASIN=B002CMUL30 6x9 speakers. I love them. Very clear. Makes me want to re-burn all my CDs in 256bit MP3s to see what I've been missing.
Step 1: Remove the door cover (click here to check out Land Cruiser Steve's excellent tutorial)
Step 2: Disconnect the speaker wire, use a Phillips screwdriver to remove the speaker from the door, and then use a knife to cut out the speaker from the housing
Step 3: Remove the back plastic support from the housing. I like to use tin snips for this job
Step 4: Set up wiring. You have two options here - solder wires to the factory connector:
Or remove the factory connector and use Crutchfield Toyota speaker harness (which will NOT snap into the factory housing, but will simply hang loose)
Step 5: Reattach the housing to the door and then pre-drill holes through both the plastic and the sheet metal in the four corners for a machine screw. I used 2.5" #10 sheet metal screws and pre-drilled the holes with a 9/16" drill bit
Step 6: Attach the speaker wires and then screw the four corners in
Step 7: Reattach the door and rock out
I hope this helps people out.
2014 Cement Grey
Cement Phantom is offline
post #2 of 124 (permalink) Old 05-11-2010, 07:29 AM
Quoted: 0 Post(s)
Re: How to Install New 6x9 Speakers in the Doors
very nice sir! big change in sound???
2007 Diamond Black, 6MT, 4x4
Let the mods begin!
Mister Ed is offline
post #3 of 124 (permalink) Old 05-11-2010, 08:30 AM Thread Starter
Quoted: 9 Post(s)
Yeah, these are great speakers, but you should be able to do this mod with about any 6x9 speaker.
2014 Cement Grey
post #4 of 124 (permalink) Old 05-11-2010, 07:22 PM
Quoted: 0 Post(s)
while i don't agree with putting coax's in when you have install locations for components, or i guess i don't agree with coax's at all, it was a nice write up though. very detailed and informative. thanks for taking the time to snap some pics as this will help others for sure
FatJohnson likes this.
mattyjman is offline
post #5 of 124 (permalink) Old 05-11-2010, 08:39 PM
Quoted: 0 Post(s)
great write up. Will definitely save my a** in the future
guardiank9 is offline
post #6 of 124 (permalink) Old 07-23-2010, 12:41 PM
CTTHROT's Avatar
Quoted: 0 Post(s)
This was very helpful for me when doing the switch so thank you very much for the great write up.
After I had followed these steps on the first door, I left the stock speaker attached to the door when cutting everything out to use as a mount on the second door. Saved a little time.
Also, I had to cut out the speaker shaped ring on the inside of the door panel to make it snap back into place properly over my new speakers.
Sound is much better!!
CTTHROT is offline
post #7 of 124 (permalink) Old 07-23-2010, 01:28 PM
fjessence's Avatar
Quoted: 20 Post(s)
Send a message via AIM to fjessence
did you need an additional amp for these speakers or was factory power sufficient enough?
"Sand Ronin" 08' Sandstorm FJC
TRD Supercharged, Demello 3 hoop front bumper with Acro fogs and 22" LED bar, Demello 3 piece rear bumper with Acro fogs, 50" Curved OZUSA LED bar with Trailworx Fab A-Pillar mounts, Demello Hybrid sliders, All Pro engine skid, Fox 2.5" coilovers with reservoirs, Fox 2.0" rear shocks with reservoirs, 17" KMC Hoss wheels w 285 BFG KM2s
Sand Ronin Build Thread
-Sang
DO Rocks!
fjessence is offline
post #8 of 124 (permalink) Old 07-23-2010, 01:34 PM
Buck Henry's Avatar
Quoted: 0 Post(s)
fjessence previously said: View Post
I installed a pair of Pioneer 4-way 6x9's using the above method ($69 from Wally World) with no additional amplification. The FJammer drives them just fine and the sound is light years better than the stock speakers. You will be pleased with the results!
Buck Henry is offline
post #9 of 124 (permalink) Old 07-24-2010, 04:03 PM
Evil Trunk Monkey's Avatar
Quoted: 15 Post(s)
CTTHROT previously said: View Post
I second this... Very helpful post. I also needed to use a very sharp knife to carefully trim the ring on inside door panel. It wouldn't quite snap back on until I gave it some breathing room.
Evil Trunk Monkey is offline
post #10 of 124 (permalink) Old 07-25-2010, 03:30 AM
FJ Qatar's Avatar
Quoted: 0 Post(s)
Infinity speakers i will do mine with:
KAPPA32.9CF speakers in dash and rear pillars, 6x9 KAPPA693.9I
what do think with my chose???
thnx also for info
09 white 5AT
*MODS:
-TRD cat-back exhaust -16TRD wheels Black -High patch horn -VKool tinted windows -Doug Thorley Long Headers -Doug Thorley Y-pip -aFe PRO7 CAI -aFe Silver Bullet Throttle Body Spacer -Kenwood DDX 8034BT -Kenwood KNA-G510 Navigation System -CB mount -275/70/16 Dunlop -OEM Auxiliary Driving Lights -Bi-Xenon Projector -Denso 35W ballast -Philips 85122+ Bulb -LED Tail & Park Front -OnBoard Air Compressor -Fog light front + rear
Soon:
more and more
FJ Qatar is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
chris68
