A/C will not blow cool air and A/C light won't turn off - Toyota FJ Cruiser Forum
post #1 of 9 (permalink) Old 09-18-2019, 07:00 AM Thread Starter
Quoted: 1 Post(s)
Hello, I have a 2009 FJ, I went out for dinner and when I hopped back in the A/C simply stopped cooling, the blower blows, if I turn the temp to heat it blows hot, the "recycle" button works but the A/C light stays on no matter what I do, I am aware that the temp dial cant be on "Max AC" in order to turn the A/C button off. Even on Heat the A/C button wont turn off.
In summary AC is not blowing cool air and it's also not acting properly. Not sure where to start with this issue.
Has anyone had a similar issue??
Alberto Davila is offline
post #2 of 9 (permalink) Old 09-18-2019, 07:23 AM
oldMattB's Avatar
Quoted: 27 Post(s)
Re: A/C will not blow cool air and A/C light won't turn off
Yes, on our 2007.
After about an hour of driving, it corrected itself. This happened maybe eight years ago, and I have had no subsequent issues with the AC.
Matt B
oldMattB is offline
post #3 of 9 (permalink) Old 09-18-2019, 08:13 AM Thread Starter
Quoted: 1 Post(s)
That has not been the case here.
post #4 of 9 (permalink) Old 09-19-2019, 06:45 AM
Cholerabob's Avatar
Quoted: 218 Post(s)
Is the a/c compressor running ? Is the a/c fuse ok ?
Bilsteins 5100, Metal Tech Rear Long Travel, Camburgs Balljoint UCAs, Full Ricochet Skid Plates, All Pro Sliders, RESZ Fab rear LCAs , Luna Dual Battery, Cooper STT PRo 35s on 16' Mickey Thompson Classic Baja Locks, FJToyman Shock Skids, Total Chaos lower link Skids, Boztec Dif Skid, Exp1 front Diamond Bumper, Exp1 Rear Bumper with Carrier, Viper winch, Ricochet Lighted Air Dam
Cholerabob is offline
post #5 of 9 (permalink) Old 09-19-2019, 03:37 PM Thread Starter
Quoted: 1 Post(s)
I took it to the shop, the Evaporator has a leak... time for a new one. I was hoping it was something less invasive...
Thanks for your help tho
post #6 of 9 (permalink) Old 09-19-2019, 09:19 PM
tukes mountain man's Avatar
Quoted: 22 Post(s)
Alberto Davila previously said: View Post
Yes happened to me a while back. I checked this forum and found others had the same issue. Found a thread that suggested changing the mag clutch relay. It solved my problem.
Mine: 2007 TRD SE
Mods: OME Med Lift, Tires 285/75/16 Nitto Trail Grappler M/T's, TRD CAI, Wilderness Rack with 4ea 130 watt 6" KC Slimlites, 2ea 130 watt 8" KC Slimlights mounted to front bumper, Cobra CB with Bandi Antenna Mount, Garmin 550 Street Pilot with Ram Mount. Scan Guage, Backup Cam
Wife's: 2019 TRD Off Road Premium,
Mods: Lifted with BFG's and TRD Wheels, and yes I get to drive it once in awhile.
Tuke
tukes mountain man is offline
post #7 of 9 (permalink) Old 09-19-2019, 09:36 PM
clay763's Avatar
Quoted: 19 Post(s)
tukes mountain man previously said: View Post
I had the exact same problem you are having, and it was also the mag clutch relay for me, cost $7 at the local Autozone... maybe ask some questions of your shop before they start replacing things.
2012 Silver - Sold
2018 T4R Cavalry Blue
clay763 is offline
post #8 of 9 (permalink) Old 09-23-2019, 10:39 AM Thread Starter
Quoted: 1 Post(s)
Thanks for the Heads up, I took it to two different shops where they ran the same pressure tests on the AC parts and the diagnostic result was the same, Evap leak.
post #9 of 9 (permalink) Old 09-23-2019, 12:18 PM
Cholerabob's Avatar
Quoted: 218 Post(s)
Ouch... 8hrs job for a 100$ part...
