Made this today in 10 minutes using scrap plywood..and 4 bolts!
I cut the plywood to the existing OEM bolts. Marked the holes and mounted using longer m8x1.25 bolts... the mounted the amp using through bolts (nut and bolted to the wood with washers and locker washers and all the junk...a little paint here and there.. the end result was a very tight secure fit which im 100% happy with...considering i had all supples at my disposal..
