Alternator voltage? - Page 2 - Toyota FJ Cruiser Forum
 81Likes
post #11 of 114 (permalink) Old 03-26-2015, 06:10 PM
captinmo's Avatar
Quoted: 215 Post(s)
Re: Alternator voltage?
Stupid question, but where/how is this installed? I'm having the same issue with my AGM battery.
captinmo is offline
post #12 of 114 (permalink) Old 03-26-2015, 08:19 PM
Quoted: 1400 Post(s)
brianh previously said: View Post
(snip)
There are some ways to increase the voltage of your alternator but it's not a simple adjustment. .
Can you provide some specific information on these various methods of increasing alternator output voltage ?
FJtest is offline
post #13 of 114 (permalink) Old 03-26-2015, 08:26 PM
Monkey_Wrench's Avatar
Quoted: 314 Post(s)
FJtest previously said: View Post
By putting a diode inline on the field wire, you're dropping the voltage to the alternator by .2vdc which will in its turn out out a higher voltage to the batter/buss.
Haven't looked on the fj schematic for it yet, but I assume this fuse looking deal goes I the alternator (field) fuse slot.
You could do the same with two spade connectors, a good inline fuse and a diode. Adding more diodes inline would raise alternator output even more.
Moab Junky likes this.
"Opinions are like assholes, everybody is one"
M1101/M1102 Information.
Evil FJ build thread.
Monkey_Wrench is offline
post #14 of 114 (permalink) Old 03-26-2015, 08:26 PM
bazross's Avatar
Quoted: 1828 Post(s)
captinmo previously said: View Post
G'day,
I believe you swap it out with your ALT fuse in the engine fuse box.
Cheers
Baz
captinmo and FAUJI like this.
bazross is offline
post #15 of 114 (permalink) Old 03-27-2015, 12:16 AM
FAUJI's Avatar
Quoted: 381 Post(s)
G'day,
Cheers
Baz
thats what I gathered as well. went ahead and ordered it. this is often an issue with agm battery.
FAUJI is offline
post #16 of 114 (permalink) Old 03-27-2015, 01:35 AM
FinnJ's Avatar
Quoted: 239 Post(s)
Monkey_Wrench previously said: View Post
Diode in the field wire? That can be done for a few dollars vs. the $50 eBay link.
Yes, like I said, but I feel the fuse swap much easier. I donīt want to try which diode works best and I like to keep the fuse box/wires as factory look.
sbarr previously said: View Post
Maybe there are cheaper fixes than the HKB Electronics version, but I do not mind supporting a vendor that has taken the time and done the research.
There is a cheaper model for sale too:
Toyota FJ Cruiser Alternator Voltage Booster MK1 | eBay
Just change the 7.5A fuse of the alternator.
2007 FJ Cruiser 6M/T CNG TRD Supercharged
My buildup thread
1981 Land Cruiser BJ42 Diesel (under progress)
FinnJ is offline
post #17 of 114 (permalink) Old 03-27-2015, 01:41 AM
bazross's Avatar
G'day
The other way to do is with a battery conditioner ... such as a Redarc BCDC25 I think that is the model.... but at $500-$600 its a lot more.
Still it does a lot more than a fused diode will do too. solar inputs and other such things....
Cheers
Baz
bazross is offline
post #18 of 114 (permalink) Old 03-27-2015, 08:03 AM Thread Starter
RichJacot's Avatar
Quoted: 65 Post(s)
A great revive on an old thread.
I will look into this further.
Thanks Guys!
2010 TT, Toytech Front Spacer for full 3" Lift, OME Med. Lift, BMC (by Bellydoc), KM3 LT35/12.50R-17 on Method 105 Beadlocks, Spidertrax Spacers, Demello Front Bumper, Expedition One Rear Bumper with Swing-Out, Expedition One Washer Bottle, Gobi Stealth Rack, White Knuckle Off Road DOM Rock Sliders, Pioneer AVH-4100NEX, ICON Panhead, Husky liners, GlowShift Elite 10 Color Oil Pressure, Trans. Temp. and Water Temp. Gauges., Warn M8000, ARB 50Qt.Fridge, Luna Dual Battery
TLCA#22165
RichJacot is offline
post #19 of 114 (permalink) Old 03-27-2015, 09:15 AM
Bar3K's Avatar
Quoted: 1870 Post(s)
X2
It looks like they are giving a false reading to something to get the output to raise
Monkey Wrench, the field circuit is external to the alternator and voltage regulator?
Where is VegasNick? How does this work?
Bar3K is offline
post #20 of 114 (permalink) Old 03-27-2015, 11:06 AM
Bar3K previously said: View Post
X2
This is a simple and straightforward solution for raising the alternator output voltage by a few tenths of a volt.
Here's how it works:
1. The alternator has an internal voltage regulator, but it has an external voltage "sensing" terminal that allows the regulator to "see" the actual charging voltage at the battery terminal, rather than just sensing the voltage at the alternator's output terminal. This way the regulator can "compensate" for any voltage drop in the wiring between the alternator and the battery.
2. If we intentionally create a small voltage drop (like 0.5 volt) in this battery voltage sensing line, we can "trick" the alternator into providing a small increase in output voltage. The alternator regulator now doesn't see the true battery voltage, it sees battery voltage minus 0.5 volt. The regulator now boosts its output voltage by 0.5V above its "normal" output voltage.
3. Typical silicon rectifier diodes have a forward voltage drop of around 0.5 - 0.6 volt. If we add one of these diodes in series with the alternator's battery voltage sense line, the alternator regulator now thinks it "sees" a battery voltage that's ~0.5 volt less than the actual battery voltage, and it boosts output voltage accordingly.
4. Conveniently, Toyota has fused the alternator sense line with a standard plug-in fuse. If we make a custom little module that looks like a fuse, but actually contains a silicon diode AND a fuse element, we have a quick, plug-in fix for creating the 0.5V voltage drop, and boosting battery voltage by the 0.5V that we desire. If we want to design the module to be idiot-proof, we can incorporate TWO diodes in parallel, but with opposed polarity, so no matter which way we plug the module in, one of the diodes is of the correct polarity to supply current to the alternator's battery voltage sense line.
t0ked, adam12_4, lqdchkn and 7 others like this.
FJtest is offline
