Hey gang,
for those with the daystar- what overall height did you see? I want to level and have seen good write-ups about the F/R kit. I have a parking garage that i deal with daily- 7' 2" max height...then theres my garage....
any measurements you can provide will be a great help!
You're at 79" to the top of the roof rack with stock suspension, wheels and tires. So add whatever the kit claims, and keep in mind tire height if you go larger.
I have the 1.5" Daystar spacer in the back with Bilstein 5100's in the front set at the 4th notch, which in theory brings the FJ level to 2.5" higher than stock, also have 285/75/16 tires and factory roof. The min height needed for my FJ to clear will be 6.8" ft, and the space between the roof and ceiling is tight, maybe 1" little more or little less, i may have to recheck that . but you shouldn't have any issues with any lift up 3" with a 7.2" high garage
Ugh JEALOUS..... i have 81" (depending on where its measured-lip of the floor or angle of the driveway) at home...and i will have to "modify" the arm for the garage door opener.
So the lift is possible, prob not tires...for now...
For those who replied, Did you need to add the drivers side spacer to get fully level? or is is not a big deal once the Daystar is added?
Got out and measured- Parking garage ill be fine. Home garage...that will be close if i add tires.
Thanks all!
Related Threads
Toyota FJ Cruiser Forum
3.7M posts
122.7K members
Since 2005
