Lower Link Comparison Guide - Page 8 - Toyota FJ Cruiser Forum
 54Likes
post #71 of 80 (permalink) Old 04-22-2016, 03:28 PM
Loganbeere's Avatar
Quoted: 818 Post(s)
Re: Lower Link Comparison Guide
81N4RY previously said: View Post
Let's see 'em!
Iconic_ likes this.
2013 Iceberg AT 4x4 | Ghost FJ Build | Instagram
Loganbeere is online now
post #72 of 80 (permalink) Old 10-11-2017, 12:05 PM
Quoted: 10 Post(s)
Does the TC lowers being a smaller OD negate the need for them being offset?
I'm shooting for maximum wheel travel, not wheel articulation. TC advertises their full link kit as offering 1.5" more droop.
sudo !! is offline
post #73 of 80 (permalink) Old 10-11-2017, 07:00 PM Thread Starter
Iconic_'s Avatar
Quoted: 2602 Post(s)
sudo !! previously said: View Post
Good question, I've always wondered that as well. If someone had the MT LT shocks and TC lower links they could tell us...
Iconic_ is offline
post #74 of 80 (permalink) Old 01-04-2018, 11:46 AM
Stephen Stock's Avatar
Quoted: 62 Post(s)
Dobinson from Australia seems to be somewhat of new player in the US market their UCA and Lower links are
38mm/1.5" wall thickness 5mm/.2." Made with HSLA steel, High Strenghth Low Allow.."HSLA steel cross-sections and structures are usually 20 to 30% lighter than a carbon steel with the same strength."wikipedia. The uca come with Sankei 555 ball joints. Here a link for the rear lowers
https://www.amazon.com/Dobinsons-Adj...PE2T7EEDBACT2S
Stephen Stock is offline
post #75 of 80 (permalink) Old 01-04-2018, 12:48 PM
BlindWilly's Avatar
Quoted: 843 Post(s)
LVTAP previously said: View Post
Rokmen is updating the design of their pro series and they are not available for purchase at the moment. They do have a less expensive trail series available.
Rokmen RM43017
These are the ones I bought roughly 2 years ago, along with the Panhard Bar.
https://www.rokmen.com/toyota-rear-u...-arms-534.html
My Understanding was that ToyTec took them over, but they still show up on Rokmen's website.
They are beefy!
Name:	20150302_155000 (Medium).jpg
ID:	980297   Click image for larger version
Name:	20150302_155015 (Medium).jpg
jamesepoop likes this.
Proud owner of "Muddy", my 2013 Quicksand FJ.
http://www.txpedition.com
"No Matter Where You Go, There You Are"
-Buckaroo Bonzai
BlindWilly is offline
post #76 of 80 (permalink) Old 01-04-2018, 01:32 PM
Quoted: 62 Post(s)
Stupid question but when installing a bolt through a poly bushing do you grease the bolt or just push it though the sleeve?Anti seize?
2014 Army Green, Radflo LT 3" lift /Dobinson springs, upper/lower links. Expedition one front bumper/Warn M8000.
Toyo open country M/T LT255/85R16 (33X10.00R16), spidertrack spacer, ARB fridge MTAC rear shelf and more
post #77 of 80 (permalink) Old 01-04-2018, 01:47 PM
StrangerRanger's Avatar
Quoted: 393 Post(s)
I've heard people argue for and against it both ways. Some say that if the end isn't greasable by a grease nipple then don't grease it. The reasoning being that if you apply grease at install, over time it will collect particulate that will prematurely wear the bushing. While if it had a grease nipple, you could grease it from time to time and force out any contaminates with fresh grease. The other side, don't grease it, and you may seize it, or wear it out by friction anyway.
Basically, do whatever you want. I personally would anti-seize it.
'07 Voodoo 4x4 AT
The Big Blue Build thread
Northeast Overland
T.R.E.A.D. Lightly!
KC1JJY
StrangerRanger is offline
post #78 of 80 (permalink) Old 01-07-2018, 07:29 AM
Quoted: 62 Post(s)
StrangerRanger previously said: View Post
Thanks for the comments, yup I used anti-seize on the bolts.
post #79 of 80 (permalink) Old 01-07-2018, 07:37 AM
jamesepoop's Avatar
Quoted: 1114 Post(s)
Stephen Stock previously said: View Post
Doesn't matter exactly. Maybe it'll reduce noise. But the bushings flex/rotate on the sleeve. So as long as the bushing to sleeve is greased, it should be fine. That's how it was with my Whiteline Panhard which look similar to the poly on your Dobinsons.
Stephen Stock likes this.
jamesepoop is offline
post #80 of 80 (permalink) Old 01-07-2018, 07:43 AM
Quoted: 62 Post(s)
jamesepoop previously said: View Post
Thanks
