Running 12v to a camper to charge battery - Toyota FJ Cruiser Forum
post #1 of 3 (permalink) Old 11-25-2009, 04:36 PM Thread Starter
cowtown dave's Avatar
Quoted: 0 Post(s)
I have a camper with a battery that is charged from the FJ through a 7 way plug at the hitch. I want to only charge the battery when the ignition is on, this will save my battery on overnight stops etc. So I'm going to go from the battery to a relay of some sort that is triggered by the ignition, then to the hitch electrical. So my question what type of relay should I use. I'm thinking one like I use for my aux lights but would like an expert or someone that knows more than me!!
2008 4x2 Sandstorm
In the process of making it my own...
cowtown dave is offline
post #2 of 3 (permalink) Old 11-25-2009, 06:43 PM
Quoted: 0 Post(s)
Re: Running 12v to a camper to charge battery
Wire it directly to the alternator ?
max-9 is offline
post #3 of 3 (permalink) Old 11-25-2009, 06:44 PM
rotorhed1's Avatar
Quoted: 1111 Post(s)
I would suggest that rather than a standard relay you install a constant duty solenoid. Most RV stores have these. They are also used on some P/U trucks with a second battery installed. They will handle many amps for a long time.
And yes I agree with you wanting to wire this so that it only powers the RV battery when the FJ is running. So the solenoid should be powered off the acc or ign circuit, or thru a switch that you control.
rotorhed1 is offline
