One Touch Window Up/Down Install How-To - Toyota FJ Cruiser Forum
post #1 of 26 (permalink) Old 12-07-2010, 01:45 PM Thread Starter
Quoted: 1 Post(s)
I just installed a couple of AutoLoc WC1000 control modules in my FJ. They work great. All connections can be made under the driver's window control/door lock control and there's plenty of room under there to mount the controllers.
I drew a schematic that illustrates how everything is wired, which should be attached below.
A few notes:
The instructions say *not* to wire the modules to the window's 12 vDC circuit. Horse pucky! The module doesn't know where the 12 vDC comes from, and the modules don't draw enough additional current to damage the factory wires.
Each module has an inline fuse holder with a 15 amp fuse installed. I removed them and wired them without an additional fuse. If you decide to keep the fuse holders, I'd recommend installing a much lower fuse in each.
Two of the wires on each module are for use with after-market remote systems. I pulled each of them from the harnesses to help reduce the rat's nest of wires.
To clarify something in the schematic, the following four factory wires are cut in half: light blue, light blue/black, red, red/black.
-Matt
MattTheHat is offline
post #2 of 26 (permalink) Old 12-07-2010, 02:23 PM
Capt Sensible's Avatar
Quoted: 7 Post(s)
Re: One Touch Window Up/Down Install How-To
So as to make sure I understand what you've done here. This is a mod so you can just tap the switch and the windows will roll down?
Chris
"It's lonely being a cannibal. Tough making friends."
2007 Black Diamond FJ Cruiser, Auto, 4wd, Toytec Ultimate 3" lift, Light Racing Upper Control Arms, TheToyOutfitters LCA, Procomp Series 87 Steelies Painted White, 285/75 R16 Mickey Thompson Baja Claws, Trail Gear Sliders, TheToyOutfitters Custom Front Bumper, Snorkel, Outrider Lower Link Armor
www.TRDParts4U.com
Capt Sensible is offline
post #3 of 26 (permalink) Old 12-07-2010, 02:28 PM
VT_RainMan's Avatar
Quoted: 0 Post(s)
No comprendo amigo?? What does this do?
2007 FJ 6MT black -n- black
VT_RainMan is offline
post #4 of 26 (permalink) Old 12-07-2010, 02:32 PM
Quoted: 5 Post(s)
looks like it gives you one touch up on the windows (a really nice little feature) in addition to one touch down.
ducky is offline
post #5 of 26 (permalink) Old 12-07-2010, 03:48 PM Thread Starter
Quoted: 1 Post(s)
Yup, one touch, up and down. I installed a module for the driver's side window and another for the passenger side window, so I have one-touch up and down for both windows. The passenger can fend for him or herself.
-Matt
post #6 of 26 (permalink) Old 12-07-2010, 03:49 PM Thread Starter
Quoted: 1 Post(s)
And I guess I should clarify...
"One-touch" is any touch, long or short. Press it once and it starts heading down. Press it again and it stops.
-Matt
post #7 of 26 (permalink) Old 12-07-2010, 03:59 PM
bc_indiana's Avatar
Quoted: 115 Post(s)
I've seen the one touch down...but what stops the one touch up if something is in the window?
Will people lose fingers?
2008 Trail Teams Special Edition
Friendly and Useful Vendors I send money to from time to time:
MetalTech
Demello Offroad
SpringtailSolutions
RicochetOffroad
Where my money goes...(CLICK FOR THE BUILD OF OREO)
bc_indiana is offline
post #8 of 26 (permalink) Old 12-07-2010, 04:18 PM
Joeg180's Avatar
Quoted: 59 Post(s)
Source or link for the controllers?
Time required for the install?
Thanks
08 Sandstorm, CQ, OF, C7, CF, All Wthr Mats, TG Sliders, Extra Horn, Tundra Handles, Wet Okole Seat Covers, Springtail M-PAC HD Side Rack, Basket, , Stand Alone Fuse Block, IPF 968, LED's under hood, extra 12v outlets, FJTOYMAN's rear shock skids, Scuba Mod, IronMan Front Coils/ToyTec Rear Coils, Bilsteins, ToyTec Swaybar Relo Kit, IMP Shift & Tcase knobs, BudBuilt Skids, Demello/EXp1 Bumpers, 10lb Powertank, Viper Max 12k Winch with Amsteel Synth Line, FrontRunner Slimline II Rack and accessory mounts, LED Spot Lights on rack, SPC LR UCAs, Bandi Body Lift & BMC
KD2HWV
TLCA #19565
GCLC #2128
http://www.fjnortheasters.org
Joeg180 is offline
post #9 of 26 (permalink) Old 12-07-2010, 04:33 PM
Quoted: 162 Post(s)
nice. i was planning to install auto roll up windows soon.
floppyD is offline
post #10 of 26 (permalink) Old 12-07-2010, 05:17 PM Thread Starter
Quoted: 1 Post(s)
^ will I lose fingers?
I don't know. I *assume* the circuit monitors current draw on the motor leads and shuts off when the load starts to go high (as in someone gets a body part in the way or the window reaches the end of its travel). This assumption is based on the fact that there are two different ICs, about 6 transistors, a couple of relays, and one big honking .06 Ohm resistor. Load-sensing circuits typically monitor the load across a very low value resistor. So I'm not worried. If you lose a digit, though, don't blame me.
> where to buy
You can buy directly from AutoLoc: The Hoffman Group - Autoloc - One Touch Up And Down Window Unit - (Up AND Down) but they can be had for about half that price from AutoLoc dealers. I paid $35 for a set of two.
> total install time
Probably an hour to an hour and a half for most folks. After doing it once, you could probably do it again in 30 minutes.
-Matt
