Steering wheel shimmy - Page 3 - Toyota FJ Cruiser Forum
post #21 of 26 (permalink) Old 06-29-2012, 02:59 PM
KalahariRover's Avatar
Quoted: 0 Post(s)
Re: Steering wheel shimmy
Mine 2010 TT got the shimmy after owning it for around 6 months. Mostly at around 60 to 65mph.
I inflated the tires a bit above the pressure shown on the door sticker, and that helped, but it was still there.
Three months more tire wear and it was gone and hasn't come back in over a year. I'm on the same tires.
So it seemed to be just a combination of tire pressure and a period of tire wear; once out of this "band" the problem was cured.
KalahariRover is offline
post #22 of 26 (permalink) Old 05-10-2013, 03:24 PM
peter2772000's Avatar
Quoted: 10 Post(s)
lqdchkn previously said: View Post
I checked the 2011 FSM and yes there is a preload on the steering gear. However if your truck ever drove ok, then I would doubt this value was incorrect. Let him try it if it works then sweet, maybe we have another fix option
Can anyone tell me what this preload value is. My shimmy is back erratically and my old tech still insists that this is the problem.
ANYONE?
peter2772000 is offline
post #23 of 26 (permalink) Old 05-12-2013, 04:59 AM
Quoted: 10 Post(s)
Bump!!!!!
post #24 of 26 (permalink) Old 05-12-2013, 03:49 PM
Banned
Quoted: 1868 Post(s)
Assuming your guy knows what he's doing this looks like the part he'll need
"Standard preload:
1.6 to 2.3 N*m (16 to 23 kgf*cm, 14 to 20 in.*lbf)
If the total preload is not within the specified range, replace the power steering link assembly.
HINT:
• Measure the standard preload at the steering rack neutral point.
The steering pinion shaft is fully turned when turned approximately 3 times. Half of the distance from the fully turned position is the neutral point."
lqdchkn is offline
post #25 of 26 (permalink) Old 05-15-2013, 06:13 PM
Quoted: 10 Post(s)
Awesome man, thank you very much. Will report back....
post #26 of 26 (permalink) Old 05-23-2017, 12:26 PM
sjp4ut's Avatar
Quoted: 19 Post(s)
well..
sjp4ut is offline
