886 OME problem - Toyota FJ Cruiser Forum
post #1 of 9 (permalink) Old 10-30-2010, 09:56 PM Thread Starter
Quoted: 0 Post(s)
886 OME problem
Hello all,
Ive installed 886/896 setup on my fj last week, and Im expirencing some "wiki wiki" sonds while driving, like metal scratching and dry metal hit sound when I pass over a street hole.
This not happened with stock suspension, I have Rockteck front bumper and Superwinch 9.0 EPI in front, do I need to add more load in front to get this suspension working properly? or could be a bad installation issue?...is this possible? it seems like all parts only fits in the right position and is not possible to put them in wrong way.
Any help or suggestion appreciated,..
Thans in advance...
Ra.-
ramienrosillo is offline
post #2 of 9 (permalink) Old 10-30-2010, 10:33 PM
FJhawkdriver's Avatar
Quoted: 7 Post(s)
Re: 886 OME problem
I've got the 886/896 set-up also but have had no problems. Had it on and off road full flex and extension with no problems. It is a bit stiff and ruff over holes. A bit harder when light and empty. MIght check your install but can't think of what it could be. You should have some heavy weight though if you are running that set-up. Could damage your shocks if not.
2007 Silver Titanium, AT, TRD CAI/SuperCharger, 4.56 gears, ARB Front Locker, ARB front and rear bumpers, WARN 8000 winch, Full Ricochet Skids, Total Chaos 2"LT/MetalTech rear LT, AllPro Sliders, AllPro Airdam, Fourtreks mounts, Highlift Extreme, MPAC rear and side, Powertank, Dirty Part's Dual Battery kit, Nitto Trail Grappler M/T 295/70/17, and a bunch of other stuff to get me where I want to go.
FJhawkdriver is offline
post #3 of 9 (permalink) Old 10-30-2010, 11:06 PM
Layonnn's Avatar
Quoted: 11 Post(s)
Re: 886 OME problem
You should be okay with a rocktek and a winch, but ideally you'd want a heavier bumper for those springs. Metal on metal sound? Pressure wash the entire front suspension to clean it up and then closely inspect all of the front suspension to see if you can find any rubbing spots or paint missing. My guess is you are having the UCA contact the coils.
Aftermarket UCA would fix that issue.
You also need to make sure that the coil seat on the bottom faces the rear of the vehicle.
1997 FZJ-80 Locked - Sold
-Layton
TLCA# 20623
Layonnn is offline
post #4 of 9 (permalink) Old 10-30-2010, 11:48 PM
landy's Avatar
Quoted: 11 Post(s)
Re: 886 OME problem
It could also be the sway bar contacting the spring. If that's the case you can get the simple sway bar relocation brackets from Toytec. Good luck in your search!
Landy
Support these fine vendors!
TRDParts4U
Demello Offroad
Ricochet
Icon Vehicle Dynamics
landy is offline
post #5 of 9 (permalink) Old 11-02-2010, 03:49 PM Thread Starter
Quoted: 0 Post(s)
Re: 886 OME problem
Thank you all guys for you kind reply, I will give a presure wash to the front of my rig and check what could be that sound.
I think is not the suspension, it looks like the bumper is rubbing with metal piece of the body, because it sounds when I push the rig from side to side and not up and down.
Ill let you know what I found.
Thanks in advance.
post #6 of 9 (permalink) Old 11-02-2010, 08:46 PM
landy's Avatar
Quoted: 11 Post(s)
Re: 886 OME problem
Oh yes, it could also be the outer bumper frame pieces that extend on each side to the headlight support bracket. 2 10mm bolts on each side and they're off. I had the same problem with my Demello Bumper.
Landy
TRDParts4U
Demello Offroad
Ricochet
landy is offline
post #7 of 9 (permalink) Old 11-03-2010, 09:20 AM Thread Starter
Quoted: 0 Post(s)
Re: 886 OME problem
landy previously said: View Post
Interesting Landy, Ill try to take a look to those bolts closely, maybe could be the same case.
Thanks
post #8 of 9 (permalink) Old 11-04-2010, 09:29 AM
landy's Avatar
Quoted: 11 Post(s)
Re: 886 OME problem
If you need pictures of what I'm talking about, let me know and I'll dig some up.
Landy
TRDParts4U
Demello Offroad
Ricochet
landy is offline
post #9 of 9 (permalink) Old 11-11-2010, 05:40 PM Thread Starter
Quoted: 0 Post(s)
Re: 886 OME problem
Hi all,
I finally found the desperating sound he he he, It was the A/A house connection bolt in front of the rig was scratching the bumper...
Ill upload some pics this weekend
Thanks a lot to all of you guys.
Cheers...
