PIAA Wire harness fire - Page 2 - Toyota FJ Cruiser Forum
post #11 of 20 (permalink) Old 12-23-2007, 11:36 AM Thread Starter
Bodegas's Avatar
Quoted: 0 Post(s)
Send a message via MSN to Bodegas
Re: PIAA Wire harness fire
Well, i just stripped the harness out and it was ONLY the passenger side of the harness.
07 VooDoo C Package
Custom built PreRunner bumper
2.5" Fox Racing coilovers w/ AllPro UCA's and HD links
2.0" Fox Racing rear shocks w/ AllPro Springs
295 75 17 Nitto Terra Grapplers on Pro Comp rock Crawler 52's
1.25" aluminum wheel spacers
AllPro shock and trailing skids
TRD CAI & exhaust
Cobra CB w/ 4' K40 on BandiMount
JVC KW-NT1 dvd/nav
JL Audio speakers
PIAA 520 ATP's
ScanGaugeII
body mount chop
Demello Sliders
EBC Greeen pads and slotted rotors
www.fjcruisersontario.com
Bodegas is offline
post #12 of 20 (permalink) Old 12-23-2007, 11:38 AM Thread Starter
Bodegas's Avatar
Quoted: 0 Post(s)
These lights came from James with my Expedition One front bumper.
For warranty purposes,should I be disassembling the relay?
Actually, the relay looks fine, maybe discolored a lil dark but not melted
07 VooDoo C Package
TRD CAI & exhaust
JVC KW-NT1 dvd/nav
JL Audio speakers
PIAA 520 ATP's
ScanGaugeII
body mount chop
Demello Sliders
Bodegas is offline
post #13 of 20 (permalink) Old 12-23-2007, 12:01 PM
NestahEdition's Avatar
Quoted: 72 Post(s)
Sorry to hear about what happen to your PIAA harness.
I have the PIAA 520 SMR's and 4 set of Hella micro DE's.
Will all these directly wired/always hot wiring harnesses, I mounted a 10mm wrench at the battery bolt holder for quick access (to a tool) to disconnect the negative battery cable if needed.
TLCA #17592
2007 FJ Cruiser 4x4 Auto Titanium Silver
Mods too long to list so I created a website www.nestahedition.com
www.Facebook.com/NestahEdition
http://instagram.com/nestahedition#
http://norcalfjs.ning.com/
"The silent force" - NestahEdition
"Don't be a So-So. Let your creativity show!"- My spouse
https://www.fjcruiserforums.com/foru...ml#post2480798 NestahEdition March 2013 Member of the Month
http://www.fjc-mag.com/july-2013/nestah-edition - NestahEdition 07 FJ Featured on July 2013 issue
NestahEdition is offline
post #14 of 20 (permalink) Old 12-23-2007, 12:05 PM
felonious's Avatar
Quoted: 0 Post(s)
If you say that your install was correct and properly done than just return it to them and get another harness and call it a day. but you said that the switch light never worked are you sure that you had all of the wiring in the correct location and the switch grounded? A wiring harness just doesn't burn apart with out a reason so I would be checking all of the install that you did. Do you hear anything loose in the rely?
felonious is offline
post #15 of 20 (permalink) Old 12-23-2007, 12:16 PM Thread Starter
Bodegas's Avatar
Quoted: 0 Post(s)
The install was exact per the schematic. the system was grounded to the chasis ground and the Switch power was installed with the supplied connector from PIAA to my low beam 12V source. nothing is loose in the relay. Even if it went to ground, the fuse should have blown killing the power.
07 VooDoo C Package
TRD CAI & exhaust
JVC KW-NT1 dvd/nav
JL Audio speakers
PIAA 520 ATP's
ScanGaugeII
body mount chop
Demello Sliders
Bodegas is offline
post #16 of 20 (permalink) Old 12-23-2007, 12:18 PM Thread Starter
Bodegas's Avatar
Quoted: 0 Post(s)
I am calling it the day, we have a 3 hour trip ahead of us and have her convinced we wont/cant burn down on the highway.
Thanks for the input ( I will deal with this after the holidays). Merry Christmas and play safe!
bob
07 VooDoo C Package
TRD CAI & exhaust
JVC KW-NT1 dvd/nav
JL Audio speakers
PIAA 520 ATP's
ScanGaugeII
body mount chop
Demello Sliders
Bodegas is offline
post #17 of 20 (permalink) Old 12-23-2007, 12:41 PM
cruiserlarry's Avatar
Quoted: 4 Post(s)
2007fj previously said: View Post
The fuse should have blown.
Keep us posted on what you find out.I have the same kit and the switch light does work so maybe a relay problem??
The fuse won't blow if the ground is shorted to 12v, and the power is shorted to ground (polarity reversal), or both wires are hooked to power. This goes around the fused side of the relay, and will melt the wiring.
W6LPB / WPOK492
TLCA #9632
cruiserlarry is offline
post #18 of 20 (permalink) Old 12-23-2007, 12:47 PM
FJBinky's Avatar
Quoted: 1 Post(s)
Has nothing to do with the relay or switch. If it did then the relay or switch would be melted.
Wherever the most insulation is burned away is most likely where the short occurred.
All it takes is one little loose strand of wire to start the short, melt the insulation and turn into a small fire. Good to hear that you caught it in time.
FJBinky is offline
post #19 of 20 (permalink) Old 12-23-2007, 04:13 PM
felonious's Avatar
Quoted: 0 Post(s)
FJuice previously said: View Post
The lights were not on at the time of the melt down so the only location that it could have received the power from would have been the relay area. And a bosh relay can handle up to 30 amps no problem with there interior parts so the 16 gage wire will melt before the relay will fry a electrical short will take the easiest path to ground.
post #20 of 20 (permalink) Old 12-24-2007, 09:24 AM
Quoted: 0 Post(s)
Hi Guys!
I have Piaa 520s and 60XTs installed in my Fj using the Piaa supplied harnesses and switches.The lights on my switches have both worked from the day of installation although one is brighter than the other. Canadian_Rocks reported that his switch light never worked. I am curious if this in someway indicated a short from the beginning.
Marc
mml4 is offline
  Similar Threads
Tow Hitch Installation and Wire Harness???? KevMansFJ Interior / Exterior Visual Tech 11 04-20-2013 06:04 PM
wire harness question fixius03 General Discussion 6 12-10-2007 09:07 PM
How to wire into subwoofer Harness? ATVAHOLIC Stereo / Electronics / Electrical 4 10-03-2007 08:14 AM
what is the wire harness kit? frebay Newbie Discussions 10 08-04-2007 11:30 AM
Subwoofer Wire Harness fourx4ord Stereo / Electronics / Electrical 1 10-14-2006 10:05 PM
