I am purchasing my new springs for the rear of my truck on monday, and I notice ARB lists different part numbers for their springs for 07 to 09 vs 2010 and newer. Specifically 2889 medium spring vs 2895 medium. Is there a actual difference between them, or the model years themselves? I was all set to get the 895 but then they don't list that for 2010 and newer. Thanks in advance.
I'd be suprised if there was a difference between the rears. Different axle and frame, but the spring mount points should be in the same location. Unless they've actually changed the diameters on the mounts.
Arb is the only one that lists different part numbers for the rear springs based on year. I wonder what the difference is? Being that its Sunday I won't be getting a answer today from arb.
I'm not sure either........My All Pro rear springs on,y 07, that came with my Walker Evans rear shocks, are marked 07-09, painted on the coils. I wouldn't think they would be different in spring rate, height, or the base or top of spring where they mount...
They also aren't marked left or right so it's not a lean thing either..
There is some difference between what arb usa lists for FJ parts and the international application catalogue. I asked arb usa that question, and they said it is because USA has less strict restriction on lift than other countries, and we should follow the arb usa part numbers. The difference between 889 and 895 is 889 is longer by 10 mm. I thought about using 889 on driver side and 895 on passenger side to correct the driver side lean, but they are only sold as a pair, and arb usa specifically told me that parts should not be mixed and matched.
Ok excellent. I didn't find that PDF on their site. Whats odd is they list the exact same springs for both generations in that pdf, but not on their site. If the 889 is compatible with the fj like it shows on their normal site, that will be the one I will get. Thanks alot, a phone call to arb tomorrow should take care of everything .
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.7K members
Since 2005
